Which Pass Thru/Go Through Sockets/Ratchets Swap/Interchange?
R
retDAC
near Huntsville, Ala.
Adding some knowledge to this database thread. I realize it's an old thread, but it is very detailed. I went ahead and purchased a GW 893823
The length of the ratchet at 12" is accurate. The ratchet is ~ 11.7 mm in overall thickness at head, not including the directional switch.
10 mm, 11 mm, 12 mm, 13 mm, 14 mm, 15 mm, 16 mm, 17 mm, 3/8 ", 7/16 ", 1/2 ", 9/16 ", 5/8 ", 11/16 " are ~ 32.0 mm in overall height.
18 mm is ~ 32.4 mm in overall height.
19 mm, 3/4 " is ~ 33.0 mm in overall height.
13/16 " is ~ 34.7 mm in overall height
7/8" is ~ 35.1 mm in overall height.
Thanks for the measurements. Every once in a while somebody needs them.
Ohio Andy
Columbus, Ohio
Sorry, I'm talking about the external drive interface, not the hex where the fastener goes.
Oh yes, sorry 12 point...
I was able to stick the socket quite handily into a 13 mm socket and also into a 1/2-in socket with no problem. And by that I mean a 12 point socket.
Also, an mt14 triple square fit into the ratchet itself... But that was a really sloppy fit.
Notice the detent, that holds that socket pretty firmly into the wrench
Ohio Andy
Columbus, Ohio
7 mm - 9 mm = 20.3 mm deep
10 mm - 11 mm = 21.6 mm deep
12 mm is 25.5 mm
qe mm is 27 mm
14 mm is 28.2 mm
1/4" bit socket with magnet is 28mm deep
5/16" and 11/32" is 21 mm deep
3/16" is 21.85 mm
7/16" and 1/2" are 25.75 mm deep
9/16" is 29.8 mm deep
