The vintage Blackhawk Thread
MR.X
Today’s flea set me back $2.00. T-12136 Needle Valve Adjusting Wrench (socket). From a 1939 Stromberg manual online. I think misidentified as a 29.
Fred Knox
Nor Cal
An early Blackhawk No. 2 socket set, ca. 1919-1921, courtesy of a GJ member trade. The sockets are each stamped with the fractional size plus the Arrowhead logo with "U.S.A." below. They have the flat machined top, characteristic of the earlier production. There are pinched tabs at each end to retain the slider. I love its hexagonal bar stock too. I plan on getting a replica of the inside label and keep it in the box free-floating, but will keep the original one attached.
toolnutz19
Hi Everyone, My friend Oldjacks has opened my eyes to the Black Hawk brand. I see some folks around here are partial to it too, so lets see your vintage Black hawk tools. jacks, Tool Boxes, nugget sets. I will start with a SJ-18 jack gifted to me by Oldjacks. I will post my ratchets soon.
I have this vintage jack that I was trying to identify. It's similar to all the images I find with the rectangular lift pad and the light. Where it seems to differ is instead of the embossed lines on the side, it has "Blackhawk " embossed. Any ideas?
Thanks
nz44tool
New Britain CT
Interesting day at the flea market...
A Blackhawk 49996 1/2" drive ratchet in working condition!
A Mayhew 30200 mason's chisel
A mystery screwdriver (which I thought might be a Mayhew at first), stamped with a "5" and "Beta-Garantie"
- upon further review (after a little clean-up) - the screwdriver stamp says "Geta-Garantie". Still inscrutable. Anyone?
Mintgrun
Kingston, Wa.
I posted two of these jack stands in this thread five years ago and yesterday I purchased two more at the same Habitat store. They wanted twice as much money this time around, but I'm happy to have a set of four. I'll make plywood bases for the new two too, since I use them on gravel, or soft plywood on dirt (carport floor).
I think the first pair are newer, based on the labels, but haven't looked at catalogs to compare part numbers. I'm guessing the AX-2 turned into AX-20 and then 67368. I find it interesting that the first pair are rated for 2 tons each, whereas the other two say 2 tons (pair). Yet, they're basically identical in terms of construction. Regardless, they're plenty stout to suit my needs.
Tom
hydromanx25
I just found this site. I have 50 years in the jack repair business and have a lot of old parts. I am retired now but dug out my vintage jacks to rebuild them. Here is a couple of pictures
y'sguy
Tulsa, Oklahoma
Welcome. There are plenty of folks here who need advice on all the hydraulic equipment. You will be a good asset to the group.
MR.X
Stopped near Cleveland and ran into that seller that’s at every flea who wants to tell you that Williams is Snap-On. I’m almost afraid to say it here afraid that some one will say Williams IS Snap On. I had to ask if anyone has EVER paid Snap On prices for his common Williams non Snap on affiliated mid century tools. Anyway, picked up these 7/16 drive sockets and moved on.
thehorse13
Jefferson County, WV
One of the best things you can ever find is someone who has brand blinders on. They will overprice the object of their affection and give away things that are worth twice as much. Case in point, you have a few nice Blackhawk sockets in your palm. :) Well done.
I speared the first of these wartime button-release three-groovers out of a big miscellaneous mess of rust, woe, and dismemberment that someone dumped on a $1 table at the flea yesterday. You guys know what happens next. Spent the next ten or fifteen minutes going through it more surgically and methodically with the same screwdriver, and then doing it again just in case I missed one, and came up with the others. Disappointed there weren't more, but a decent grouping, including a deep, which surprised me. Not in the greatest condition, but three of them (40125 - 25/32", 40116 - 1/2", and 40112 - 3/8") are dated coded 1942, the deep (40318 - 9/16") is date coded 1943 and the 40126 - 13/16" is dated code 1944. The odds that they arrived in someone's grandfather's garage box separately? Low, sez I.
thehorse13
This 1920s QD box has been laying around my garage for many years. Because I'm not looking to start another large project, I figured that this little box would be fun to clean up. The decal is in nice shape so my plan was to cleanup everything around the entire box, remove and pop the spring back into place on the one spring loaded latch, then give it a lick of black satin paint. Easy right?
Well you know what they say about plans and this is no different.
I first tried feeling around inside of the latch looking for any obvious groove that the flat spring may have simply popped out from. No dice on that avenue, so I decided it was time to open the latch up and see what's really going on inside. The worst case scenario was apparent the second I opened the 3 tabs holding the latch together. You can see that the spring is broken in half. For a second, I thought about just making another one but before I do that, I figured that I would see if anyone has one of these spring loaded Blackhawk latches laying around that they would be willing to sell.
MR.X
Reading some posts on the vintage SnapOn thread about whether a handle on a driver was outsourced from another Milwaukee company reminded me of this old Walker (Racine about 25 miles from Milwaukee)jack crank handle utilizing the Blackhawk / American Grinder Mfg Co. sheet metal handle / grip patent. On the speeder shown the grip has a crimped metal cap that was also in the patent. As most of you know these grips are found on 20’s era Blackhawk braces, crank speeders, T-handles and extensions and even socket case handles. Interesting that the American Grinder patent was coauthored by the guy who founded Frickin Delta Machinery as Delta Specialty Co. “in his one car garage in 1919.
y'sguy
Tulsa, Oklahoma
I don't have a latch like that, but I have found that I could make a flat steel spring from an older-style stainless steel radiator clamp. You can cut and trim and shape one to the desired fit. Your results may vary.
