Who makes good flush cutters?
In all my years I've never owned a good set of flush cutters for cutting zip ties. They either break or the tips bend and stop cutting. Oh and they all are locked open so when you grab them in your bag they fillet your fingers and make you bleed.
I've been carrying the milwaukee version for awhile and they haven't broke, but they don't lock closed.
Madjik Man
The Tsunoda KBNs are amazing. I also have the TH-150NC which is a flush cut and catcher. No more flying cut pieces.
whateg01
doo dah, kansas, usa
I keep buying them for like $5/10 (probably not actually that cheap) on Amazon. No name stuff that cuts zip ties easily. I have a set of Milwaukee that I damaged trying to cut what I thought was copper wire but turned out not to be. So I buy the cheap ones now and when they get lost, I don't cry over them. How do y'all damage them cutting zip ties?
YesIHaveAHammer
These electronics nippers people are using are designed to cut copper wire.
Copper is a soft metal that is sheared by the blade.
Plastic cable ties on the other hand being nylon, are flexible and compress during the cut, needing more force, which is eventually released in a snap when it finally cuts through.
On the left is the Super Knips XL, recommended for all but small cable ties.
Hakeem
Chicago
I had the Tsunodas and they were nice but didn’t leave quite as flush of a cut as other flush cutters. They had a slight bevel on the “flush” side which keeps it from leaving a completely smooth cut.
The Icon set has been great for me along with the Snapon combo flush/diagonal cutters
whateg01
Cutting a zip tie that is heavier than your cutter should handle.
I guess I'm doing something wrong then, because I have some that only ever get used to cut zip ties off of my transit cases when they get to their destination.
These side cutters don't shear anything. They aren't shears. They cut through copper wire the same way they cut through zip ties.
I must be using mine wrong since they still work for cutting zip ties.
YesIHaveAHammer
Granted.
As per the rest of what I said, it seems to me there is more "pushing through" and load-up of pressure occurring when cutting a cable tie, than with thin copper wire.
It could be...
  • you're not cutting too big cable ties, or especially high grade ones
  • you are careful to seat the tie near the base of the jaw
  • your cutter's tips are not too narrow or optimised for confined spaces
YesIHaveAHammer
I can't find this video on YouTube, but you don't need to log in anyway
At 1:04, he says the standard 125mm is fine for up to 2.5mm (halfway between 1/16" and 1/8") ties.
I'm sure they'd also be fine on 4.5mm (halfway between 1/8" and 3/16"), but might need care with your hand force and where you place in the jaw, and a bit of luck if you're doing hundreds.
