Olli,Thank you very much @captain14 !
Will you have to match an existing pattern, or will it be covered/cladded?
I had to match an existing pattern & color scheme once, that comes with its own set of challenges. In the end, it takes a bit more time & a little more effort/ attention to detail and then it will turn out great.
Kind regards,
Olli
Olli,
The location is the back of the house, near the AC compressor and in direct sunlight from mid- morning until later afternoon.
It’s a 4” circle opening, so I’m thinking getting some cardboard and mark the circle and see what I can fit with brick pieces. Or I can just fill with mortar mix. I’m not comfortable enough to cut the remaining brick out to replace with full bricks
For some reason, the pic posted sideways.
Mets, Giants, and scotch. Those items add a nice finishing touch to your work space.Hi everyone!
Before diving into the rest of the forum, I’d like to introduce myself and show the first, completed, part of my little lair. It is only missing some trim on the ceiling, that I wasn’t able to install yet because other projects needed completion first.
My name is Olli, will be 39 this year, and I’m first and foremost a DIY’er with a primary focus on house & garden. But have a interest in (and do quite a bit of) other stuff as well.
As per the title, this is where I keep most of my tools, do maintenance on tools that require it, do office work & relax. I do have two more rooms, one for project work and one for storage. These are currently still undergoing remodel - so not to be shown yet.
I outfitted/build this room basically from scratch. Meaning that after tearing everything out that was in this room before, it was down to 4 rough brick walls & some pipes (heating) that needed to stay. 3 walls and the ceiling mounted piping were cladded by placing metal studs/framework and drywall. The fourth wall was cladded with mineral materials only, since it is an outside wall that had some humidity issues and I didn’t want to risk anything - although the underlying issues were rectified in the whole process of building this room. The materials used are calcium silicate boards, corresponding mineral based adhesive/plaster and mineral based silicate paint.
It has it‘s own electrical distribution panel that is fed from the main line.
Kind regards,
Olli
