Early Disston Hand Saws
the handle has a peculiar way of attaching to the blade. It has a single wing nut that goes all the way through. You can tell the wing nut has been there for a while due to the wear on the wood on the handle. The other flat head screw doesn't go all the way through the handle? I've never taken this apart to figure out how it stays in place?
This is part of a multi blade kit, keyhole, backsaw and regular saw blade I think. Loosen the wingnut, the other bolt is used as a pin. There is a slot in the blade that goes over the pin, and locks in
Start here and go down a page or more. I think the newer ones came without horns.
[https://archive.org/details/DisstonIllustratedTradePriceSheet1954/page/n2/mode/1up
These are a similar set, and where my thoughts of the slots and blade types came from
A
AntiqueBen
I forgot how cool this Aluminum handle Disston looks. It needs a good cleaning. Kinda unique for Disston?
A
AntiqueBen
According to my Google box it looks like Disston made this D-100 aluminum handle saw from 1961-66.
A
AntiqueBen
^ Bar Keeper's Friend if you want to keep that original finish. (examples)
Studebaker Avanti, eh? Does the blade fly out at over 120 mph?
Unfortunately she won't go 120 mph 😂
I cleaned up the blade and some BLO & she's ready to go...
A
AntiqueBen
I found a Disston rip saw (5 tpi) today for $10. It cleaned up good. Looks like it used to have the "nib" but it's broken off. I still need to get some paint off the handle, but overall, it's a user. Before & after pics below.
A
AntiqueBen
According to the Distonian Institute, it looks like this saw is an early 28" four screw D-12. The blade has no etching whatsoever, so now I'm confused. They only showed the earliest versions without an etching??
Distonian Institute link HERE
Mike'smeatshop
My mind is caught up on Champion for a few days but I had to show this saw that I have been trying to restore for a few months now but maybe someone can give more information. I have another but can't find it in all the mess. It is a Disston two hand saw from back in the day. I know I ruined it but I have another.
Commonly called a Thumb Hole Rip saw, as 90% of those handles seem to show up on rip saws, made for cutting wood the long way. If you are taking a 12' long board in half, that's a lot more work than cross cutting it to length.
The teeth are generally bigger, lower TPI than a crosscut, and filed differently. If you drop a needle, or tiny drill into the bottom of the gullet, it should lay perpendicular to the plate. On a crosscut, it should be 20⁰ angled to the plate, and tilted up or down a bit.
When ripping, there are two different conjectures on posture. One included standing almost vertical, and using the saw almost vertical in a push mode, with your fingers interlaced. The other was a more traditional stance, but I forget the left hand position.
With the rip cut, people have reported cutting 3" per stroke of the saw. Very aggressive in the right wood.
At first glance, I’d say yours is a D8, but verify it here. Could be a #8, the medallion will tell.
Mike'smeatshop
Yea, I think I found it to be a D8. But I got lost in other projects. Thanks, RMT. lol
Oregon Dave
I thought more two handed Disston saws would pop up. But I found my other saw which isn't in very good shape. Debating on restore or let it alone.DSCF8883.JPGDSCF8882.JPG
I vote for restoration; if for no other reason than practical experience with clamping and gluing to make those cracks disappear - if you need to!
Those incredibly cheap little super-glue tubes at Harbor; dental floss/tiny thread applicators???
If you do, please post your results & share the process - Thanks
Mike'smeatshop
I agree. And I have read through the article or one similar and completed a handle years ago. But back then it was very difficult matching the wood. But this world has come a long way since then. If the weather warms up I may try again.
Oregon Dave
Don't match it; choose something unique, that you like - brand it with your initial - make it look like you did it on purpose !!!
kwigly
Ontario
Would be fun to play with fixing the handle, but the blade might be another problem, It looks rusted through just below the handle ?
