Lets see your workbench
Theo911
Here's a shot of my recently completed workbench (previously a kitchen cabinet base that was falling apart). I reinforced the structure first after taking it down to the frame. Then I put a base on it with casters. The worktop is 9 ft x 26" with 3/4" plywood over 2x4 framing every 16". Over the top of that is galvanized sheet metal with aluminum 1 1/2" angle on corners. Dark gray paint. Added handles and put a thin durable carpet in the drawers and shelves. Recently added the outlet strip along the back and I have a vise to mount but I havent decided if I want to permanently mount it or make a base for the vise that I can clamp on the top when I need it.
Always_Thinkin
Illinois
Well here is my workbench. It is still not finished...you know how that goes. I got a lot of ideas from the Family Handyman website and just searching images of workbenches in Google.
I incorporated different features that are really handy, I think. Each picture shows a different feature of the workbench. That is why there are so many pics. The workbench surface is 2.5' x 8' and is 42" above the floor. It is currently free standing so I can move it around. Let me know if you have any questions.
The features include:
Pic 1. Overhead Lights and magnetic tool strips mounted to the 6" deep shelf 18" above the workbench surface.
Pic 2. Oversized pullout drawer above a roll-out drawer (for the heavy stuff).
Pic 3. Slide-out drawer panel for 4 jack stands, hardware organizer, floor jack handle and two wheel blocks. Also, my floor jack stores under the pull-out trash can.
Pic 4. Pull-out under workbench trash can.
Pic 5. Tool cart stores under workbench.
Pic 6. The Kids' workbench...gota start them out in the garage early.
lucky.expert
San Antonio, TX
Well i just joined the forum to be able to check out everyone's workbench pics, yall have some sweet ones! I built one a while back for my garage, I just wanted what I would call a 'Classic' workbench.. Sturdy, big, and with storage drawers. So the one I built is 8'x 2' or so, with a full 4'x8' pegboard on the back. I attached a fluorescent light to hang overhead, as well as a 4' 12 outlet power strip attached about a foot above the table top. It has 5 full extension drawers so nothing gets lost in the very backs of the drawers. I looked all over online for a workbench like this, but nobody seems to sell them so I made my own.
SRX
R6, I love the avatar!
On a side note, I found 2 plastic bread delivery trays in the middle of the street one day (must have "fallen off the back of a truck" literally) and had the idea to attach full extension slides to them and make a couple of "open-top" drawers for the work bench. Has anyone ever used these before? Figured I could lay the cordless drills and such in them.
lucky.expert
San Antonio, TX
Great drawers on that thing. Nice job!
Thanks, I've always liked the looks of recessed drawers compared to normal ones.
and SRX, I don't know why you couldn't use those bread trays, assuming they are sturdy enough to be able to attach a slide to, as well as a big enough flat spot to attach the slides so they don't get in a bind...
pendragon1998
NE Georgia
I think we had about $100 into the larger bench we did, and another $60 in
the smaller one, using some of the scrap plywood from the first one.
My bench is built of kiln-dried 2x4s and the benchtop is doubled-up 3/4" plywood. Everything is bolted
together with 1/4" bolts, except the center legs which are screwed and the benchtop itself,
which is connected using steel Z-clips seated in a grove on the inside of the upper stretchers.
This sucker is built to outlive me. I hadn't yet added plywood shelving underneath when I took
this photo, but it has since been installed.
The benchtop is 6' long and is made from two AC grade 3/4" plywood sheets
glued and screwed together (1.5" total thickness). It's rock solid. I'd really prefer
to add a sheet metal top to it, though. Since this photo, I added a wooden strip
to the edges to clean up that raw plywood face.
Here's an interior shot, showing the doubled 2x4 legs (though-bolted) and
the rabbit groove that houses the Z-clips holding on the benchtop. We
didn't have the best router to work with, but we got the job done.
I built workbench number two (2' x 4') using some of the leftover materials from
workbench number one. I only used single 2x4s for the legs on this one,
as it's got a smaller horizontal span and I don't intend it to be used for as
much heavy use. It's still strong enough for me to jump on.
The Civil One
My Work bench ,, pics , 1 to 3 , this is for physical work. Mostly mechanical.
Pics 4 to 7 are my working bench , where i make my living.
It used to be a Name board , on a shop front , it was lying in a back yard ,
i spotted it was Mahogany , and spent a few week bringing it back to life .
The legs are an old pair of banisters , and the whole lot folds away neatly.
Falcon67
Merkel, TX
Here's the main one:
Lathe bench and some of the trans overhaul bench.
A steel bench I bought at an auction - handy for welding and hammering.
kyles974
Florida/Alabama
:rocker:
Way to go dad!!!!:thumbup:
My 6yr old girl would love this!
I might have to do the same, thanks for sharing!:beer:
nice bench!:rocker:
Perks
New to Forum so this is my first post, I made this bench awhile back to use as a welding table & work bench, The bottoms are a couple Harbor Freight boxes that are actually pretty nice for the money all ball bearing & will carry a lot of weight, One side is filled with lathe & milling machine tooling & all the drawers still slide beautiful, I removed the casters & made up feet for them with adjustable pads to level, The top is a solid piece of 3/8" steel with a 8" back splash I welded to it, The complete unit is welded to the railing that leads into house which locks bench solid.
Perks
simon g-s
Not sure if you can make mine out under a pile of stuff. Its a heavy old warped and twisted welders bench I got for £5 years ago.
I'm modifying an inlet manifold for my pontiac 400 to fit a 6V71 super charger. My guess, it will go like the clappers OR blows up!
Outlander
Quebec, Canada
Here's mine. All made with recycled wood from other projects or left behind by previous owner. Lots of space on the big one in front of the windw, which has a view of the lake. Smaller one is on hinges and can be folded. I find myself using it more than the other one as it is handier for most messy/oily work, and it is closer to the garage door. It has never been folded since I built it.
Hardware02
Here's a welding bench I made about a year (and a bit) ago...
Removable handle for moving it around...there're a vise and anvil on mounts that can slide into that receiver or the one on the front of the bench...
Morrisman
Angeles City, Philippines
Neat idea for a welding bench. I've always visualized using a large flat steel plate for the top, but that would mean anything with a lump on the back would not sit flat while you welded.
Cool idea, I may use it myself when I build mine. :D
Tim The Tool Man
Lehigh Valley, PA
Here are a couple of my work benches:
This is my main work bench.
...And this is my chop saw & RAS bench
I haven't built my welding yet but I plan on stealing a few ideas from Hardware02's bench.
tinbender 66
Western Washington State
It's time for me to build a welding table. I've been trying to source a piece of plate for the top but now that I've seen yours I think I'll just plagiarize it :).
For the kind of stuff I do, I don't need a "surface" plate.
I really like your table!!
mdbeck1
Norman, OK
I like it as well. If you think you need a solid surface table later you can lay a piece of plate on it and clamp it down.
Jack Olsen
Los Angeles
The operative term there being 'clamping.' The cool thing about the surface made out of rectangular tubing is that you can clamp your work just about any way you want.
mngundog
MN, in the sticks, U.S.A.
Perks
So the cabinets are bearing the entire weight of the 3/8 steel plate?
Falcon67
Merkel, TX
I LOVE that welding table. Man, great out-of-box idea. And, now I know where all the pegboard went. :lol: Sweet.
chris30066
Georgia
I recently built a 12 foot long workbench out of galvanized pipe and 2" x 12" boards. I was originally going to make it wider, but I couldn't reach the peg board well. That's the reason for the missing board along the front. I attached a removable vise to one of the legs, and I plan to attach a removable grinder to one of the other legs.
DustynF
I finally finished my first bench. I took some pointers from you all and added a few of my own ideas. The top is 16 gauge mild steel and is 30 inchs deep and 40 inches high. I incorporated a small 2.5 gallon bosch water heater under the cabinet. I filled and sanded all cracks then painted the frame black. After that I came back with two coats of poly. I also added a desk space with a top that is made out of John Boos butcher block.
Hardware02
Exactly. Some guys source a flat piece of plate half the size of the benchtop as well - then you can move it around on the top as the project dictates.
ClintNZ
Rotorua, New Zealand
Hi All, new on here. I need to take a decent set of pics of my shed to post up, but in the meantime here's a few that I have on hand of my most recent project, a mobile bench:
I made it to fit over the old filing cabinets that I just scored for a trash bin & storage, & to have a top at the same height as my main bench.
The top is hardboard topped truck deck plywood left over from making a trailer. Having something easy to wheel out & work right around has already proved pretty useful. Before I paint it I want to add a mount for my circular saw underneath, a guard & some guide rails so it can also be used as a table saw.
Cheers
Clint
