rattle_snake's random shop projects v0.1
R
rattle_snake
Chandler, AZ
Last guy that worked on these headers threw a tantrum and beat the **** out of one of the primary tubes with a large hammer. With steering box gone, no need for that.
Don't have a torch hot enough to try to heat/cool the dents out, so cut out part of the offending section of metal for repair.
Used a piece of pipe with OD just under the tube ID to hammer the tubing back into shape. Pounded the piece up into the bend and got most of the dent out. The piece I cut out was the perfect scab, so I worked it back into a round shape with a hammer and right sized pipe.
Welded it up and slicked it out. Not too shabby.
Sent it out for coating, good enough.
ntsqd
Lower left coast
When I made a new dip-stick for Patch I used a compression to NPT adapter fitting. Screwed the fitting into the block (in this case, could've been an NPT bung), stuck the 3/8" Bundy tubing in it, bent the tubing to clear things (in one plane only), and then tightened the compression fitting. Used a compression by compression fitting to seal the dipstick into the tube. Set both ferrules and then backed the top nut loose to finger tight.
I poured one quart short of full into the engine and let it sit unstarted overnight, and marked that on the dipstick. Poured the last quart and let it sit overnight again, then marked that on the dipstick. I was making a bunch of different changes and didn't need to start it anyway, so letting it sit over a couple of days wasn't a problem.
Water is easy for leak-checking, but terrible about it. Mineral spirits, diesel, and ATF are far, far better. All three will go thru holes that water won't.
R
rattle_snake
Chandler, AZ
Picked up the rear sump truck oil pan and compared it to the 1980s dual sump car pan.
The area I'm most interested in is the front of the pan that is close to the crossmember. The truck pan is about 1/2" shorter and is tight on the pump body. The Banjo fitting needed to run the dual sumper is 1" tall, so total clearance improvement is 1.5" This will allow me to lower the motor as far as I want, beyond where it was.
Planning on a tube crossmember under cab mounts, like factory. The truck pan sump is farther forward and should allow the tube to run behind it.
The rear sump is deeper on the truck pan by a decent amount, don't really care.
The pans use different pickups, for the different sump location and depth. Car top, truck bottom.
When pan is in position the front sump pocket for the pump is below the saddle still. This means that a minor amount of oil cannot be drained, which is OK. But it also means the front cover dipstick cannot be used. It would always read some oil even is rear sump is empty. Have to abandon it and plug the hole.
The truck pans in general are 6 qts and car pans are 5. I put 6 qts of water in the pan and marked the level to have a target for the new dipstick.
I cut a short piece of DOM (7/16 ID?) and drilled out one side for the dipstick o-ring to fit properly. Next step is to drill a hole in the pan. The flexable dipstick length can be adjusted.
ntsqd
Lower left coast
Looks like the pan has a guard of sorts for a block mounted dip-stick location. I thought Ford never did that? Timing cover, yes, not in the block. The FSB's dip-stick is in the area where that part is, but I can't really see how the tube joins the engine down there.
R
rattle_snake
Chandler, AZ
Some 351Ws have a dipstick hole in the block where you see the provisions in the pan. Some early and then late 90s blocks. The pan I bought is for the late model engines that have that hole in the block. Using that is also an option. Have to look and see if my block has that, I don't think it does. Would be easy to drill it though, so it is an option. I haven't drilled the pan yet.
R
rattle_snake
Chandler, AZ
Stared at the oil pan some more. Realized that the entire 6 qts won't be in the pan when checking oil. After running engine, fill filter, let sit. So target is 5 qts-ish and can trim the cable after it's running. Made a longer bung with smaller DOM to secure the tube. Dipstick length seems too short....
R
rattle_snake
Chandler, AZ
Drilled a hole in the new oil pan
Welded up the new sleeve both sides.
Right motor mount
Left motor mount
Ended up lowering the front of the engine by about 3/4" from before. This leaves about 3/4 between the oil pan and the cross member. Left the trans cross member as-is for now. Kinda have to do the rear suspension and see what the driveline angles are going to be and design the mount to that. But the motor is in.
I think the next item is the LCA/cab cross member. Now that motor is in and headers in place I can route the tubing as needed.
Removed the front dipstick, trying to find a freeze plug that will fit. Then figure out best mounting method for the new dipstick.
Time to start thinking about the brake lines and hoses, and steering.
R
rattle_snake
Chandler, AZ
Thanks! Seemingly simple but took me an entire day to weld three pieces together. With axle forward, have to get a little more creative that what is available to purchase.
R
rattle_snake
Chandler, AZ
Working on chassis brace under the cab mounts and rear LCA mounts. Since the frame is boxed, the brace can be a pinned connection, single link on the bottom instead of attaching to both flanges like the factory brace. The header collectors are the lowest point and prevent a straight shot from side to side. I broke out my old HF pipe kinker to attempt to bend some tube. Does almost OK on shallow bends on certain material after some modifications.
Having built pipe fence I notch with a grinder. A belt grinder makes quick work of it, and can narrow in on the best angle given the different tubing sizes. Tube is 1.5 OD 0.125 wall, sleeves are 2 OD 0.250 wall.
Tight joint almost no gap.
Clamped the sleeves to the bench at the desired width, and fit the bar in between. Ended up with about 13* bends and a 1.75 drop.
Weld-r-up. Full power Scotty.
Painted the bar and installed the bushings. Re-tacked the frame tabs slightly for best fitment. Decent clearance around the collectors, but didn't like how low the bar hangs down.
So back into the kinker for another bend. Decided to do a single bend in the middle to make a double hump type of deal. Ended up the same length, because math.
Burned in the frame tabs with solid spacer. Been awhile on overhead welds. Now bar is tucked up to the trans decently while still having 3/4" clearance on the collectors.
R
rattle_snake
Chandler, AZ
Steering lines in
brake lines, hoses.
Made some body mount bushings
Cleaned up the inner fenders. Welded most of the holes up, cracks. Trimmed for the new suspension.
Wheels don't fit, need spacers. Spacers require long studs.
Finally got it sitting on the front wheels again.
0 psi
R
rattle_snake
Chandler, AZ
Made quick work of that(y)
Quick?
Seemed like a lot of work to me. A lot of time spent on things not really related to the primary job to be done.... Squirel!
Lookin' good!
Thanks!
Very nice work indeed! I missed it, what is that IFS setup, it has some nice aluminum pieces.
IFS is last gen crown vic.
man that is looking sharp!
Thanks!
Damn, that was fast !! Great work!!
Thanks!
I guess fast is relative. Started the job in May.
R
rattle_snake
Chandler, AZ
Tons of progress! Feels quick especially considering most things are custom and feeling mostly dialed in to start with🤘
Yes a lot of progress. Not all forward, but progress all the same. :unsure:
Even though I have already reworked and improved many aspects, I'm still finding more small items to re-do.
First pass was fix 50% of ghetto items. Then got to 90%. That last 10%....
You're in luck, they don't have your application. Yet. https://sbfilters.com/collections/body-mounts :)
I saw those earlier, $600 for bushings.
R
rattle_snake
Chandler, AZ
Tried again to move the truck over to lift bay. Fired up, put in reverse and not moving. It does that sometimes if sitting long enough. But I also messed with the intermediate band.
I shut it down and noticed a large puddle of steering fluid on the floor under the rack. I snugged up the AN fittings, which ***** because they spin and can't really get a wrench on them. Should bought the more expensive one piece block. Maybe I'll weld this stuff up.
Fired it again and can see that there is fluid pouring out of the input shaft. Seal is ******. Wonderful. So truck is still not running or driving. Glad I'm not in a hurry or have a deadline. Decided to push it over to the lift bay. Used the jack to swing the rear end around. Going to drain and pull out the rack.
In an attempt to accomplish something, I un-did the trans line clamps to redo them. Instead of ovalized p-clamps to secure the hoses, I reworked the separators to also bolt to the frame. I drilled out the threads on the back half, and swapped out the metric socket head hardware (some M4, others M5) for a 'Merican 10-24 Philips like the others. Then drill and tap threads in the frame.
Still need to secure the audio system power wire somehow. Probably black split loom to not make it stand out.
Now the run of hose is secured with just 4 screws.
The sway bar inverted itself while jacking the front end up and down. I put it back but it is likely too far forward.
I've been on a quest to remove and replace p-clamps and velcro straps. I bought a stash of AN hose separators from -4 to -12. It's fairly easy to make one side bigger or smaller, and many of the applications have different size hoses. Didn't get pics yet but did the power steering hoses and the A/C hoses.
tremiso220
Tried to save the translucent finish on the guitar project. I mixed the die to strong and it left marks, but even beside that the color was dark and dull. No life. Tried sanding the color off, but it seemed to burn and get worse. Tried wiping it off with solvent, and that worked well except where I had tried to sand. Sanded through some of the sealer. Banged up the neck reworking it 3 times. So not going to be perfect. Put some more sealer on the sand thru areas and decided to try a different color.
Not sure what the wood is exactly, but it has a red hue to it. I realize I'm not going to get a pure blue color from it. The opposite direction is to add yellow (to green instead of purple), so I dumped some unmeasured amount into the leftover blue/black I had already. Die went to full green. Decided to go for it, put a green coat on front and back. Wow, now it pops. The front sealer was partially sanded through all over, and took the die differently. Put a coat of clear over the die on the front. Needed more color to hide the prior mistakes, so used the straight blue. Better, did another clear on the front only. Then finally a 2nd straight blue. This yielded a dark green, looks to me like an apple Jolly Rancher candy. So sour apple it is, but at least it has depth and a soul. The hardware is gold, and this dark green should go well with it. Bought some gloss polycrylic spray and put down a heavy topcoat. Sanded, another layer, then removed the binding mask and put one final coat of clear on the whole thing.
In the sun you can see the blue topcoats over a green at the bottom. Next step is glue the neck on.
Honestly, the sour apple green sounds like a much better outcome than the original blue. The gold hardware with that deep green should look fantastic, and it sounds like you managed to turn a few mistakes into something with a lot more character.
R
rattle_snake
Chandler, AZ
Justin, the whole build looks fantastic.
Agree Justin.. you are doing a fantastic job! very inspirational... even though it is a blue oval! :ROFLMAO:. So... can I ride along when you go do the burnout in the FFG turnabout :rocker:
Thanks! Enjoying the process. well most of it.
Ya I think 'something different' was an OK outcome instead of same old colors. Learned a lot doing the builds and had fun with them.
lol I had a compete set of body bushings left over from a bronco build I did a few years ago. The bushings are nearly the same size so I used them on the 66 f100 I’m building.
I found a set of 78 79 bronco mount hardware for 1/2 the cost of truck, even though the bronco has twice the mounts... but still made my own.
R
rattle_snake
Chandler, AZ
Replaced the rack input shaft seals
Same result. Didn't appear to be leaking previously. At a loss how to move forward....
The pump is a GM type 2 rated at 1300 psi. Can get shim kits to lower, but not convinced this would solve. Looks like CV bypasses around that pressure.
The car that the IFS came out of was hit on left side. I replaced inner rod on that side, otherwise the rack moves smoothly.
I could get a re-man rack but I think it will pour fluid out like the existing.
Empties the reservoir in 1 second.
R
rattle_snake
Chandler, AZ
Had the hoses on backwards. Assumed the little port was pressure and big return like the steering gear that came off. But for CV rack the big is pressure. Holding fluid now.
Instead of parts swapping I wanted to understand the issue. I plumbed in some shop air to pressure line and it puked out the shaft. Pulled dust caps and oil seal was blown out/inverted. Hmmm. Didn't go in like that. Popped it out using air. Seemed ok. Put it back in. No air exiting return. Checked hose connections and had them reversed. both 6AN.
The transmission appears to have all Neutrals.
