Lets see your workbench
Matt018
Mines homemade out of 2x4s bolted together, and an old door, Thats a laminated desktop on top, and a 1/4 steel diamond plate flipped over and screwed into the top for durability.
don long
southern california
I have a stainless steel table from costco that I turned into a self contained bondo cart
It has a vacuum that turns on when my air tool demands air and shuts off 3 seconds after tha air flow stops it has a manual switch for hand sanding
each power sanding tool has a dedicated place on the table top held on by the sand paper hole punch and the hand sanding blocks are vacuum assist tools that sit between two aluminum angle bars.
you can see the holes cut out of the table top for the bondo can, the cream filler, and the charcoal dust dispenser along with a thinner can for cleaning the bondo board. The hardners and spreaders are in a tin can as well
on the first shelf in the front is different types and grits of sand paper and grinding discs
the second shelf holds the hand sanding screens and a dent puller that welds itself to the metal for hand pulling dents.
The third shelf holds the long board hand sanding screens and the vacuum
in the back rests sand paper for the 3" d.a. and grinder and my dust masks,
scotch brite pads and sand paper for the 8" disc machine
take a look
Plane Crazy
35' of work table down each side
high enough to lean on, and store engines under
legs are bolted to the wall for more floor space
trimed to fit wall, so small parts can't fall out the back
of course, a break area
and a shoe rack, next to that, for speciality tools, hung from the wall, space for jack stands under it.
RivennHewn
PNW
Another workbench completed this week.
Vintage cast iron lathe legs, with an 1-1/2" thick maple top.
Who recognizes the stretcher?
thightower
oklahoma
Don't have picture of it. But it is a 4' x 8' sheet of 1/2" plate with 6 1 1/2" legs, about 40" off the floor. Dad built it 30 yrs. ago and it has stood the test of time.
BMW Rider
Calgary, Alberta, Canada
Just built myself a new workbench last week.
The old one which got dismantled to make space for the addition work on my garage was just a 2x4 frame with an old door for a top. This one is welded up from 1 1/2" square tubing and has two tool cabinets mounted in it. The top is doubled 5/8" plywood glued and screwed together with 1 1/2' x 1/8" flat steel edging. The top surface is Allure Trafficmaster garage flooring from Home Depot. Its very solid and supports my Record 6" vise quite nicely :thumbup:
DanMasshardt
Very nice. Everything I make is so much more basic than you guys. :-(
NUTTSGT
Northern Central Ohio
Wow, I finally made it to the end of this thread after spend some time looking at some great benches. I guess it's time to post mine up.
Here's work table that I built, it started life as two kitchen base cabinets.
This would be the workbench of that side of the garage.
A couple of pull out boxes (drawers) that are in the middle section.
The workbench on the garage side.
Storage fastener behind the doors.
emeraldcoupe
spring hill, florida
take a look
awesome is the only word to describe that bench.
thundermug
usa
Here's one of them. Pollard made in Chicago.
http://sphotos-a.**.fbcdn.net/hphotos-snc7/388825_602656270662_451381528_n.jpg
MoparTrucks
Ozarks of Missouri
Man some of you guys are really skilled and your work benches are awesome pieces of furniture better than anything I have in my living room. And I have to say the DC-10 turned into a shop is completely the coolest thing I have seen in a long while.
I just built a rather...rustic work bench for my shop today out of 2x4s and lumber left over from other projects. I got the basic design out of an early 1970s Popular Mechanics magazine and its taller than normal due to my partially fused spine as I cant bend over a low workbench anymore.
steky
Western Ky
Wow, you guys have some nice garages and workbenches. I'd be ashamed to post pics of mine, I'd have to clean it off before you could even see it....lol. Really bad about throwing tools on my work bench during projects and not cleaning up. Got a few days off from work coming up. You guys have inspired me to clean the shop up and get better organized. Maybe I'll take some pics then...thanks for sharing.
MoparTrucks
Ozarks of Missouri
Aw take a picture and post it, the only reason mine isnt a mess is because I just built it. I wish I had some of the wood working and metal working skill of a lot of the guys on here (or had the money to hire them to build me something super nice) but like you this site has inspired me to get off my duff and get things organized and cleaned up.
bullfrog123
SE Idaho
"L" shaped with wood top on one side and 1/4" steel on the other. Steel side is for welding and general beat the chit out of things and the wood side is nice for assembly and general work. Last year I rebuilt the wood side and incorporated a HF box into it. Also anchored down the bench not only to the wall but also to the concrete floor. The turnbuckles keep it nice and tight.
Last pic is my woodworking bench. Simple angle iron design with particle board top. Nothing too special.
vtwin650
I am sure that I have posted these before, but I spent some time organizing this weekend and thought I'd share...
Cheers!
Noxx
San Dimas
Just oiled up and installed a new top, so I don't have my vise or the Dillon mounted up yet, but you get the idea. The towers are 7 drawer Lista's, circa 1980.
Noxx
San Dimas
I just oiled up a new top, so I don't have a vise or the Dillon mounted up, but this is my primary gunsmithing / reloading spot. The towers are 7 drawer Lista's circa 1980.
Garage Logix
Seattle, WA
Here's one of our custom stainless counter workbench projects with matching stainless garbage door and space for his beer cooler below. lowered the workbench to use as a desk for his computer.
Love my job!:rocker:
SRX
I recently decided to build a bench for my basement room. I picked up this door today to use as a top for $50. It is 80" x 36" and solid. I am driving out tomorrow to look at these surveyor drawers for $50 a piece. They are 40" wide and 30" deep. Seems like a good combo? What do you guys think? My only concern is just how deep the drawers actually are.
Wadd2
Hard to tell in the pic but one side is 6' long and the other 12' long. The 12' side has a bench grinder in the middle and my vice on the end with 3' of it covered in 1/4" steel plate where the vice is. All of it is 30" deep.
PCO6
Newmarket, Ontario
At $50 each that's a great deal but I think you're going to find that they are about 34" deep.
SRX
Thanks PCO6. By any chance do you know what the height of the drawers are? I imagine the are not more than 2 or so inches. It's about a 50 min drive for me (not alot of fun due to traffic), so any help in the decision would really be appreciated.
Conor
Here is mine...
would it be a really bad idea to cut out the middle leg (only the front one, i'd leave the middle back one) I dont work with anything heavy this is just a bench that i tinker with small stuff on. I dont do engine repairs or transmissions....
I would really enjoy being able to sit in the middle of the bench.
daveroy
Omaha NE
Just two comments and take them for what you paid for them:
1. 30" is pretty deep for a bench. you will end up with LOTS of clutter along the back.
2. Surveyors drawers are made to hold big flat pieces of paper...
If you load this up with tools you may find the drawers/slides less than ideal in weight bearing capacity.
SRX
Good to think about Dave. I figured that given the price, it was worth the drive to see them in person.
PCO6
Newmarket, Ontario
If I was at our office I could check for sure. Two inches sounds about right. I'm sure they're not 3".
chassell
Just finished mine this weekend.
