Craftsman Drill Press
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Part 3, Cleaning Painted Parts
full
  1. Vacuum any sawdust still on any parts.
    full
    full
  2. Scrub all painted parts with Grez-Off and small brushes.
    full
  3. Use Barkeepers Friend if lightly rusted.
    full
  4. Rinse and dry.
    full
  5. Apply paste wax to all painted parts and buff.
    The end frame on the left is waxed, the frame on the right is not.
    full
  6. Drill through and continue to tap the female threads through the end frame for the centrifugal machine screws.
    This will aid in reassembly later.
    full
    full
  7. Run a tap through all threaded holes to clean out any dirt and swarf.
    full
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Part 4, Cleaning the Stator Cover Band
This stator cover band has some light to moderate rust.
  1. Scrub the band with Grez-Off and a small brush, rinse and dry.
    full
    full
    full
  2. Bump out any dents.
    This band has a small dent near the switch.
    full
  3. Mark the dent and draw cross-hairs.
    full
    full
  4. Set-up the band and hammers.
    I used an old mouse pad because it has some give underneath the band. I use a convex-faced body hammer on the dent centered on the cross-hairs. Another hammer is used to strike the body hammer.
    full
    A couple whacks worked well.
    full
  5. Bend open the four folds on ends and loosely connect the ends together.
    full
    full
  6. Insert the band in a bucket, mix-up some citric acid, fill a gallon jug with hot water and pour in the citric acid.
    full
    full
    full
  7. After an hour or so, pull the band out and lightly scrub with #0000 steel wool and the citric acid.
    full
    full
  8. Rinse, dry and wax.
    Far from perfect, but more than acceptable to me.
    full
Once again, very nice documentation work Frank.
One comment on the hammers; never strike two hardened steel hammers together. For the striking hammer a lead or brass hammer plastic face or even a hardwood hammer should be used.,
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Part 5, Cleaning the Small Parts
full
There are a variety of small parts in this motor. Most will get sonic cleaned.
  1. Place all small parts in a jar and run them in the sonic cleaner for a couple rounds. Bearings will get cleaned separately
    full
  2. After sonic cleaning, wire wheel the screw heads and bearing plates.
    full
  3. Wire wheel the acorn nuts and threads of the thru-bolts. Clean the rods with steel wool.
    These were not rusted enough to warrant an acid bath.
    full
    full
  4. Flatten any dents in the motor badge.
    full
    full
  5. Clean the motor badge, the thermal switch badge and the ON/OFF plate with cleaner wax.
    full
    full
    full
    full
  6. Clean bearings separately with several cycles in the sonic cleaner.
    full
    full
    full
  7. When the bearings look clean, use fresh lacquer thinner for a couple more rounds.
    full
Beautiful! Zero axial play, zero radial play. These are going back in.
full
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Part 6, Assembly Prep
  1. Install the air cone into the fan-side end frame.
    full
    full
  2. Tap (4-40) the holes for the thermal switch badge and Install the badge with 4-40 screws.
    The holes do not need to be drilled.
    full
    full
    full
  3. Insert 8-32 x 1" set screws into the new thru-holes for the cent switch.
    full
  4. Install the switch shield and switch insulation. The set screws will hold them in place until the switch is installed.
    full
  5. Remove the remainder of the old cord.
    full
    full
    full
  6. Drill (#29) and tap (8-32) the base for a ground screw.
    full
    full
    full
    full
    full
  7. Insert a new grommet into the base.
    This grommet is a tight fit in the base and the cord will be a tight fit in the grommet.
    full
    full
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Part 7, Assembling Stator and Switch-Side End Frame
  1. Set the switch-side end frame adjacent to the stator and install the Klixon thermal switch.
    full
    full
  2. Set the centrifugal switch assembly inside the end frame.
    full
  3. Insert the screws into the terminal board and install the paper retaining washers onto the screws.
    The paper washers are not insulators. They simply hold the screws in place during assembly.
    full
  4. Loosen the nuts on the wire terminals.
    This allows some flexibility of the terminal board during assembly.
    Motor Assembly Jig
    Because of my unorthodox(?) method of dismantling and assembling these motors, I made this jig to aid in installing the terminal board into the end frame.
    The two outboard screws thread into the terminal box. The two inboard screws are loose in the cross bar and thread onto the wire terminals. This keeps the terminal board mounting screws aligned for installation.
    full
  5. Tilt up the end frame to the stator and install the inboard screws of the jig onto the terminal screws.
    full
  6. Install the outboard screws of the jig into the terminal box cover screw holes.
    full
    full
  7. Pull the two inboard screws of the jig and start the two terminal board mounting screws with a long cabinet screwdriver.
    full
    full
    full
  8. Remove the jig once the screws are started and tighten down the terminal board mounting screws.
  9. Tilt the end frame and stator up on end.
    full
  10. Observe and adjust the wiring.
    All wires should enter the base in the same opening.
    full
    full
  11. Adjust the stator on the end frame so the thru-bolt slots align with the end frame holes.
    full
  12. Install the centrifugal switch onto the set screws.
    full
    full
  13. Remove one of the set screws and install a cent switch mounting screw.
    full
    full
    full
  14. Remove the other set screw and install the other cent switch mounting screw.
    full
    full
    The switch side end frame is installed onto the stator. The original wiring is intact and in great shape.
  15. Set the stator/end frame assembly onto the motor jig with the bearing bore centered over the shaft bore in the jig.
    full
    full
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Part 8, Installing the Rotor and Fan-Side End Frame
  1. Heat one of the bearings for about five minutes and slide it onto the fan side of the rotor.
    full
    full
    full
  2. Insert the rotor into the stator.
    full
    full
  3. Install the fan-side end frame onto the rotor. and align the thru-bolt holes.
    Note that there are three "tabs" on the end frame. The tab above the vent hole is the top.
    full
    full
  4. Install an acorn nut on each thru-bolt and insert all through the assembly.
    full
    full
  5. Install the remaining acorn nuts and tighten.
    full
    full
  6. Flip the motor and install the motor jig onto the fan side.
    full
    full
  7. Heat the other bearing for five minutes and install on the switch side.
    full
    full
  8. Seat the bearing with a small pipe.
    full
    full
  9. Tighten the terminal nuts and install the terminal box cover.
    full
    full
  10. Remove the motor from the jig, set it on its side and spin the rotor to verify no hang-ups.
    full
    It's ready for a power test. I do this now in case I have to open the motor again.
  11. Carefully connect a temporary power cord.
    full
  12. Hold the motor firmly and flip on the switch for just a second.
    Note: The bearings are not yet lubricated, so it's much louder than it will be.
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Part 9, Installing the Stator Cover Band
So, this 3450 rpm motor seems to be an oddball. I would have expected it to be the same size as the 1750 rpm motor, but it is smaller. The rotor shaft is ~12" versus ~12-1/2". The rotor body, the stator and the stator cover band are all narrower, but the end frames appear to be the same size.
Below are some comparison photos of this 7556 band and my 6962 band.
full
full
Why does it matter?
Notice that the rivets on the 7556 band are closer to the edge of the band. The back of the rivets overlap and interfere with the tabs on the end frames. This means that the back side of the new blind rivets must be as flat as the original rivets.
full
full
  1. Remove the rivets from their nails and shorten them to ~3/32".
    full
  2. Attach the badge using the shortened rivets and pop out their nail heads.
    full
  3. Strike the back side of the rivets with a center punch to splay them open.
    full
    full
  4. Flatten the rivets with a pin punch.
    full
    full
  5. Place the motor in the center band with the wires routed and the badge oriented appropriately.
    full
  6. Hook the ends of the band together and center the opening of the band over the base bolt holes.
    full
  7. Flatten the fold-over tabs.
    full
    full
  8. Test fit the base to verify spacing and orientation.
    full
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Part 10, Installing the Base and Cord
  1. Lay the cord across the base to estimate the length required to reach the switch from the cord opening.
    full
  2. Strip off the outer casing of the cord.
    Apply a light coat of Super Lube grease in the grommet bore and on the end of the outer casing of the cord.
    Insert the wires and the end of the cord casing through the grommet.
    full
    full
    full
  3. Install a strain relief clamp or hog ring near the end of the cord casing.
    Pull out the cord to the clamp.
    full
    full
  4. Crimp a ring terminal onto the ground wire, route the wire to the grounding screw in the base and attach..
    full
  5. Feed the capacitor, the switch and the neutral wire through the opening in base and place the base on the stator.
    full
  6. Install and tighten the base bolts.
    full
  7. Attach the neutral wire from the cord to the green wire from the stator.
    The capacitor must lay on the four flats in the base. If using a wire nut, ensure that it does not interfere with the capacitor.
    full
  8. Solder the hot wire from the cord to the switch.
    full
  9. Insert the switch toggle through the base.
    full
  10. Install the capacitor and the bottom shield.
    full
    full
  11. Stand the motor upright and install the switch plate and nut.
    full
    full
  12. Power test the motor and wiring.
    Notice the very long run-down time. A long run-down time on a motor/grinder is usually an indication of dry bearings and not a good sign.
    Bearing Lubrication
  13. Start with the fan-side bearing.
    Press the rotor to recess the bearing.
    This allows the spring washer to be held in place.
    full
  14. Inject grease into the bearing between each ball.
    full
    full
  15. Install the spring washer, fiber gasket, bearing plate, felt washer, felt cover and four fillister head screws.
    full
    full
    full
  16. Flip the motor around to the switch side.
    The bearing is protruding a bit. It will get pressed in with the screws and compress the spring washer on the fan side.
    full
    full
  17. Install the fiber gasket, bearing plate, felt washer, felt cover and four fillister head screws.
    full
  18. Plug in the motor and test.
    Look for smoke, smell for overheating, feel for heat and listen for the click during shutdown.
    Notice the reduced noise and shorter run-down time. This is good!
    full
    full
    full
    full
F
FrankLee
seMI, 48317
Packard Craftsman Motor 115.7556 - Epilogue
There are many paths to the same destination. This series of posts showed the basic route I generally follow to refurbish these motors. There are other ways to accomplish the same objective. Simple jigs make tasks easier.
There were a couple unusual things with this motor:
  • the rotor slipped out of the switch side bearing before the fan side end frame slipped off the fan side bearing
  • the rotor, stator and stator cover band were narrower than other similar motors
Below are links to each post during the overhaul.
Part 1, Disassembly
Part 2, Cleaning the Stator and Rotor
One last thing...
In part 1, I mentioned that the insulation on this old motor wiring is very brittle and cracks/breaks very easily when bending.
In the video below, I show how it's possible to re-form the wire without damaging the insulation.
F
FrankLee
seMI, 48317
Dunlap Vise #5244
There are 100+ posts on GJ with search hits for "Dunlap 5244", so these vises are somewhat common.
Last week, I picked up this Dunlap vise #5244 for a quick project. I don't have much experience with bench vises, but I believe there were several versions of this model. This one has the separate badge attached with drive screws. I don't think this version had removable the pipe jaws.
The handle is straight and in very nice condition. It was missing the swivel lock and was somewhat abused.
full
full
The forcing screw was not meant to be removed. There were four staked points behind a steel sleeve that locked it into the dynamic jaw.
full
full
full
full
full
I used a Dremel with a stone bit to remove the stakes...
full
... and a brass punch to remove the forcing screw from the sleeve. The sleeve is a slip fit.
full
I then filed off the remaining high points from staking.
full
full
full
full
I cut slots in each drive screw and removed them with a screw driver.
full
The cast iron parts were soaked in Purple Power to strip the paint.
full
full
full
full
I drilled the drive screw hole through with a #41 bit and tapped 4-40 threads. I'll use machine screws to reattach the badge.
full
full
I made a new swivel lock with a carriage bolt and acorn nut.
full
The forcing screw is 5/8" diameter. The bore for the forcing screw in the dynamic jaw is ~3/4". That's a sloppy fit.
I had a few used flanged bushings that fit the screw and the bore perfectly. That should tighten things up a bit.
If too tight due to alignment issues with the nut, I'll cut the flange off to make a thrust washer.
full
full
full
full
The top of the jaws were beaten on badly and were mushroomed.
full
full
I made this jig to clean that up on the belt sander. I'll flip the jaws over so the bevel repairs are on the bottom.
full
full
full
The cast iron parts were soaked in citric acid to remove the rust. They were then wire wheeled and masked for painting.
full
The cast iron parts are primed. I'll let this cure for a couple days before top coating.
full
full
full
Pipe jaws were available as an accessory in the 1952 catalog. this and later catalogs had a similar vise as a Craftsman (and jaws) but a different model No.:
F
FrankLee
seMI, 48317
Dunlap Vise #5244, continued
I completed painting the Dunlap vise over the weekend.
full
full
Painting took several days, so when I removed the masking, I scraped the corners with a razor blade. This eliminates the possibility of paint peeling off with the tape.
full
full
full
full
The jaws are just slightly misaligned horizontally after flipping them over.
full
I ended up cutting off the bushing and used the flange as a thrust washer.
I used a retaining compound to secure the sleeve. I'm fairly certain it will hold up nicely.
full
I installed the base, greased the main screw and ...
full
full
... finished assembly it this morning.
full
full
full
full
F
FrankLee
seMI, 48317
The grinder is a 1/3 hp model 397.19580. I pulled it off the stand and the date on the bottom plate is AUG 11, 1969. Both eye shields glass are good and all rubber feet are present. The right tool rest was the only missing piece.
EDIT: Actually, the left tool rest is missing. They were installed incorrectly.
I removed the bottom plate, and... wtf!
What's wrong with this picture?
I cut the lamp cord, reconnected the hot wire, flipped on the power and it runs beautifully!
The goofy, very loose installation of the lamp accessory caused the hot lead to get pulled off the switch.
Was this worth the $15 I paid?
Hell yeah!
F
FrankLee
seMI, 48317
This morning, I tore down the grinder, cleaned and reassembled the motor portion.
The only real change I made was to redo the cord grommet. I replaced the plastic strain-relief grommet with a rubber grommet and hog ring. I had to slightly enlarge the grommet bore.
The previous owner replaced the original lamp with an 18-in. bench lamp accessory. He cut both the hot and neutral wires to install the lamp with wire nuts. There was a much easier way.
The neutral wire terminal on the relay and one of the switch terminals have double spade connectors for lamp wiring. The wiring can be configured so the lamp illuminates via the lamp switch or via the grinder switch.
I believe most grinders are wired from the factory with the lamp independent from the grinder switch. I prefer the lamp turn on with the grinder switch. It's an easy change.
