Tool to Press Bearing into Sprocket
DesertG
Hi Guys, I don't have room for a floor press or I would buy one.
Is there another tool out there, so I can avoid the hammer and socket approach to removing and reinstalling.
Thank you
cgrutt
Pic would help. Bolt, nut and a few correctly sized washers might work. Or c-clamp. Just want to be careful how and where you press the bearing races.
D
DesertG
How big are we talking here?
I use something like THIS to install smaller bearings and it works great. Obviously, it isn't gonna handle a very large bearing.
Thank you! I am talking something like a 5 inch sprocket that has a 2.5 inch diameter bearing
D
DesertG
sprocket from a motorcycle
duneslider
Riverton, Utah
I've never had a motorcycle that had a sprocket with a bearing pressed in it. Is that some sort of idler, or tensioner?
Anyway, I have used a ball joint press and a couple pieces of 1/4" plate to press bearings into things.
MiteyF
Measure the interference. Usually proper bearing fits are basically a zero fit. AKA, heat the sprocket with a torch, and the bearing should fall right in.
txvwnut
Bedford, Texas
This right here. If you don't have a torch the stove or a hot plate will heat the sprocket just as easily.
FrankLee
seMI, 48317
I generally use an oven. I keep a small toaster oven in the shop just for things like this.
Yep, any of the above. I use the freeze/heat technique often. I use a light bulb:
imagineer
In the past, I used a drill press to press bushings and such. It just takes a little common sense to know when you're applying too much force and could possible damage the drill press.
I hear that a common fail is to use a bench vise, and then break a jaw. I wouldn’t try that unless your vise is disposable.
I would consider c clamps and metal plates as the strongest choice for things you might have on hand. Plates could be replace by angles if big enough.
mike93lx
Richmond, VA
If your vise breaks from this, it was junk to start with
Why would you expect a c clamp to be stronger than a bench vise?
goldtang
Western Australia
Thank you
I did a job for someone and ended up with a small 6 ton press that dose not take up to much room , light enough to drag around or lift on the bench ,
Grant Gunderson
Bellingham, WA
Bearings should always be pressed in with either an arbor press or a screw type press. IMG_5550.jpeg
I have a full set of specific bearing drifts for all of the smaller sizes. For larger bearings you can usually use the adapters out of a Ball Joint press kit. Sockets also work. I save the old bearings that I remove and then take them apart and save the outer races to use as drifts in the future.
99% of the time if a bearing is tough to press in you probably don’t have the alignment correct. In the kit above the bearing drifts and cups use the same ID to accept the screw so everything stays aligned with the cup that’s machined to align perfectly with the bore the bearing is going into.
You can make your own press with threaded rod some bits and grade 8 washers. Acme thread works best. A thirst bearing between the nut and the drift is nice too.
ohhimark
detroit
I moved my press outside, it's actually easier to access than it was when in the garage.
I don’t.
It’s cheaper, so if it breaks I’m less likely to give a flying fig.
Stolen idea from these threads, among many others here. Tribal knowledge / group think?
mike93lx
Richmond, VA
I don’t.
Pressing a bearing into a sprocket isn't the problem in those. It's abusing a tool. And if a vise fails from it, a c clamp would also either break or fail to complete the task from lack of leverage 🤷
Beerhippie
Far NE Oregon
Yeah, I've pressed quite a few bearings in and out using my cheap-*** Asian POS vise and an assortment of sockets.
(OK, that's a Jacobs chuck, but you get the idea)
I've never even felt that I was approaching the limits of the vise.
