Old tool guy
- Joined
- Apr 13, 2023
- Messages
- 3,307
Does your blade have a hole in the middle?
Yes, big hole in middle and small holes that keep it aligned with a pin at the bottom.Does your blade have a hole in the middle?
I don’t see the connection to my tool, unless it’s the swivel head.Old Tool Guy: It looks like the patent on your scraper refers to this "Tool Holder" patent by John and Clarence Lutz which is interesting because Lutz File Handles are well known. I didn't find a definite connection but it's likely the same Lutz.
Now that you mention that and i read closer, i think the key is lines 14-20 where it talks about various angles and easy tool changes.On line 13 of the written description it specifically mentions "scrapers or files".
Very slow response here, but I agree with the initial assessment, and glad you see it now.Now that you mention that and i read closer, i think the key is lines 14-20 where it talks about various angles and easy tool changes.
Subject: | patent 835160 Nov 6 1906 John W. Lutz and Clarence O. Lutz |
Date: | 2025-09-04 9:59 am |
To: | datamp.org, RTM, CRSINMICH |
Yes it is.Nice little plane.
That is a good looking plane. Send a picture of the adjustment if you get a chance. I haven't seen one of those before.Here is an Upson Nut / Standard Rule No. 35. Upson Nut merged with The Standard Rule Co. in 1888. In 1889, George Karrmann of Upson Nut patented and began manufacturing an "improvement in bench-planes", which was a lateral adjustment of the iron to provide a friction-slide for moving the iron by frictional contact only. Mine has different knobs (see photos) than you typically see with Upson Nut planes (not sure if they are earlier or later model), but they are very good looking. The plane is 9 3/4" long with a 2" wide iron.
Those brass knobs are definitely Standard Rule style.Here is an Upson Nut / Standard Rule No. 35. Upson Nut merged with The Standard Rule Co. in 1888. In 1889, George Karrmann of Upson Nut patented and began manufacturing an "improvement in bench-planes", which was a lateral adjustment of the iron to provide a friction-slide for moving the iron by frictional contact only. Mine has different knobs (see photos) than you typically see with Upson Nut planes (not sure if they are earlier or later model), but they are very good looking. The plane is 9 3/4" long with a 2" wide iron.
The patent pages are attached. My lateral even has the patent date marked on it. The right side friction pad was clipped off by a PO, but it still moves the iron properly.That is a good looking plane. Send a picture of the adjustment if you get a chance. I haven't seen one of those before.
Yes, here's the one I made. Not the most refined plane, but works great. It's made from black locust, which is a very hard wood and not easy to work with. The positive is that it is dense, so it has some weight.Toothing planes normally have their cutters set at a high angle, near vertical.
But isn’t Lee Valley selling a toothing blade for their 62 equivalent.Toothing planes normally have their cutters set at a high angle, near vertical.
Since that's not in collector condition, can you redrill and tap for a slightly larger screw? I don't know if brazing is harder or softer than welding, might be a consideration for breaking off a tap.Only problem is the threaded hole for the blade clamp, the break goes right through the hole, he ran an odd screw through the hole and peened over the end. I removed that, it’s still threaded but it’s just large enough that the threads don’t bite.
Brass/bronze brazing taps pretty easily--until it work hardens and then it doesn't.Since that's not in collector condition, can you redrill and tap for a slightly larger screw? I don't know if brazing is harder or softer than welding, might be a consideration for breaking off a tap.
Step up to a 12-28 or 1/4-28, depending on your selection of obscure taps and screws.The bronze didn’t get in the screw hole. A 10-28 screw threads in nicely, but when i try to finger tighten it, it slips.
Argh. I thought that was a hole for a depth stop. If you have a depth stop then you can buy or make your own wingnut or knurled screw to hold the depth stop in place. Just buy or make to match a tap again I'd try to stick to a matching thread pitch.
IMO, you're spending way too much time on a common plane with little value. If you want one like that, you could get a nice one for cheap.Found this Stanley 192 in a barn, the owner had a lot of stuff all over the yard and in 2 barns/storage buildings. He claimed to be an architectural salvage dealer, and I believed him. Fortunately the tools were in a shed. This looked good covered in dirt and rust in the dimly lit shed. Got it home and found otherwise. I don’t think he was covering up the condition intentionally, it was more of “here’s what i got, pick through it”.
Obviously it has led a rough life, frame has been brazed back together in 3 places. The owner did a pretty good job, everything lines up very straight. Only problem is the threaded hole for the blade clamp, the break goes right through the hole, he ran an odd screw through the hole and peened over the end. I removed that, it’s still threaded but it’s just large enough that the threads don’t bite.
I’m thinking I will clean it up, grind down the extra brazing, and apply a japan finish.
Picture of the blade, you can see the trademark stamp and the bimetal edge.![]()
Put it on Ebay. If everything there is in the pictures, it's not 100% complete.
yip that was everything in the boxPut it on Ebay. If everything there is in the pictures, it's not 100% complete.
Took your advice. Found this one, the blade is missing which is unfortunate becase there are differences in the two planes so this one is older, but without the trademark stamp on the blade i struggle to date it. The repaired plane has the last stamp style so that makes it after 1935. I’m going to put the blade in the older one, make a note of that, and the broken one will die a slow death covered in cobwebs.That's still a big nope for me.
Is that a no 40 in the middle? Nice clamps too.
