Thank you! I am talking something like a 5 inch sprocket that has a 2.5 inch diameter bearingHow big are we talking here?
I use something like THIS to install smaller bearings and it works great. Obviously, it isn't gonna handle a very large bearing.
Pretty sure that's a starter spocket.I've never had a motorcycle that had a sprocket with a bearing pressed in it. Is that some sort of idler, or tensioner?
Anyway, I have used a ball joint press and a couple pieces of 1/4" plate to press bearings into things.
And an assortment of sockets.Bench vise
This right here. If you don't have a torch the stove or a hot plate will heat the sprocket just as easily.Measure the interference. Usually proper bearing fits are basically a zero fit. AKA, heat the sprocket with a torch, and the bearing should fall right in.
I generally use an oven. I keep a small toaster oven in the shop just for things like this.This right here. If you don't have a torch the stove or a hot plate will heat the sprocket just as easily.
AKA socket.Put the bearing in the freezer, and the sprocket in the oven. Use gloved hand to fit them. Could use a bearing seal driver to tap them together if they're tight.
Hi Guys, I don't have room for a floor press or I would buy one.
Is there another tool out there, so I can avoid the hammer and socket approach to removing and reinstalling.
This,I generally use an oven. I keep a small toaster oven in the shop just for things like this.
If your vise breaks from this, it was junk to start withI hear that a common fail is to use a bench vise, and then break a jaw. I wouldn’t try that unless your vise is disposable.
I would consider c clamps and metal plates as the strongest choice for things you might have on hand. Plates could be replace by angles if big enough.
Also handy for curing paint and warming lunch! If, that is, you don't mind lunch tasting a little like paint and grease.This,
A toaster oven was a required tool on the late 80’s GM 5 speed transaxles. I also used a toaster oven to install Cummins timing gears.
And ZF synchros
Or your paint tasting like lunchAlso handy for curing paint and warming lunch! If, that is, you don't mind lunch tasting a little like paint and grease.
I haven't eaten paint chips since they took the sweet, sweet lead out.Or your paint tasting like lunch
I did a job for someone and ended up with a small 6 ton press that dose not take up to much room , light enough to drag around or lift on the bench ,Hi Guys, I don't have room for a floor press or I would buy one.
Thank you
Can't argue with that
I don’t.If your vise breaks from this, it was junk to start with
Why would you expect a c clamp to be stronger than a bench vise?
Pressing a bearing into a sprocket isn't the problem in those. It's abusing a tool. And if a vise fails from it, a c clamp would also either break or fail to complete the task from lack of leverageI don’t.
It’s cheaper, so if it breaks I’m less likely to give a flying fig.
Stolen idea from these threads, among many others here. Tribal knowledge / group think?
I broke my vise today...
...and I'm sick that I was so stupid to let this happen. This is a family vise that came out of my dad's shop. I'm just sick now. I know it will never have the strength it had before but can cast be welded? I've heard that it can but maybe shouldn't in this type application. Are there any parts...www.garagejournal.com
Which is the stronger better vise- Wilton vs Yost
I picked up a like new Yost that I don't know any thing about. Don't know the age or model. It has 5" on the side and yes 5" jaws. My other vise is a Snap On branded Wilton 1750. 5" jaws as well, but a lot smaller. The Wilton is a little tighter and smoother, but both are nice. Wilton has...www.garagejournal.com
What would one have to do to break a large USA cast iron vise???
Just scrolling craigslist and saw yet another large vise, a Reed this time, which had been broken and the weld repair looks like catshite smeared on. Reed made TOUGH vises. but someone broke this one in half. Thinking about it, for sixty years, I've been in heavy industry, auto repair...www.garagejournal.com
help me out: Allied Bench Vise
The bench vise at our local charity work shop was broken this week. Any one have an Allied 5" moveable jaw? Or would someone be interested in welding this one as a repair project? No need to return it. We'll get another vise. I see many youtube videos on restoring bench vises and this could...www.garagejournal.com
The VISES of Garage Journal
I just finished restoring a small Wilton bullet vise. I machined a new set of 3” brass soft jaws for it on my Benchmaster milling machine. The fit was perfect and they came out pretty nice.www.garagejournal.com
Yeah, I've pressed quite a few bearings in and out using my cheap-*** Asian POS vise and an assortment of sockets.Pressing a bearing into a sprocket isn't the problem in those. It's abusing a tool. And if a vise fails from it, a c clamp would also either break or fail to complete the task from lack of leverage![]()
