Between 265 & 485 SQ/FT Kwik Fab's Small Shop
PugetDude
Superstition Mountains, AZ
Naaaaw, definitely a stray!
It wanted nothing to do with me, but was trusting enough to eat as close to me as it did probably because it was starving.
If it does linger more often, I'll keep it fed. Any recommendations on an outdoor shelter, in the event that it needs one to stave off the heat?
Paging @Grizz1963
rharman
SoCal
If you’re gonna feed it get it fixed.
We have a setup like below on each of our two back porches. Kitty Tube with a Rubbermaid tub on top. The platform has PVC legs and is clipped at 45° across the front to align with the tube opening. As we call it.... The platform is the "veranda" and the tub is the "cabana".
The Kitty Tube is insulated and ventilated. They're really nice but you're probably not going to like the price. Available from Kitty Tube or on Amazon. Free shipping though.
We did these shelters after we adopted 4 ferals (or, they adopted us) in 2012 and knew they were going to be keepers. We still have 2 of them. One had given birth to her second (that we know of) litter when we found her. Pretty amazing for ferals to make it to 15 years old now.
If you keep the cat, you should look into TNR (Trap, Neuter, Return) services near you. Likely much less expensive than a local vet unless they offer some type of deal. That's what we did with ours. Fresno appears to have 3-4 offerings.
Good luck!!
Krfjkm
Charlotte / Mint Hill NC
I’ve heard to use an old igloo cooler— gives warmth in the winter
K
KwikFab
Central Valley, CA
Good luck!!
Damn you're right, those aren't cheap. Haven't seen the little guy though as I've been sick as a dog unfortunately.
I'm more worried about the heat; winter isn't really a thing out here as it never gets cooler than 40s or so. It's board shorts weather year round.
M.Brane
1 hr N/W of LA LA Land
And so it begins....
We have a black cat that's adopted us. Well he's adopted my girl. Loves her. Me not so much though I've graduated to door man. She got him fixed, and got all his shots current. We have a water bowl outside for him, but food is indoors to avoid attracting other neighborhood critters.
He's very aware of his surroundings, and very cautious. Probably why he's still around. Maybe one day he'll warm up to me, but I'm not holding my breath. The female cat we have that we inherited from some friends loves me, but she's still a little autistic *****.
rharman
SoCal
Of our 4 ferals, only one of them warmed up to us a little bit. If it was feeding time, you could pet him quite a bit. Other than that... NO way. That worked to our advantage when he had a major eye infection. Taking him to the vet would have been impossible. The vet gave us the antibiotic injection and we were able to grab him and give it to him. Sadly, he was the first to pass.
The remaining 2, and the 3rd that passed away last year, stayed feral. Feeding time is OK to open the door and, maybe, a quick pet before they realize it. When we think about it, we're actually glad they're that way. I'm sure it's contributed to their longevity.
K
KwikFab
Central Valley, CA
When I welded up those parts the other day, I was already feeling under the weather. Well later that evening I had the worst headache for the rest of the weekend.
Only now starting to feel a bit better, but I was able to get my business partner to pick up my parts for powder coat. Picked them up today and they're looking freaking great.
Even though I cut and bent 7 sets, I opted to get only 4 done so I can turn these around quickly. Already sold 2 and just posted the other 2 so we'll see how fast they go before I get the others done.
As for my press brake, I called and when I began to explain the situation (and my troubleshooting) I was met with a response saying "we'll send you a new board".
Apparently some of the boards they received did not get the "best packaging" so they've had reports of some having intermittent issues. They suspect it could be something like a broken solder joint which will be a really easy fix for me if that's the case.
For now I decided not to remove it, but the replacement does arrive tomorrow. If I get issues again with the backgauge, I'll remove it and inspect the port and the PCB for signs of any broken connections and reflow it leaving me with a new replacement board as a backup.
That's best case scenario of course.
Dig Doug
Trying to cool your air compressor down some - maybe get a portable fan hang it from above - off some chain or hooks …
Just throwing out an idea
Have you thought about adding a. 2 ton mini split to the garage ?
Central Valley gets HOT during summer and can get chilly during winter at times -
my brother lives in Tempelton and when I visit I drive N on the 5 ( from San Diego ) and take 46 over. I think your a little farther North of that
K
KwikFab
Central Valley, CA
I have two fans that blow from the inside of the garage to push air out for two reasons -
1. Keep me at least a bit cool
2. Push any and all smoke and metal dust out of the garage when plasma cutting
Even though the table is at the very end of the garage and I always run the garage door open, I like to be extra cautious and keep my lungs and the inside of the garage smoke-free.
I had just taken a random pic of the air compressor, but you're right it would be nice to cool it down some. I run a refrigerated air dryer for that reason, as the air gets hot and carries moisture to my consumables on my torch.
As for a mini split, it's definitely been talked about. My friend would happily do it for free if I bought a unit as he does commercial HVAC so you're talking big stuff. I posted a picture earlier in the thread somewhere of the large pipes he'd have to fit up and whatnot so doing a mini split would be the equivalent of a professional baker making cake from a box lol.
I just haven't considered buying one anytime soon because the mini split would be rather pointless if the garage door was kept open. That and business has been crazy slow all of a sudden so no money coming in to invest back into the garage.
When I'm working in there and not welding or cutting, the garage stays significantly cooler even in the summer as it's insulated. This is the main reason for not having bought a mini split.
Even when people stop by to visit and I'm in the garage they're like "holy ****, it's so much cooler in here". Especially when my business partner comes over :lol:
zimman
Mark Twain National Forest
Cut tons of parts out today, but I'll share last night's bracket.
The first bend that needs to be done is the very tip of the catch here. You can see that after it's bent, it more or less tells me how much clearance I need from the die before the second bend.
Anyway I had all that calculated so onto the next bends.
Leaving the larger flange for last. This is because if I had done it first, it would interfere with the punch holder doing the bend at the tip of the catch.
******* mint.
What camera phone or camera are you using. Amazing photographs.
Zim
K
KwikFab
Central Valley, CA
@KwikFab - Has your cat buddy come back? This just popped up on my Amazon suggestions today - made me think about your buddy.
Funny you ask - we've been busy so I haven't been around the shop at all to see it.
I did however see a FB post come up last night in a local group with a picture of said cat. Looked like the same one only to realize it is (same general location).
The girl deleted the post after we confirmed it was a stray and she took to messaging me to let me know it got picked up, fixed, and released again so that part is handled fortunately. Only thing that ***** is, the reason for last night's post by her is because the cat was somewhat limping.
I do hope it's alright, and I do believe it waked by my driveway around the time she messaged me that it'd be released. However, I had just received a solicitor as I opened my garage door hence the cat taking off.
I'll keep an eye out the next few days otherwise I may not catch it since I'm busy during the week with the kiddo.
K
KwikFab
Central Valley, CA
I don't believe I posted about it but recently I had posted a large metal Bluey sign I cut out over a year ago for sale. It was hung on my kid's wall in his playroom and since he had phased it out for Paw Patrol, I took the sign down.
Well, that thing sat with zero interest shown both in the forum as well as locally on Facebook. Decided to gift it to my kid's teacher so they can put it up in the classroom only to hear days later that the other teachers absolutely loved it.
When I picked my kid up today, I gave out a few of my business cards and asked that they send me a message to see about what they wanted.
One messaged me asking for anything Winnie the Pooh for her class, and another asked for a turtle.
After I got done with doing some mock up using a customer's truck today, I decided to knock out the Winnie the Pooh.
As for the turtle, I'll have to follow up and ask if she's wanting a "generic" one, or a sea turtle, or whatever she might have in mind.
Let me backtrack though. I had a buyer for some truck parts I make and while the majority are sold online, this person was local and only after we got to talking a short bit did he realize who I was :lol:
What I mean is, I'm known on another forum as I'm an Official Vendor there so when he found out, he was excited to put a face to a name. Turned out even better for me because I asked what kind of truck he had, and it was exactly what I needed to use for a mock up - a double cab long bed.
My good friend in Reno has a long bed as well, but during my visit a few weeks back I had very little time to actually use his truck for gathering my measurements. Well fortunately what I got was damn close to the final result because I cut out a revised set of mock parts and put them against today's customer's truck.
Love how good 16 gauge cold rolled looks; picked it up today just for this mock since it's a lot cheaper than cutting the real parts right away out of 3/16". The kicker? That 16 gauge went up in cost from $65 up to $81 today before tax.
And here they are clamped to the truck so I can measure the final "adjustments" needed.
Funny thing is, you're seeing the ugly side as I had asked the customer to remove one of his sliders (specifically passenger) only to realize I cut out mock up plates for the driver side.
Anyway, was glad to get this done as well as receive some commentary. Apparently the way I designed these, they have more attachment points than the set he purchased from a well-known company.
K
KwikFab
Central Valley, CA
Agree but I'm doing the work pro bono :lol:
Steel ain't cheap so if you want to see an Eeyore you're welcome to donate!
As I walked through the gate, multiple other teachers were just staring at me until I dropped off the kiddo. Met with the teacher that wanted the Winnie the Pooh outside only for the rest to ask for a card, along with a parent so....I might be busy with misc stuff now lol
Jgaz
Hope at least some of the teachers, and for sure the parent, are willing to cough up the cost of the steel, at the minimum.
Nice work.
BTW: I’m really glad you have all your stuff in your own thread instead of scattered in the “your garage “ thread like the rest of us.
K
KwikFab
Central Valley, CA
Nice work.
For the teachers, I'm doing it absolutely free including the material.
I'm doing it just as my own way of saying thanks to them, even those from other classrooms nearby that have nothing to do with my kid since they're all Preschool and Kindergarten teachers.
My kid is in Preschool so he's in there with a few others between 3-4 and I'm sure it ain't easy for them to handle.
That and my wife is a teacher (SPED) for going on 15 years now so I totally get how things are for them.
The one teacher today that received the Winnie the Pooh did ask how much she owed me, to which I said anything she'd like to contribute would be appreciated as it would go towards the cost of steel to provide more to the others. So she's grabbing cash for me tomorrow although I did remind her there's no obligation.
As for the parent? Yeah I'm already drawing up a monogram sign and quoted him as a paying customer so we're good there!
K
KwikFab
Central Valley, CA
That monogram sign?
I finished drawing it up before I had to pick my kid up from school so once I sent him a picture, he OK'd it and agreed on the price.
Paid me right then and there which meant off to get more steel.
Most of my sheets I get cut down to 2' x 4' out of a 4' x 8' sheet, mainly for convenience of loading and unloading not to mention the lack of requests for large items. In this case, the sign will exceed 24" in both directions so I got the sheet cut down to 3' x 4' pieces.
He had asked if it's possible to get it done by the 20th - dude doesn't realize I'll get this done either tomorrow or the next day.
K
KwikFab
Central Valley, CA
Man, was he absolutely happy.
More so because I got it done next day :lol:
Also knocked out a little favor a friend in Utah asked for. He intended to pay, I told him it's free. Afterall, it used up a small corner at the bottom right of the sheet I had cut the sign from.
It's a small stencil so he can spray paint his logo when needed.
K
KwikFab
Central Valley, CA
I was going to wait until tomorrow to post but, why not share now.
I haven't been on this forum long so there's a **** ton many don't know - I try to always give back more than I get.
Few days ago on FB, someone reached out to me just to thank me for the past few years I've spent helping strangers from all over to learn CAD, CAM, troubleshoot their CNC table, and more. I did it just because I never had the help and decided others shouldn't struggle like I did. This was back when I was a regular user before I even became a moderator to the group.
Anyway, he wanted to show his gratitude by gifting me a kit he specifically makes for my press brake. No strings attached, hell he said I shouldn't even mention it at all as he really just wanted to show his appreciation. Well, I sure as hell appreciate his thoughtfulness cause check this out -
It is a kit that replaces the "fingers" on my press brake's backgauge from the weird triangular ones, with a flat set. These make WAY more sense and I had actually considered purchasing some from another seller but never did.
They're CNC machined out of steel, and cerakoted I think so the finish will last a long time.
The small bag up top has little "ends" that can bolt onto the fingers to allow a specific angle and/or shape to fit for easy alignment of parts; not all parts will sit squarely up against the backgauge in the real world.
And last but not least the long blocks that are CNC machined out of aluminum. They are also stops that work in the same way the fingers do. Only thing is, these sit on top of the backgauge portion and allow an additional 12" of depth for seating something farther back into the brake.
Otherwise if you jog the backgauge backwards enough, it'll actually hit the limit switch and you can't go back any farther whereas the extended stops sit farther back past the limit switches.
What I'm mostly excited about using are the squared up fingers and the inserts so those will get installed first thing tomorrow.
Absolutely a huge shout out to Jacob for doing this.
K
KwikFab
Central Valley, CA
Kid had soccer practice this morning, so I'm only now getting to the shop.
Swapping the fingers on the backgauge is as simple as pushing out a pin. Here, you can see the old next to the new.
My complaint about the stock finger (left) is that I would often have to adjust my backgauge laterally, to ensure the "tip" hits the right spot when setting up a part to be bent. With this square setup, it doesn't matter if the finger is at the edge or center as the whole face sits perpendicular to the die.
What's really nice though are the threaded holes on the finger itself. This allows the use of inserts (included) to allow for an odd shaped piece to still fit against the backgauge.
In a real world setting, not everything you bent is going to sit squarely on the press brake, as I have parts I often produce that have a slight cant when placed on the brake to be bent which are the L shaped brackets here.
I make so many, yet I never use the backgauge because of the odd angles; now I can for future use.
And the last part of the kit are the rear extensions I mentioned above. I've yet to install them mainly because it does require a small bit of disassembly, but I'll get to it once I see myself needing to seat a part deep on the brake for bending.
The crazy part is I would've gladly purchased the finger kit as they're only $60 while still being CNC milled. Another seller offers them for $189 and if I recall, he sources out the job hence the significantly higher price.
K
KwikFab
Central Valley, CA
That finger kit looks really well thought out. I like the adapters for odd shaped pieces.
It really is, and I'm stoked to have his whole kit.
Wow! I don't want to know what they cut off/out of that cat. Yikes!
Speaking of, the gal messaged me yesterday that the cat was dropped off at her residence.
Even though it's a stray, they felt it was better to release the cat exactly where it was already comfortable so it seems the cat sort of already chose a new owner :lol:
She can't keep it though since she's got 4 dogs but seeing as how she lives nearby, she's glad that a few of us in the neighborhood will be looking out for it.
When we were running errands today, I picked up some more cat food along with a bowl for it.
