Maxjax Installs: Post Here
abstamaria
Manila
Les, I didn't drill extra stop holes in mine. I'll try to work with the current holes.
Thanks, Regguy 1.
That's my one-year-old Rottie Sundance, who had more confidence in the lift than me. He kept wanting to go underneath.
abstamaria
Manila
Re: Maxjax in Place (and Red!)
Here are the lift columns, as installed. I thought the black paint on the columns tended to make the lifts stand out too much, so I have the section above the base in red now, as with the arms. I didn’t want too many colors in the garage. I hope they look all right. That’s my 8-year old garage buddy, Xena.
mat_GTI-R
God I want one of these!!!
I have a drain in the middle of my garage and the floor drains to it all around... wondering if this light slope would give me a headache trying to shim the two posts?
How much can these posts be shimmed? :-\
Oh and M. petee_c, I see you are from Canada, where did you get your Maxjax from and for how much?
Thanks!
Todd.Brock
Cincinnati
Someday I am going to get around installing my Maxjax. I bought it back in June with the last groupbuy. It was 1750 shipped.
UPSHIFT
Simi Valley, CA
WOW !! SPEECHLESS> :bowdown: GREAT COLORS, GREAT LIGHTING..
abstamaria
Manila
Thanks, all. I hope you like the garage. It is very bare. Petee, I am not in the midst of a major repair, so it looks clean. The fact that it is very bare makes it easy to keep idy, or at least look tidy. The white floor helps.
JCSlocum, the read tool cabinets at the back wall are heavy-duty Proto, acquired one at a time over many years.
Mat, I don't have the manual with me (but you can access it on the net), but I recall MaxJax says not to exceed a certain number of shims. Maxjax comes with several shims of two thicknesses.
The floor is white epoxy. The paint was from a local manufacturer (I am in Manila), so my experience with it may not have much applcation elsewhere. But let me look for the discussion on it, and I will post the link.
Best,
Andy
abstamaria
Manila
Lifting newish 911s
I planned to try the lift on my 2004 Porsche 996 first, since it is a relatively new car with provision for lifting on 2-post lifts. The 120" spacing I used seems all right for the car; however, I couldn't position the pads of the MaxJax so that I could avoid fouling the plastic body panels around the rear lift points.
My Porsche has small lift points, each with a key-hole slot in the center. I think it shares this with most newish Porsches. However, on my car (a GT3), the plastic rocker covers wrap underneath and make it difficult to place the MaxJax's large square pads without trapping the plastic bits. If the MaxJax's pads were circular, they would be perfect.
Incidentally, I have one jack pad, shown below, left over from my old 993. This is specifically for Porsche and has a key that fits into the slot mentioned above. If I got 3 more, that might be the solution. However, I would have to place the Porsche items directly on the MaxJax's metal arms. I wonder if that would be safe.
Andy
abstamaria
Manila
Unable to lift the Porsche, I tried the MaxJax with an older car. The 120” spacing worked well, too, and the car went up easily, as shown above. The MaxJax should be great for servicing this car, as a rear wheel and an inner fender panel have to be removed to access the oil filter. What a treat.
Jvvmusme
Bogota, Colombia
Andres
Shouldnt you move the dino a little bit forward ? In order to balance the weigth ? The theory says that the arms of the lift where most of the weigth is should be a little shorter than the others... In this case the rear arms. I read that somewhere.
I find this Dino a real dream. My favorite body style. A 206 or a 246 ? Like it more than the GTS.
abstamaria
Manila
Red MaxJax
Petee C is right, Les. yes, I like the red, too. It makes the lift seem more compact.
Andy
abstamaria
Manila
Dino on MaxJax
I worried about that, too, Jose. The good thing is that there is an active 206/246 forum, some of whose members have had experience with 2-post lifts. One sent the photo below of his frame in the course of restoration, showing the lift points. The rear lift points are farther forward than I would wish, so I share your concern. However, the collective experience seems to say the points are safe.
I prefer the GT to the GTS, too, Jose. This is a 1972 246, purchased some time ago when they were not too expensive.
I'm looking forward to your thread.
Best regards,
Andres
abstamaria
Manila
Brentocool, an electric cable goes to the portable pump, and two hydraulic hoses connect the pump to the posts.
Joe From NY
NY
Yeah, you wouldn't want too many colors in your garage, that would ****... :supergay:
I actually like alot of colors in my garage:
Joe From NY
NY
No wonder you have to work outside!
yeah, i need more room, i guess i am a country open-space kind of guy trapped in a small plot suburb and it is frustrating. that photo is from 3 years ago, it is much more crowded now. :shocking:
abstamaria
Manila
Joe, I didn't mean that sarcastically. I had intended to write it is good we have different garages, that each had it's own charm, and that I liked yours for that reason. I know you do a lot of work in yours. My old garage didn't look too different from yours.
But, if you want go clean up to recover some space you have to throw things away. That's very difficult.
Andy
Joe From NY
NY
Andy
yeah, that photo was taken two years ago, mine is actually a lot worse now. An old machinist lived across the street and died years ago, the wife sold the house with all his **** still in the basement. I bought most of it from the new owner, including a nice Clausing lathe from 1951. That is in pieces now in my basement, but all the rest of his tooling and other stuff is in my garage now. i only have a path now to walk in, but i couldn't stand to see all that stuff go to the scrap yard.
This is the lathe before the move:
This is come of the **** i took out:
demoderbydave
Spencer Mass
Joe,
Don't apologize for the "mess", as long as you are happy that is all that matters. Someday you JUST MIGHT need some of that stuff! :headscrat:eyecrazy:
abstamaria
Manila
Pump Cart
To round up my report on my install, I decided to keep the pump unit portable as it would be too difficult to route permanently installed hydraulic lines. I was bothered by the hand-cart appearance, however, and so chopped off the long handles and installed a spare chrome bar from one of the tool cabinets. It looks a bit neater, I think.
Andy
demoderbydave
Spencer Mass
Re: Pump Cart
Boy I thought I was **** about stuff!:lol_hitti But as Cheryl Crow once sang..."if it makes you happy...it can't be that bad!"
More power to ya and let me know when you want to give MY garage a makeover!:thumbup:
les_garten
PSL, FL Next door to Megan FOX, and down the stre
Re: Pump Cart
Andy
It Needs Flames!
MOAR FLAMES Please!
Chetter
Northern Ohio
Anyone know of any up and coming group buys on the Maxjax lifts ?
Yea, I'm really wanting one these lifts, and it would be good if there was another group buy or special price for the Garage Journal members. I have finally gotten money enough to try and buy one of these, let's hope they help us out. :thumbup:
