Larry, I have done rebar rails before, probably will do 1-1/4" pipe this time around. (1.66"OD) with either **** welded elbows or Kee fittings.So are the stair graspable handrails gonna be rebar?
Code indicates #10 (1.25" diameter) thru #16 (2" diameter) would suffice...
I built that big antler lamp 20+ years ago out of elk and mule deer sheds I picked up on the ranch in Wyoming and whitetail sheds from Washington, Idaho and Missouri. The wiring is completely hidden, it runs inside the antlers. Used a tomato cage for the form, cut it out after all the antlers were screwed together.Ya-Ya-Yaaaaaa, looks good Scott.........but once again where's the damn rebar??
You know a real man of your creativity would $hitcan the deer antler lamp and create a faux deer antler lamp out of rebar.....that way you stay compliant with the Basis of Design.
Look, I’m not trying to discount your younger hornier years by any means.I built that big antler lamp 20+ years ago out of elk and mule deer sheds I picked up on the ranch in Wyoming and whitetail sheds from Washington, Idaho and Missouri. The wiring is completely hidden, it runs inside the antlers. Used a tomato cage for the form, cut it out after all the antlers were screwed together.
Rebar probably would have been easier.
I sure hope you're right. We elected to go-ahead and replace the gas furnace section as well as the AC condensor/ air handler, since it was also 17 years old- and is located in the crawl space at the opposite end of the house from the access door. 70'+ of bent over crab walk for access. Not a pleasant service call.Well, that's something you shouldn't have to worry about for some time. And I'm sure it's going to work a whole helluva lot better than the previous set-up.
Damn you @larry4406 you just made me add something on Ricky's list of needs/wants....Nice fab! Sharp looking design.
Those hitch extenders are very handy. I have an Ericson Big Bed Senior Extender. It folds up nice and the carry handle is properly placed to balance the unit.
I knew you knew what you were doing!That's why I used it, Dan.![]()
Mike, I finished them up 24 hours after I picked up the steel. (including knocking off at 4:00PM to shower before going out to dinner with friends) on Tuesday . Fabrication was very simple-, I capped the end of the 1.5 x 3 rtubing with some 14 gauge sheet stock, used simple, **** joints on the frames, already had the weld tabs. The welded wire took longer to fit and weld than the frames. We were only in Phoenix for a couple of days so I had to hustle and get them done. Ground the frame welds flush witha nice new Walter 36 grit flap disc (thanks @LXCam ), then gave them a quick once-over with an old 120 grit flap disc. Satin black powder coat hides a lot of evil...Scott, you sure made short work of those railings. You need to come by my place, my wife has been on me to make a handrail for the front porch of our house and although it's been on my "to do" list, it has been relatively low on that list. That is until I watched my older brother come up our front steps the other day when he was dropping off some produce and saw him struggle getting back down them as his balance is not the greatest lately. My FIL also struggles going up and down our front steps so my wife usually has him come in through our garage where we have handrails.
The wife and I discussed at dinner the other night that winter is right around the corner and I have a lot of personal projects that I have been putting off and she suggested maybe I put a hold on taking on side work for a bit until I get our stuff caught up. I think she may be right, so I need to make a materials list and get some steel ordered. Your work is inspiring.
Damn you @larry4406 you just made me add something on Ricky's list of needs/wants....![]()
The doors are insulated, Sterling. They're flush woodgrain steel faced, vinyl wrapped foam back. Wayne Dalton 9100 Series.I noticed that the garage doors in your new shop are not insulated. Are you planning on adding insulation or not a concern. Do those doors face north so no direct sunlight (blast furnace effect) to deal with? Your railings look great and I’m going to steal the cattle panel for a fence I want to build for a orchard yard to keep the deer and javelina out of it.
I'm at 1200 sq ft with 12' ceilings, stick framed. One long wall and one short wall insulated. Other short wall has an insulated 20' garage door and other long wall has a lean to. Bonus room overhead that's insulated and conditioned and insulation in the ceiling. Running a 24k btu Mr. Cool mini and it seems to keep up pretty well. Struggles a bit on the hottest days of the summer but still keeps it under 78. (normal set point in summer is 75)I want to put two mini splits into my shop when I can afford it. Over the last month or two it’ll get up to high 80’s low 90’s towards the afternoon. It would be nice to not be uncomfortable while working, and it’ll be nice to have the heat available in the winter. Any recommendations for my 4990 sq ft shop as to mini split sizing?
I had 50' of 16-3 cord that is very flexible and doesn't seem to have a memory. The splice is (allegedly)
I got tired of dragging out an extension cord every time I use my Makita sliding compound miter saw. The factory cord was coming apart, I have been patching it with electrical tape, both liquid and from a roll. I didn't feel like pulling the saw structure apart to rewire it. The first foot or so of the cord was still good, so I spliced it with an inline connector and put a 50' cord on it.
