Found a Snap-On 1/4” drive 3/8” power socket and locking shank together at an estate sale. The shank has a date code but no branding just like other 1/4 bits I’ve found.
PM-12 (1955)
A1043 (1951)
Wow, that shaft looks suspiciously like a Yankee push drill or ratcheting screwdriver bit, but those only came in 7/32 and 9/32, never 1/4". Is the shaft actually 1/4"?
HOF
Differences between the FN720 ratchet and the FN720A ratchet.
FN720 (1985)FN720A (1991)
One piece switchTwo piece switch
Flat gearDimpled gear
Old LogoNewer Logo
Roll stamp = Model, Snap-on, USARoll stamp = Snap-on, Model, USA
Gears = 20Gears = 20
HOF
I got this in the mail today. It was described as an 3/8" drive F7 (dated 1965). I figured it was an F710 or F710AK, but it only has F7 on it. Bad roll stamp is the only explanation I can come up with.
Farmer J.
UK, Cornwall/Hertfordshire.
I wonder how old that Torqometer is? Lovely tools, i'm a great fan of them. I have 2 of the more modern ones that came in plastic boxes a 1/2" and a 3/82 drive. The instructions with mine are the same except without the specs for the various car engines.
Fascinating reading, I spent a whole evening looking at them! I use a snap on extension with mine and do the calculation for higher torque stuff like flywheel bolts, will have to post a pic of it.
snapmom
Florida
Two of the older Torqometers
TQ-11 1/2dr from late 30s. The first Snap on
RT-250 9/32 dr. from the early 40s
I did some cleanup on some of my finds from Saturday yesterday. It was very difficult to use evaporust on the long rusty speeder. I think this is as good as it’s going to get.
Here is a 1941 listing for the 36” Ferret speeder I found on the collecting Snap-on site.IMG_8497.jpeg
The 3/8” drive extension I found recently had a noticeable bend so my neighbor and I used a vice with soft jaws along with a pipe and tire iron to apply enough brute force to mostly straighten it out.
Ayrhead
Ontario
This was one of the items I purchased yesterday. A Snap On 3/16 Carburetor Float Gauge…
Ayrhead
Ontario
A universal u-joint assembly tool…
Ayrhead
Ontario
A Bluepoint Vl-15 Valve Spring Compressor
Ayrhead
Ontario
Three Bluepoint Ratchet Style Ring Compressors
Ayrhead
Ontario
A Snap On Offset Wrench
Ayrhead
Ontario
A Snap On TK-419A Distributor Points Adjusting Tool
Ayrhead
Ontario
Three Valve Spring Keepers, 2 Snap On: a CF-7B, a CF-7 & a Sunnen
Ayrhead
Ontario
A Bluepoint CF-63 Brake Cylinder Hone w/ Extra Stones…
Snap-on WOEX-6A wrench SNAP091325 01.jpgSnap-on WOEX-6A wrench SNAP091325 02.jpg
Snap-on WOEX-6A British Standard Combination Wrench
Stamped "1/8W"
Since I do not work on British cars, this little gem is currently on its way to North Carolina where it can keep a lovely pair of Morgans in tip-top shape.
