work benches... from scratch
coolreed
Oklahoma City, It's a Windy Heat.
I built these Cabinets/Workbenches from scratch. They match my kitchen cabinets. Used a granite look formica top.
I also made this Roubo Split Top Woodworking Workbench that utilizes Benchcraft Vises. Weighs about 300 lbs.
Also made this Cabinet for my Garage Sink.
c10bonanza
Looks like a recent Guild build from Marc at The Wood Whisperer. Nice job! :thumbup:
Gunnert
Base of my workbench is 3/4" plywood attached to a header on the wall and angled braces. On top of that I glued and nailed Exotic Brazilian Imported Cherry hardwood flooring. Got a deal at Lowes on the Cherry when someone returned a special order. < $200 invested in 18' x 30" Workbench.
stonewellmark
Hudson Valley, N.Y.
Finally got a chance to start on my Bench, played with the idea of steel but already have one with casters under it. I just wanted a heavy duty solid wood bench that was cool. Let me know what you all think. Ill be posting more pictures as it comes along. Thankx
Mark
black88coupe
S/E Michigan
Seems like I posted this already somewhere .. don't remember .. anyway, I found a guy who once worked on a crew remodeling a Lowe's. They were told to scrap out the metal drawers that used to hold their fasteners back when they still were pretending to be a hardware store. Anyway, I bought 8 of those drawer units from him and knocked together a base and had my woodworking buddy help me with the tops and the other day we got 'em together. About sixteen feet long, plus they have 11" of clearance underneath for storing toolboxes, floor jack, chain saw or other awkward things. Have a look:
Thats awesome!
duude
Mine aren't nearly as fancy as some. ImageUploadedByTapatalk1360100791.054277.jpgImageUploadedByTapatalk1360100957.547851.jpgImageUploadedByTapatalk1360101104.435182.jpg
mattmatthew
The trick to cleanly cutting melamine is 4 things.
1. Sharp, new blade
2. Use a zero clearance blade insert.
3. Put masking tape on the bottom where the blade will exit (top if using a circular saw)
4. Set the blade in your table saw as high as it can go. You want the teeth of the blade exiting the piece as close to vertical as you can get them. If the blade exits lower as it normally would when the blade is set 1/8-1/4 above the material it tends to want to peel back into the plastic.
Other things to consider when cutting melamine or any type of brittlelish material like solid surface (Corian) are the type of grind and rake on the blade.
Most people try to cut melamine with wood blades. Two big issues with that: Wood blades have a more positive, forward, aggressive rake and an Alternate Top Bevel (ATB) grind (every other tooth cuts a slant in opposing directions), which essentially amounts to a controlled tearing effect. Wood is cut most efficiently with this because of the nature of the wood grain.
Blades with a Triple Chip Grind (TCG) and -5 degree rake are better suited for more brittle materials like high density plastics. The Triple Chip Grind has an alternating tooth design like the ATB wood blades but instead the first tooth cuts a swath in the middle, like a right side up triangle, and the second tooth that follows is a completely flat grind tip that cuts the remainder away. The negative rake also performs less of a tearing cut and more of a shearing action, in much the same way metal cutting blades work — in fact if you look at every circular saw blade that's designed to cut steel, most likely it is a TCG blade with either a neutral or a negative rake.
rpearlberg
Fairfield, CT
I built this bench that my lathe sits on. All 2x6 top framing and blocking for stiffness, and 4x4 legs for solid footing. Adjustable feet for leveling and a 12ga steel top over a 1-1/4" thick melamine commercial workbench top that I salvaged from a used office supply place.
Someday, when I get caught up on some other projects, I may build an all-steel bench for the lathe.
I love this!!
zoomzoomjeff
Des Moines, IA area
Mark
I love it! Because it's absolutely over-built, which is just my style!
KCobra
Clarksville, md
I've been lurking for quite a while and have really enjoyed the forum. Now, I finally have something somewhat "worthy"...
I have a small 2 car garage, which is really only a 1 car with storage on the other side. The garage is only 18' wide by 20' deep. And I have to store all the yard stuff in it as I can't have a shed. And the ceiling has 2 levels, 8'4" in the back half and 9'6" in the front half (where the doors are located).
So, I have been wanting a workbench, just haven't got around to it, plus space is so tight.
But, I really need tire storage. And I don't have wall space to hang a tire rack.
So I thought, why not combine the 2!?!?
I built a 39"x60" workbench, with a tire rack underneath. It is on casters so I can move it around. The caster lock for both swivel and rolling. It's a little taller than I wanted, but with the space needed to get the tires in there and the casters, it ended up at 39 1/2" to the top. I made it deep enough so that the tires can be all the way to the back and still leave room for my legs/stool to sit and work.
Anyway, I know it doesn't stand up to the fine craftsmanship I've seen on this forum, but I'm pretty happy with the way it turned out.
Courtney
Dayton, Ohio
Courtney - I am looking at post #677 on this thread. Is your bench frame out of 2x4's with the legs 2x6? Just curious.
Doug
Thanks!!
The frame and legs are 2x4s.
Sorry for the late reply! Getting ready to build a 10x12 shed. Came here for ideas and saw this.
Courtney
Reitwagen
Vermont
It's nice and sturdy. Everything was free except the bolts and the top.
stewie97
It's not a work bench but a drinking bench for the patio. :) This was my first wood working project and I am happy with the way it turned out.
Very cool bar....er....bench! Really digging the cooler idea!
964haus
Vancouver, BC
Here's mine.
2x4s, lag bolted to walls, toolbox incorporated into lower left, double layered 3/4" ply top with trim, inspired by GJ....
M.
jesse72
California
Here is the one I just finished. Did a build thread on it a minute ago. 4x4 legs and 2 sheets of 3/4" plywood on top.
tjwrnglr
Those of you with double layered 3/4" plywood on top, Can you give me some pointers on attaching these together and then attaching them to the frame?
peelman
Seymour, Indiana
As far as putting the sheets together, I recommend some good wood glue (liquid nails or gorilla or something) and some clamps. You can run some short screws from the bottom up, or use a short nails in a brad nailer to keep it in place while the glue sets, but if you use a sufficient amount, you won't ever get them to separate.
As far as mounting it to the frame, use cleats on your cross members or small pieces of angle on the underside of the bench to secure the top to the frame. Makes removing it / replacing it later a lot easier. I did double 1/2" screwed from the top then layered 1/4" hardboard on top with brad nails on mine and have been dreading the day I have to replace the top since. What i get for invoking alcohol in my workbench construction process. Hopefully this spring I'll be rebuilding mine using 4x4s, 2x6s, and stacked 1x3s or 1x4s for the top to make it vice-ready. 2x4s and OSB didn't make for a heavy enough bench.
5Cent
North Central, OH
Here is mine I threw together this summer. I was tired of only having the small cabinet section to work on, but was waiting until I came across the right bench top material. The neighbor had a 9' section of bowling alley that I couldn't pass up! Bench is hard mounted to the wall studs, the block foundation and is supported by 4x4's. Just need to finish it with paint, and then finish the over head cabinets. Kept it shallow as the garage is only 19x19, and kept the 2x4's around the top about 1/8" above the top service so things can roll/fall off.
Old
Top:
90%:
tjwrnglr
Worked on my benchtop today. Lowes plywood has their 4x8s painted with white primer on one side which was a pain to sand out. Left it on and did it without the glue. Used brad nails and screws to attach the two pieces from underneath, along with angle ties to fasten it onto my frame. Also didn't like the edges of the plywood showing through, so I added some trim to the visible edges for a clean look.
Before on the left, after on the right:
Waiting on stain to dry and then I'll post complete pics of everything.
67carl
California
I found this design this design (Torsion Box) and have drawn up plans for one to fit my space. Nice and strong, won't flex and is damn near perfectly flat - if your cuts are straight!
