Show off your "Custom Handled Ratchet"
mrkstrk
Ok, great ideas and workmanship. The one I've not been able to figure out, how to put a handle on a ratchet with a flat handle. If you turned it on a lathe, HOW did you chuck it up and center it, if you did not turn it how did you get it in the handle?
jim1987
Quick pic of the shorter one aswell seen as the glue has dried:)
Poor pics but you get the idea:)
HOLY ****! How long is that breaker bar? 48"? 1/2 or 3/4? What do you use that thing on? 1:24 scale models? Lol
shocksandstrutz
Wentzville, MO
Nine4gmc......awesome idea, I have a new set of cman screwdrivers I dont use and I want a set of rotoheads bad..............done and done, ill post a set when I get back from my work trip
Cap'n
New Brunswick, Canada
This count?
Broke a flex head pro point 3/8 (princess auto brand), so I cut the head off and ground down a short stanley 1/2" I had and drilled it to become a long flex head. Works perfect, I use it all the time now.
4 jaw chuck in a lathe and a live center, and it's not a problem...
bodyguy16
QC, Canada
This count?
Very nice, I like the idea
Sent from my SGH-I747M using Tapatalk
shocksandstrutz
Wentzville, MO
switched it up a bit, had a black CMAN handled bit driver, drilled it out just shy of the thickness, put a HF 3/8 rotohead on it, stuck it in the press and whoala.....really like the round handle compared to the oval HF one.....might have to make a stubby version of this also, just cause i have another handle around
Zeroek
Indiana
This count?
Someone could save some serious money by doing this.
chipper
Williamsburg, va
My first custom....Kobalt long 1/4 flex which I switched guts with HF composite making it 72t and craftsman handle
stonesfan68
Houston, TX
My newest addition required some machining, so I had gj67stang (Garth) make this one up for me. It is a SK 45170 3/8" ratchet that I picked up at an estate sale for $5 with a 1/4" Cushion Grip screwdriver handle. It looks and feels fantastic- I highly recommend Garth's services. I can't wait to put it to use!
chipper
Williamsburg, va
Chipper,did u have to drill out the handle, or could it just be press fitted on?
Thanks.
I had to drill out just a bit wider and a bit deeper to fit and I don't have a press but I used a mallet and a mini sledge to fit ....and its not moving I tried to get it off right after I started because I didn't line up the cman logo right but it wouldn't budge..lesson learned for the next one
ugotd8
Denver
My SO flex ratchets had the comfort grips on them and they were scratched/cut so I used some JH Williams hard handles. Came out pretty good. I would have never thought to do this, thanks GJ!!!
Hpozzuoli
Rhode Island
Dammit. I swear I will buy a lathe just to make an sk ratchet. That is awsome.
mechanicalmoron
I can see it being nice to have one, but at the risk of being a killjoy.... looks clunky as hell, and in the way. If I need high torque and comfort in an open area, I have a 18in cheater pipe I wrapped a leather handle on.
John316
Anywhere, USA
and here is mine from earlier in the thread on a 1/2" HF
(still holding up great)
Here is my HF 1/2 Roto with my Craftsman bit driver handle. I drilled it to a tight fit and used an epoxy to seal the deal.
I have had the bit driver since the mid 90's and used it a LOT as for some reason the handle just feels good to my hand. The aluminum shank was pretty worn, so it made a perfect donor for the project.
The 1/2 Roto is actually pretty nice, but I could not stand the MAC copy soft handle it came with.
John316
Anywhere, USA
Just did my Gearwrench 3/8 Roto which had a crooked handle from the factory. Sort of annoying, but it was too well used to return, so I made use of a Williams screwdriver handle.
John316
Anywhere, USA
These are fantastic! How do you get the handles off of the screwdrivers?
For my most recent one, I slid a washer over the blade to protect the top of the handle and clamped the blade in a vise. Then used a prybar against the surface of the washer to pry the handle off without damage.
I needed to increase the handle hole size from 1/4 to 13/32. I used a step drill bit to get it close without going off center and finished the hole by eye with the handle (wrapped in a rag) clamped in the vise. I used a HF Dead blow to whack the handle on, being careful that it did not twist in relation to the ratchet body. For the last 2 inches I was having a hard time moving it, so I used my vise to press it in the rest of the way. (I have a 5" Wilton bullet with a large opening. I still had to remove the jaws for it to fit the long way).
Total time about 20-25 mins.
espyking83
Hell hole of a King Air 200
Awesome thanks! Any adhesive used to keep the handle in place?
ADSR
Anyone have a pic with a bahco dual 80 with the comfort handle off? I'm debating the SO HH swap.
rick carpenter
Huntsville, East Texas
I took a standard Craftsman 1/2" drive q/r ratchet and filled the shanks voids and the handle "steps" with JB Weld and ground them down smooth. Never did like the sharp edges but love the weight, size, and q/r function of this ratchet. Handle is about four dips into plasti-dip.
6brzina
Forney, TX
I put a new green handle on my snap on 3/8" and took the old one and put it on a Husky 3/8" roto head.
Now my ratchets match
