Is there a tools to remove this nut?
Oregon Dave
No Corded Power Tools just common sense yes 3 mm or 1/8 th if you like is a guess on my part for the slots
G
Homemade spanners have been suggested several times upthread; OP has been AWOL & no news about the 'Status of the Nut'.
I don't like to go off topic, but re: gibberish.
I was at Heathrow, having a drink at a bar; English bartender, Australian lady on the next stool. We had so many laughs when one would speak a word the other two had never heard of until it was spelled, then we recognized it - same mother tongue.
At a different time I walked up behind a club soccer game; did not recognize a single word being yelled.
BeerHippie probably wasn't being disrespectful; he just wasn't at the bar.
Most angle iron isn't hard enough to do that.
Files are real hard, maybe notching one the right size.🤣. Wear safety glasses when cutting or using, so when it grenades on you.🤓.
And no, just to be clear, in case the emojis weren't enough, don't do this. A file is hard, but VERY brittle.
Mintgrun
Kingston, Wa.
There's not much left of that crusty "nut" and it looks undersized compared to the wooden part, so I'd just slice into it and split it to get it off and then make a new one to go with the new wooden piece. Chances are, the threaded end of the shank has been hammered on and it will no longer spin off.
I'd just leave it as is and be content with owning a funky old tool that looks its age and is still capable of doing the work it was designed to do. (Making stuff look like-new again is overrated).
Shiftless
East Bay SFO
Congrats on your victory over a stuck fastener. We’ve all been there and done that. Maybe not a wrench like that but we all have our war stories.
BTW, you’ve got a nice looking Wilton bullet there !!
Oregon Dave
They're probably better and easier ways, but this is what I came up with. Sorry the pictures didn't post in the order I expected.
PXL_20251016_013618900.jpgPXL_20251016_014812595.jpgPXL_20251016_015639188.jpgPXL_20251016_020015725.jpg
Ingenious concept using the impact driver to break it loose; fine build on the adapter - de-nutted!
Shiftless
East Bay SFO
I was going to make one but the tapered bore is beyond my skill set.
Please don’t give up after all that work unscrewing the nut.
Consider making the handle in 2 pieces so you could wallow out the tapered bore aspect of the job by cutting a groove in each half. Fit the new handle and glue the halves together.
If you have a lathe, glue the 2 halves together after reaming out the tapered bore and turn your new handle into the appropriate shape. Sand it nice and smooth and finish with boiled linseed oil for a vintage look or gloss lacquer for a wow look.
Consider cocobolo or ebony or some other exotic hardwood if you want a real showpiece.
Have you considered trying to glue and clamp your original handle back together? Trying wouldn’t be much of a risk in its current condition. Here is one I glued. Not perfect but usable. IMG_8644.jpeg
It looks like your wrench may have been made by Bemis & Call.IMG_8643.jpegIMG_1433.jpeg
D
DRRummel
Baltimore, Maryland
I have wood glue, both yellow and clear. But I have seen repairs also done with UV resin. I like the idea of 5 second cure times.
What are your thoughts?
Thank you for finding the manufacturer. I was curious, but my Google image search was fruitless.
crguy
SW Washington
I was looking to buy a replacement last night but haven't found any options. I have found Ash handles for files. But nothing for a monkey wrench. I was going to make one but the tapered bore is beyond my skill set.
A round file would work fine for tapering the hole. Doesn't need to be a precision fit.
Jacko264
Kingston upon Hull uk
You could drill a hole though a handle and fill the hole with a resin / glue Sealer push the steel shaft into it and clean extra off
i am talking about a new handle
G
RoninB4
Under My House
-As others have suggested a split handle will allow you to create an exact fitment to the tang. It's a bit over the top but examine how the handle for Japanese swords are constructed, ray skin wrap optional. Epoxy or resorcinol glue will hold up well, a couple of copper rives will secure it to the tang or reuse the original nut. Handle material optional but several wood species look would look great and more like the original. Congratulations on the nut removal.
crguy
SW Washington
A split & glued handle will be ugly, just like the one pictured above. No need for that.
Beerhippie
Far NE Oregon
Done right, no one will ever know. Splitting the wood with the grain is the trick. It'll go back together with no visible seam.
How do you think Native Americans drilled out the foot-long stems of their ceremonial pipes? Flutes?
RoninB4
Under My House
-I disagree, if done properly only a thin line will be barely visible. I can't show you any of the handles I made for old Japanese swords as they're covered with ray skin (samegawa). The handle is for an adjustable wrench so how nice does it really need to look? Besides, fitment will be better than a circular hole and be more secure if the tool is used. JMO and you work however you want to.
KnurledNut
n/a
I'd run a belt sander or file across the bottom of that to break any peened edge, remove the old broken wood handle, clamp the nut in a vise with soft metal jaws and turn the wrench head with an adjustable wrench.
Edit: I completely missed there were two pages to this thread. I posted after reading only the first. Face palm.
The OP's solution looks like it worked well.
whateg01
doo dah, kansas, usa
...The handle is for an adjustable wrench so how nice does it really need to look?
How nice does a toolbox need to look? After all, is just a storage thing. Yet people spend a lot of effort keeping their toolboxes polished. Or a car? It's just transportation right? Why does that need to look nice? 🙄
Oregon Dave
Favor a round tapered rasp; OP has already demonstrated a degree of craftiness.
OP: Does taking a look inside; may have to clean it, of course; give you any clue how them lo' boys did it - pre-1900.
