Between 485 & 705 SQ/FT 3rd time's a charm with a 3 car workshop
L
loganb
Omaha, NE
Changing spark plugs done....and based on the condition it wasn't really necessary
But I now know the condition and age...and it didn't take long so not a big waste
Just found out we are having a play date tomorrow though so now I need to go mow so the water jumpy can be setup so won't get to the plugs and distributor cap next as I had originally planned ...oh well
nicholam77
Minneapolis, MN
But $1,700 ish total on 3 days so doesn't ****. But it was 7 years of storing, totes etc and at least 200 hours the last couple of months as things were sorted, organized etc..... so not pure profit by any means
For sure worth it! $1,700 is a lot. Now you can use that as justification to use on something you want but don't need! That's what I do anyways...
Nice job on the trellises.
I always admire your ability to get out in the garage for a few hours here or there, and tackle something small or even incomplete. I often struggle to do that, but when you stack it up it amounts to getting things done!
zanyad
NE Ohio
I feel the same. During the week it seems that by the time the kids are down and I've got some time, it's nearly bedtime! Weekends always seem to have some sort of activity, too.
L
loganb
Omaha, NE
I like your style! Thanks for taking the time to comment while you dodge the Minnesota state bird I mean mosquitoes lol As this was wife's show...she did what she wanted to do with the money...being overly responsible she deposited it into the kids investment accounts lol ...how boring. But I did end up with some more sticks of 3/4" emt conduit for ceiling light additions! As if I needed another project to distract me lol
I've grown very "attached" to the fully conditioned, attached garage...I wasn't expecting getting it comfortable all the time would be this damn nice. Most of my weekday garage time is short increments ..10 minutes while cooking...an occasional 30 minutes if I went home over lunch etc. With a doorstop to hold the door to the garage open I can hear the kitchen timers, kids getting too rowdy etc so it works well for picking up ****, little organization projects etc. A couple nights a week I get 1 to 2 hours out there after kids are down, weekends may get a couple hours but are just as likely to be nothing depending on what else is happening. Recently the garage time has been maybe a little more "supported" as I've been working on the Nova family cruiser...not sure how long that will last. The list of incomplete projects is growing rapidly so I'm trying to get the Nova initial "work" done so can drive it more, shake out the other gremlins that come up and maybe figure out next steps on it. Kids enjoyed getting groceries and donuts in it on Sunday morning
On the topic of Nova....
Got spark plug wires swapped
Still need to do the tuneup on the HEI distributor
Got the dash pulled back apart to inspect speaker wiring, no loose connections found yet but the head unit was doing some weird stuff so going to reach out to their customer service. When it was on Bluetooth input but nothing playing on the phone, it was playing the last FM station listened to very softly. If the car was running I couldn't have heard it...so no solution there yet
View up underneath
Tonight I started in on the subframe bushings, there are 3 on each side tieing together the front subframe to the body and they appeared to be original.
The kit from Energy Suspension
The rear one shown inside the end of the subframe tube
Appear to be original once I got them out. They at least have Chevrolet in the rubber bushing so if not original at least OEM
The bolts came out shockingly easy...I had hit them a couple times with PB Blaster but was expecting a fight...didn't happen. Rear and middle swapped well. Had more issues with the front/radiator core support one, but eventually got the passenger side done, torqued and back on the ground. See if I can get the drivers side going tomorrow after I drill out a washer as they shorted me one for the 5/8 bolts and gave an extra for the 1/2. If they weren't 2.5" OD I would just buy another washer but don't feel like finding those locally
madison069
Monroeville, PA
Yeah, little nervous about this as they were pretty worn. Going to deal with it once both sides are replaced... Not excited about hanging to tweak those big ole doors
If you do have to adjust the door, use a floor jack with lots of towels to cushion the lift point for paint reason. Or you could use a cherry picker with a strap, but I would opt for the floor jack and trying to lift the door behind the lip, use 2x4 to spread the load and lots of towels on the contact points. But, if the body panels haven't been touched after the bushing were worn out, then you will just probably notice the door closing better and the fender lining up better.
L
loganb
Omaha, NE
When you're "volun-told" that you're cutting down some vent/louvers for toe kicks on your wife's day job project and forget to do it until she reminds you the night before at 10:15....you get to get up early to do it
Angle grinder, M12 bandfile and some white paint and they're ready for install...well once the paint dries
And this is all of course purely hypothetical as husbands never forget anything added to their to do list
L
loganb
Omaha, NE
Finished driver's side yesterday, went a little faster but the radiator support was still the worst.
Had to drill out the provided washer for the larger 5/8" bolts on the rear two...easy peasy
These bushings didn't owe the car anything
Next up is hopefully engine and ****** fluid(including new pan with drain) then radiator hoses, heater hoses and coolant. Still have lots of paint correcting & polishing to do as well
L
loganb
Omaha, NE
****** pan off, fluid looks good. Turns out this pan did have a drain plug but the new pan is shiny so it will go on lol. Ordered an external seal/gasket kit to replace the easy to access ones with the pan off.
Valvoline VR1 shows up in the morning cause I couldn't find it locally, if i'm smart I'll take tomorrow off work and work on projects.... so I'm probably at work
L
loganb
Omaha, NE
I need to do the annual service on the Z28, Mach 1, and '49, thanks for the reminder!
Nothing wrong with a new pan, probably worth 5hp ;)
If it's that easy maybe I'll replace engine oil pan and get 10 extra hp!
Gasket seal kit for the ****** won't be here for a couple days so I'll get things cleaned up, filter changed and new pan in place to keep it clean and get it off the jackstands and probably go back to paint correcting and the other things on the never ending list. At least knowing in my head it's not driveable takes a bit of pressure off me to get it out this weekend.
L
loganb
Omaha, NE
Little attempt at progress before the activities today
v0 of a center console cupholder/phone holder project
Some rough sketches on the initial concept, somewhat influenced by some online images of other projects. Must have's include cupholders, cubby/holder for phones to drop into. After that integration of gauges, USB charging, switches etc is all fun stuff. There is a steering column mounted tach then coolant and oil pressure gauges under the ashtray I'd like to integrate into this. Long term plan is it would be basically permanently mounted but any wiring would be setup with bulkhead fittings and quick connects to allow removal
3d model of v0 with the bare necessities
cupholder inserts bought online, cutouts in the back are for some 3d printed pockets for phone and other small "stuff". It's a total of 5" tall and the cupholders are 3" deep or so which leads to space for a future iteration to have a pull out drawer in the bottom for additional storage etc
430 grams of Schoolhouse Spools finest PETG....set it pretty slow as we'll be out and about so when it finished really didn't matter. Thought about only printing the bottom that fits the driveshaft tunnel but I wasn't going to be able to make a revision on it before we left so just sending it and will incorporate several likely revisions in the next print.
madison069
Monroeville, PA
While it looks nice as is, could you round the edges? From the photo, the nova interior is all soft round edges and I wonder if the console would fit in better visually? Or are you planning to wrap it and soften the edges?
L
loganb
Omaha, NE
Agreed, whatever the final iteration is needs rounded or softened corners ...how that gets accomplished is still up for debate and likely multiple revisions
L
loganb
Omaha, NE
Both radiator hoses replaced...each needed some trimming but not a surprise
Have heater core hoses off....very tempted to go ahead and do heater core at the same time as it may be original. There is one at Speedway in Lincoln I could have tomorrow if I pick it up
Banged my head against the auto parts retail counter trying to get a basic metal fuel filter replacement...standard 2" diameter with hose barb on each side. Sunday afternoon on a holiday weekend doesn't get you the more knowledgeable staff who can do things without the computer. Had wife and kids in the truck waiting so got home and found what I needed and will pick it up tomorrow.
OutlawDrifter
KS
Oh man...I went through that with an Oreillys store manager and a simple carb gasket between the carb and air cleaner.
Finally told him to grab the book off the back counter and I had the part number in 30 seconds 🤦🏼‍♂️.
I avoid that place like the plague, and generally have my part numbers called in and pulled before I head into town. It's so frustrating...and every high schooler that works there thinks they run a NASCAR engine building shop 😆
L
loganb
Omaha, NE
Someone underestimated how involved this would be...2 hours to get to this point, now I have to get the OEM sealant sealing the metal half to the fiber/plastic interior airbox apart
Didn't dawn on me until this weekend how lucky/spoiled I was growing up with a parts guy who actually knew how to use the books to find the right part. Now it helped that this was a small town shop and his computer system wasn't that great...but he was from the era before computers and the books was all you had and life was simpler
So far, I've actually had the best luck with the weekday/weeknight O'Reilly's guys. I may have to expand my reach of which parts stores I frequent....AutoZone just opened one near me and my 3 or 4 interactions there so far have failed to meet expectations, Advance doesn't have anything close though they do have a distribution center in town which can be picked up directly from which is nice. The nearby Napa crew doesn't seem much better than AutoZone and they seem to detest online orders though I've heard they don't get store sales credit for online pickups.
When I got the fuel filter this morning I was especially annoyed as what I needed was just hanging back there on a wall of similar "universal" parts off to the side behind the counter and had I noticed those yesterday I could've had it....but nope the guy behind the counter said "No metal fuel filters here" when he probably walks past it 2 dozen times a shift. Had it been critical I would've figured it out in store yesterday, but it wasn't and I knew I'd be back
And in the camp of "while I'm already there" parts changing....fan blower motor is buried behind the inner wheel well on the passenger side fender....since that wheel well is off that's getting replaced as well with a new one as I don't want to have to get back into there anytime soon.
L
loganb
Omaha, NE
Victory...well maybe
Going back together
Currently letting it sit so the sealant helping to seal the long sides to the mounting plate cures up before I make a mess of it.
Now to decide what to do with this blower motor that the vent hole is just a bit too small for the tube to go into
Getting the coolant work all done and buttoned up today now seems like an overly optimistic goal
L
loganb
Omaha, NE
Nova hasn't seen any attention in the last 2 days....damn other commitments
Did get a 25% off coupon from Harbor Freight on a single item....so I put it to the wisdom of the collective...what should i get?
Some things I've been thinking off:
Another hydraulic lift cart to put the planer on instead of being on the top of a Vidmar cabinet and way to high. Holdup for not buying it already...not sure where it gets parked but i'll find a spot
I don't really have a spot or a need for more tool cabinets
One of the new G2 ratchets....would need to be 1/2" drive, I've got plenty of 3/8" drive....but a nice 18" or 24" flex head 1/2" drive wouldn't be terrible...if they're worth it
What else am I missing?
madison069
Monroeville, PA
I'm saying the same thing Krfjkm, I didn't get a 25% coupon either!
I've been wanting to get a lift table for awhile now, but I would have to get rid of the plastic cart if I did. Not sure if I would have room for it all!
I remember hanging out at autozone with a buddy of mine in college scanning through the computer and catalogs. the computer was simple and ok as long as the data was kept up. But the catalog was able to provide dimensions and material type of items such as bearings and seals that you couldn't see on the computer. It was nice to have all of that info while learning about the EFI systems at the time.
L
loganb
Omaha, NE
Wai, I didn’t get a coupon… hmmmm.
All I can say is maybe spend less there? I don't go in their often....maybe buy something 3 or 4x a year from there...at least half of that is spurred by the coupons.....related....not sure?
I am really liking the hydraulic lift cart I got for the drum sander....haven't figured out yet where the planer cart would sit...but I think I have an idea
madison069
Monroeville, PA
I've always wondered how those flip top stations work in real life, the kind where they have two machines on a drum that rotates on an axis so one machine is on top while the other machine goes under. Is the rotation station steady enough to be used and easy to maneuver around the garage? I figured it would be a good solution to store machines in a smaller footprint but questions the useability of it all.
L
loganb
Omaha, NE
I've played with one at a neighbor's, it was well built and worked nicely. I think they're very viable when done right, with the right size of equipment on them....but my planer is too heavy and it's got an oil filled gearbox so not something I want to do with it. I have thought about it for the spindle sander on one side and a couple of bench grinder/sharpening station on the other.
legenddc
I made that one and it worked really well with the Ridgid spindle sander and Ridgid planer like in the picture. I've since replaced the planer and haven't screwed the new one down yet. I will try to raise the bottom shelf up so the drawer is more useful and everything is more stable.
Have you seen these planer brackets? I wonder if you could make something similar and put the planer on the hydraulic cart with the drum sander on top of the planer.
L
loganb
Omaha, NE
I've seen those but hadn't thought very hard about stacking machines....planer on bottom and a metal frame then drum sander on top would work.....
Would make changing blades on the planer a bit more time consuming but that might happen 1x or 2x a year....
Hum....
Xti04
I have one I built for my planer. The opposite side had a a 6x48 belt sander on it. I have not flipped it over to use the planer in years.
L
loganb
Omaha, NE
What the hell...let me show you the box...not what's in it. 16 demerits!
Lol
It's a boring box and not sure when the parts are going in.
New speedometer cable as getting a lot of jumping on the gauge, glove box insert, a dash vent louver...couple packs of trim screws maybe. Hopeful goal this weekend is get the blue beast running again....so finish radiator core reassembly, then finish the ****** new seal/gasket install.
OutlawDrifter
KS
Lol
A little MMO in the back of the speedometer sometimes helps. Cured my '79 K10 Bonanza of the "swiping mph indicator".
L
loganb
Omaha, NE
I'm told but haven't confirmed that was done last year and didn't help...so wanted the cable on hand for when the gauge cluster comes back out to hopefully cure it. The cable was pretty cheap...$30 something I believe so that helped me just order it to have it vs pull the gauges out several times while screwing with it
Uofime
Charleston SC
I know you want another project like you want another hole in your head, but probably ought to pop the cover off the cluster and see how sticky the mechanism is/ clean and properly lubricate it. One more while you’re in there. It’s got 50+year old grease that as gone sticky and hard.
L
loganb
Omaha, NE
Spot on in all regards! When the cable gets replaced it'll be time to clean and lube it all. I'm going to get this current round of "stuff" done and the speedo fix will be on the next round of things after it gets some more drive time!
Thanks for joining in!
L
loganb
Omaha, NE
Slow progress
Input shaft seal replaced
Hopefully that cures its leak...
New cast aluminum pan means magnet won't stick...so some black super glue fixed that
Had to do a bit of work to clean up the pan flange and get it flat. Went to install and found they sent M8 bolts...not 5/16-18 so not thrilled about that and the flange is too big to use the old hardware. So new order to Mcmaster for some stainless button head screws goes in tonight
