Show your "Long C" Craftsman!
Mintgrun
Kingston, Wa.
I recently shared this 102.01121 bandsaw I found on FB MP in the Heritage thread, but realized it fits better in this one, so I am sharing it here to show a few photos after washing it off. He was offering up two of them and I chose the older one (of course!). These are the photos from his ad.
That's the tire from the upper wheel wrapped around the tensioner. It's pretty much complete, aside from the covers' knobs. Unfortunately, it did not come with the fence.
I took it apart so it would fit in my little car and blew it out with compressed air when I got home, followed by some soapy water.
It's got a Sears Companion motor with a cool 'open-hinge' mount. I'm guessing that's all original. He said he connected power and it ran, but I haven't done that yet.
This one on the Vintage Machinery site shows an added 1" riser block under the tensioner that allows you to use 80" blades, since 78" is an odd size. I'd like to copy that detail (with shorter bolts).
Walker Turner sure made some nice tools back in the day.
Tom
Well... it's not marked with the "Long C" on the tool itself, but it does appear that way in the catalog illustration:
1939 Craftsman catalog pp 27 - hacksaws
This beauty was apparently manufactured between 1939 and 1942, and sports a production code of "BB". While not cited in Lauver's list, it looks like the likely culprit would have been Stanley. GJ member @d42jeep's photos of the same Craftsman "Master Grip" side by side with a Millers Falls specimen makes it look like the original maker was Millers Falls, not Stanley.
This was not in the best condition when I found it, and required a bit of sprucing up:
Craftsman 9AC3558 "Master Grip" hacksaw
photos and description of restoration HERE
Smokeshow69
That’s a good find! It should hopefully do well on the bay!
^ We're going to find out.
It's a nice saw, but that old Lenox I found is a much better design and far more fun to use.
I was actually kind of surprised by the heft of this Craftsman unit - it is not your usual "lightweight adjustable frame".
^ The scales on yours are in much better condition than those I found in that ebay ad.
So.... it was Millers Falls who made that, eh? NOT Stanley, as one might assume from Lauver's list.
I'll have to make a couple edits.
Thanks. BK
I don’t recall the original version of the list, but I copied it into my inventory spreadsheet. Mine says
BBPlanes by Millers Falls, possibly Hacksaws too
But that could be my edit, because I have several Craftsman by Millers Falls planes marked with BB, and probably saw Don’s hacksaw.
O
My BB tag note I added long ago and reads:
BB = Stanley, ca. 1939 - 1950 (This code only found on amber handled flat blade style screwdrivers, and a block plane; phillips screwdrivers of this same style and time period were found to have the I-circle code) - Note I-circle = Parker Mfg Co
I don't have other Stanley codes that are not clearly noted as acquisitions by Stanley...
I just added: BB Also found on Millers Falls made Amber handle hack saw - Long C period?
Are we certain its MF for these saws?
I list MF as:
F-circle = Millers Falls
^ I think that Don's example clinches it as far as this unit goes. I just revised all my posts on this and the ebay listing as well.
I can't see how one could argue that it was NOT made by Millers Falls:
Gary Lauver's list shows "BB" as "Stanley", but only a few select items (slotted screwdrivers and a plane, but not Phillips)(how weird is that?) :headscrat
So you have to ask: why would Millers Falls need to outsource a saw? They were a primary supplier - they sold all kinds of stuff to Sears.
In my mind, it just does not logically follow that MF would outsource a saw from Stanley.
This post from the Hacksaws thread might throw a bit of shade on that statement
But I am certain about the planes, so a bit happier to expand, but that seems like a big one to use multiple OEMs for. Unlike BF, which is rumored to be Atkins hacksaws, Daido and KTC
Cruzan80
Denver, CO
I dont remember if it is a BB code, but I do have an early CM Phillips with patent information, which IIRC, was Bridgeport (based on the number).
So you think there's a possibility that both of Don's specimens were produced by Dreier Bros. (Dreier Bros. Inc., 7301 Woodlawn Ave., Chicago, IL) ?
Only way to confirm that would be to come up with an existing specimen with their name on it.
It seems like Millers Falls is likely to have started making those hacksaws around 1938 since they are marked “new”. Besides the upscale No. 84 they offered a less expensive No. 48 with the handles less fancy and riveted in place They offered both styles for a long time.IMG_0821.jpegIMG_0820.jpeg
I'd say that pretty much clinches it, no? :unsure:
Shape of scales on the MF model 84 is same/same as the Craftsman "Master Grip"
Cut-out hole at rear of handle is same shape on both the MF 84 and MF 48 as on the Craftsman "Master Grip".
Thickness of frame at rear is 3/16"
Only difference I am seeing is that Millers Falls isn't touting that fancy-schmantzy "polished nickel plated frame"
(Sears had better pitch men, obviously. ;) )
Sears did stuff like that with plane parts and chisels also. Plated parts that neither MF, Sandusky, or Stanley did natively. An easy tell when grabbing second hand, but not sure the tool works any better. I have a few examples.
^ So you think the Craftsman version was plated and the Millers Falls version was not plated?
Or that Millers Falls just didn't use the "polished nickel-plated frame" as part of their sales pitch?
:headscrat
O
There is a difference between polished nickle plated and just nickle plated. I'd guess the non Craftsman simply skipped polishing the metal before plating.
JonahBrown
I have never seen pictures of all four of these sets together so here goes. These are the 4 styles of large c-series sets I know of which have speeders. The bottom left is the first cantilever style with the short handle ratchet offered in 1932 and 1933. The second variation was likely introduced in late 1933 and shown in the early 1934 catalogs ( top left). The midget set received a separate case. The third and best known variation was the classic hip box (top right) introduced in late 1934 catalogs and possibly carried into early 1935 as stocks were replaced by BE. The least known style was the heavy duty flat box (bottom right) which was likely only offered for a short time period sometime in 1934 or 1935.1782519979300.jpeg
coachwash
Gulf Coast Texas
Got this Long C Craftsman 1/4 midget socket box at a goodwill. I would like to know pieces went in this set, so I can work on it. I would like to preserve what is left of the logo on the inside. Obviously the previous owner painted his name on both sides of the box. All responses are appreciated. IMG_7344.jpeg
