Who makes good flush cutters?
Sparky Six Axis
In all my years I've never owned a good set of flush cutters for cutting zip ties. They either break or the tips bend and stop cutting. Oh and they all are locked open so when you grab them in your bag they fillet your fingers and make you bleed.
I've been carrying the milwaukee version for awhile and they haven't broke, but they don't lock closed.
mike93lx
Richmond, VA
I have a bunch of the kleins and have been happy with all of them. They're also great for cleaning up supports on 3d prints
ecotec
I got the Knipex ones recently, and they have been great so far.
whateg01
doo dah, kansas, usa
I keep buying them for like $5/10 (probably not actually that cheap) on Amazon. No name stuff that cuts zip ties easily. I have a set of Milwaukee that I damaged trying to cut what I thought was copper wire but turned out not to be. So I buy the cheap ones now and when they get lost, I don't cry over them. How do y'all damage them cutting zip ties?
YesIHaveAHammer
These electronics nippers people are using are designed to cut copper wire.
Copper is a soft metal that is sheared by the blade.
Plastic cable ties on the other hand being nylon, are flexible and compress during the cut, needing more force, which is eventually released in a snap when it finally cuts through.
On the left is the Super Knips XL, recommended for all but small cable ties.
Hakeem
Chicago
I had the Tsunodas and they were nice but didn’t leave quite as flush of a cut as other flush cutters. They had a slight bevel on the “flush” side which keeps it from leaving a completely smooth cut.
The Icon set has been great for me along with the Snapon combo flush/diagonal cutters
whateg01
Cutting a zip tie that is heavier than your cutter should handle.
I guess I'm doing something wrong then, because I have some that only ever get used to cut zip ties off of my transit cases when they get to their destination.
These side cutters don't shear anything. They aren't shears. They cut through copper wire the same way they cut through zip ties.
I must be using mine wrong since they still work for cutting zip ties.
YesIHaveAHammer
Granted.
As per the rest of what I said, it seems to me there is more "pushing through" and load-up of pressure occurring when cutting a cable tie, than with thin copper wire.
It could be...
  • you're not cutting too big cable ties, or especially high grade ones
  • you are careful to seat the tie near the base of the jaw
  • your cutter's tips are not too narrow or optimised for confined spaces
YesIHaveAHammer
I can't find this video on YouTube, but you don't need to log in anyway
At 1:04, he says the standard 125mm is fine for up to 2.5mm (halfway between 1/16" and 1/8") ties.
I'm sure they'd also be fine on 4.5mm (halfway between 1/8" and 3/16"), but might need care with your hand force and where you place in the jaw, and a bit of luck if you're doing hundreds.
YesIHaveAHammer
Knipex: What do you use to cut cable ties flush?
Cable ties are usually made of high-quality plastics, which have high tearing forces. When they are cut off with pliers, high frictional forces therefore arise between the plastic of the cable tie and the steel of the cutting edge of the pliers.
The wider and thicker the cable tie, the greater these forces become.
The surface of the cutting edges and their wedge angle also have a major influence on the cutting forces that are generated.
models come close to their load limit when cutting cable ties, especially with wide cable ties, but also when cutting with a fast cutting motion: the speed increases friction.
None of this is specific to Knipex of course, just they are the ones talking about it.
Two Speed
Ontario Canada
I got a set of channel lock flush cutters for work, used daily, forget how long, but I ended up with a handle snapping on them mid job. Overall I was satisfied with them, but don't cut electrical cords with them, I suspect that hastened their demise. #758. Being mid job I saw milwaulkee "flush cutters" at the one of the larger hardware stores, and despite my personal distaste and anti-milwaulkee products I thought I'd give them a chance, biggest regret and mistake. They are NOT flush cutters despite the package declaring FLUSH cut. Don't belive the package, and of course they are packaged so you can't inspect the cutter end. **** milwaulkee and their **** tier products. All of it. ALL OF IT. Never again. I swore of milwaukee garbage years ago (smoke let out of two drills, drill chucks that didn't stay tightened and refused warranty on them.Did I mention, **** milwaukee? No? **** 'em sideways with a splintered bat. Ended up spending some time with the grinder and having to turn them into flush cutters.
NoahG
Detroit, MI
Sparky Six Axis
I've had a Snap On set for ~20 years. Well, 2nd set, an employee used the 1st on wire and ruined it.
Nothing worse than someone wrecking your tools. I've had people use my tools to cut hardened steel. Kleins, dikes and cable cutters are only for copper or aluminum.
ecotec
D-2000 Klein Linesman’s and diagonals can cut a lot more than that. IMG_5924.jpegIMG_5925.jpeg
infinite97
Vancouver, WA
I’ve never liked that little flimsy style of flush cutter. I use these knipex.
ecotec
I'm well aware. But they stay sharper if you don't cut 1/4" allthread with them.
You're the guy who borrows someone Kleins to cut a fish tape LOL Someone ban this guy.
If I didn’t have my name on almost every tool, I would post a picture of my Veto. I almost never have to borrow anything that is not contractor provided.
Your Linesman’s are safe from me, man.
I can’t remember the last time I used any 1/4” threaded rod… hell, it’s been ages since I used 3/8” threaded rod. We use 1/2”. But, if I had to cut some 1/4” threaded rod, I would use a portaband.
redwrench60
East Tennessee
I agree 100%. I can’t stand those pitiful little stamped steel crappers from ANY company. None of them will even cut cleanly all the way at the back of the cutter throat.
Aside from a dedicated zip tie tensioner/cutter tool, those Knipex are the best I’ve used and I cut thousands and thousands of zip ties at a previous job. Like, we scooped up zip tie tags with a snow shovel after a project.
Sparky Six Axis
I really enjoy Amazon reviews. Just about every product has 1 star reviews from midwits who don't understand the product.
People think all tools can cut steel. So silly.
whateg01
Not everybody understands the differences in metal. I helped somebody who was "taught to weld" and was trying to do some artwork stuff. She could not figure out why the stainless steel spoon she found would not stick to the decorative things she had found that turned out to be made of pot metal. I suppose it's really no different than somebody coming from the metal shop and going into the textiles area trying to cut silk with the scissors from the junk drawer.
Sparky Six Axis
I have a pair of nice sewing scissors and I beg my wife not to use them for plastic but she doesn't listen. She also uses my expensive cooking scissors for cutting plastic. Kills me everytime
Maybe I'm a tool Nazi. Tools last longer if they aren't abused.
Hakeem
Chicago
I messed the cutters on my linemans up by cutting drywall screws. Emailed Klein and they specified “machine screws”. A bit misleading in my opinion.
