Hussar blue 95's rock. 8)
SaabGuy, Thanks for the photo! T5?
I'll have to dig up some photos of my shop for you, nearly identical layout.
The SAAB signs are EXCELLENT!
Nice garage. I suspect our paths have crossed at some point. I am the owner (among others) of the Sonett known as Yellow Thunder.
You have been busy! Looks great!
Wow, really looking good. The lean to and cupola really add to the space! Are the double doors at back for tractor parking?
Nice job.
Another MA guy here... Great place. My absolute favorite part is the wood panel siding. Truly a classy touch. I envision having the same siding style, with some kind of subtle stain.
Well done, gorgeous cars!
Waiting on the building inspector to see if I need a few other things done- like hand rails for the stairs, lag bolts in the main beam etc.
Ah yes, the obligatory handrail . . .
I just went out and snapped an early morning (low light) picture for you. Here is what I have done and I hope it works for the inspector.
Code requires the handrail to be 34" off the nose of the stair tread. I lagged 2x4's to the outside wall and used 3/4" copper pipe couplers as a standoff bracket because code also says you must be able to get the hand around the rail.
Notice I've strategically placed a fire extinguisher by the handrail.
I'm getting an inspection this week and will see if this flies since it is an unoccupied storage building.
Best Regards,
That cupola is really nice. What light did you use for the front exterior?
This a such a gorgeous garage. I would love to have your land and house some day. Are you doing any of the work yourself or is this all subbed out. Did you every think about going with a metal roof instead?
Looked great with the raw wood, but the red looks even better!
Are you planning on drywall for the ceiling or something else? Just curious because of the electrical conduit.
SaabGuy,
I have the same exact lift and am not too far away from you (near Framingham). Did you buy it from Glenn? When I bought it he had two of them, same color and I think you got the other one.
Looked at the first image of the excavation and thought this is a New England build...
Nice Garage...
