Shop number 2....Arizona
A
AZ Glen
Scottsdale, AZ
Ac install completed today, just needs the electrical connection completed after stucco. I did not know it but code requires dual lights and a switch in the attic?
A Trane unit, it is huge, I poured a 3x3 pad and had to go back and pour a new 4x4 pad. I slid the 3x3 pad over and will use it for my compressor instead.
We had an attic fan growing up as a kid and I definitely wanted one for this shop. Having the ability to come home from work, open the windows and evacuate the warmer air via this fan will be great.
stucco materials get dropped tomorrow morning for Thursday install.
yucholian
Monroe, WA
I bet the lights and switch are required because you have mechanical equipment in the attic. I could be wrong.
moonman29
Looking good so far, but if I may give you a bit of advise, do not use that much flex duct. Do everything in rigid duct, round or square, and only use three to four feet of flex to connect the diffuser. Your fan coil (blower) will operate much better and get more airflow out of it. That flex duct is too much of a restriction for the air.
Audicon
Much of the newer flex duct is far better designed with smooth inner walls. This can actually increase efficiency in some installations.
Looking good Glen
A
AZ Glen
Scottsdale, AZ
The insulation will go in next week. I hope to get framing and electrical inspection on Monday. My electrician needs to wrap up my 3 phase.
The foam went up today for stucco. You can tell the wife unit has been priming too.
FYI...the labeled foam below has to be flame resistant/proof or whatever that is why its different.
How is this for a timeline:
7.03 Permit submitted
7.18 permit rcvd
7.24 broke ground
7.30 footer inspection
7.31 poured main shop floor
8.01 poured remaining pads.
08.06 truss delivery
08.08 lumber delivered
8.10 framing starts walls go up
8.18 sheathing completed
8.19 strap and shear inspect
8.20 doors and windows
8.21 roofing goes on
8.25 electrical ruff in
8.27 ac installation
8.29 Stucco foam and lath
A
AZ Glen
Scottsdale, AZ
I have a 20 HP rotary converter. It was at my other shop I brought it when I moved.
I forgot about the holiday, the inspevtion will have to be Tuesday.
KING CHASSIS
Hi Glen. I just joined this today. And ran onto your post right away! Very cool shop man!! Looks like alot of work is going to get done in there. Take care. Brian
A
AZ Glen
Scottsdale, AZ
Thanks Brian....Im excited about this shop, I spent a lot of time thinking about what I want.
Insulation went up today and drywall was dropped in preparation of install tomorrow morning.
A
AZ Glen
Scottsdale, AZ
Drywall started going up and looks nice. They trim the windows just short of dropping the blank out in order to keep the glass clean during mud. Proportions just don't add up without something in the room, those are 12 foot walls and 8 foot doors and 5 ft. windows
A
AZ Glen
Scottsdale, AZ
The scratch coat is on the exterior walls, they will be back in a week to put on the finish coat.
The interior is primed and the color started going on if you look close its over by the big door. Luckily my sister-n-law is a commercial painter....and yes, it was all applied by roller and brush, no sprayer.
A
AZ Glen
Scottsdale, AZ
got the walls painted this weekend and the ceiling to the carport. The garage door was hung today 12x10 with frosted glass insert. The frame is powder coated black and I had them powder coat the rails beige.
skully67
PNW
Shop looks great. Hard to tell how big it is though without stuff in there.
Nice write up in CHP magazine.
You gonna make SCSN?
A
AZ Glen
Scottsdale, AZ
Looking good Glen! Who did you use for your Garage Door?:beer:
I used Clopay. Overall the fit and finish of the door is great. I am also very lucky that my installer is very picky and understands what I want in a finished product. (Phoenix guys, Semper Fidelis garage doors is the installer)
1. we asked for nylon wheels with roller bearings and they shipped steel rollers. so now we have to swap them out.
2. We asked them to powder coat the panel hinges black so they didn't stick out like a sore thumb and it appears they rattle can'd them and the paint is flaking off.
The supplier of the door agreed to make good and swap out the parts, my installer held them accountable and I didn't have to get involved. Too bad, its a nice door but they dropped the ball on a few small items.
The Liftmaster 8500 is a great opener, smooth operation and should help increase the lifespan of the door, it slows down at the last 6" and seals shut.
Yes we are planning to run 10.5 Outlaw at SCSN, I have asked Steve Morris to fly out and help me with tuning and chassis setup, I am a rookie. The shop roof is 54x34, the enclosed portion is 40x30
A
AZ Glen
Scottsdale, AZ
finally got the power hooked up this week.
90% of the electrical is completed, including 3Phase, AC, Compressor and lights.
The attic fan is awesome, I can turn it on and open windows on the opposite side of the room and feel the cool outside air coming in. The addition of the ceiling fans makes it breezy. I had those in the old shop, they are a steel blade industrial 5 speed fan.
There is a lot of talk on this board about lighting. This area is 1200 Sq. Ft and I put 10 qty. 8ft. long T5 fixtures. I ordered the 40 bulbs by the case and they are not here yet. I needed 8 bulbs for the carport so I bought them off the shelf and put them inside so I could work last night. These things are very bright.... It is going to be crazy with 40 bulbs lit.
I was really pissed when I found the concrete guys formed the seams.
I wanted to saw cut the lines and I thought they knew that. I used
this seam sealer and it flowed very nice. I plan to clear coat next weekend.
some details too.
KING CHASSIS
Glen, Im building a new shop here at my house right now too. And the floor is saw cut. I want to seam seal the saw cut. Do you remember what you used for yours in the pic? You shop is kick ***!
A
AZ Glen
Scottsdale, AZ
Sikaflex is the product. It is very runny so it levels out smooth even
If you go back and forth when applying. I filled those with a .250
Backer rod (foam) and then went over the top with the seam sealer.
That will save a little money.
Home depot sells it
A
AZ Glen
Scottsdale, AZ
they got the final coat of stucco on the front and north wall today. Its a synthetic blend stucco that is supposed to resist cracking. It is also color matched to my sample so I don't have to paint it. A friend has it on a 10 year old house and it still looks good.
also got the rest of the light bulbs in today via special order:
T5's are freaking bright.....be warned.
