Shed Build Construction
D
D45
NW INDIANA
Ah ok so you are using a 1/8" thick sheet........thanks
All I can find is 1/16" thick and I am not too keen on using that
Vegaman_Dan
Pacific, WA
For an entry sill plate, I'd be tempted to just use angle iron. Cheap, easy to replace, easy to modify. Rust staining might an issue, where Aluminum won't, but it is softer so... tradeoffs.
D
D45
NW INDIANA
Angle iron is cheap..........but it will rust no matter what I do, even powdercoat it
Aluminum is the best material for this job, since I want one piece covering the entire area all the way back past the door, about 1"
I found one on Ebay for $23 shipped, but it is .063" and I think it should be 1/8"
D
D45
NW INDIANA
Some crappy pics of the rear loft and a three level storage unit for the back......its about 7 feet long
Its rock solid for heavy stuff
I have three old kitchen cabinets I'm hanging above it on the wall
Beemer533
Syracuse, NY
Yeah, I have been beating the **** out of mine with no issues. Unless you are driving cars over it, you will be fine with aluminum. I agree 1/8" will hold up better though.
Try online metals.com, they are usually pretty reasonable.
This post has been edited by the NSA
D
D45
NW INDIANA
I'm sure space will fill up fast
Wall corner trim will get done this week
I'll slowly move things in over the next 2-3 weeks and try to keep it organized
D
D45
NW INDIANA
I just got an email notification from Ideal doors
The continental brown door that I ordered will be at Menards during the week of October 27!!
Two more weeks
Allenw
NW Oklahoma
This post was a good rainy morning read, I was going to ask about siding for a storage shed since I need to replace the siding and roof on mine but I don't need to now.. It was a used shed that I would guese is 20 to 25 years old so not to bad for painted plywood.
D
D45
NW INDIANA
Thanks...........it should be easy to replace the siding and the roof
I would just re-panel right over the current siding
Speedy2222
Indy,IN
I like it! Definitely gives me some great ideas for fixing up the two sheds i have along with adding the third i had hoped to.
Allenw
NW Oklahoma
It'll be a bit more interesting then that. The old plywood has started delaminating and I want it as tight as I can get it to keep mice out so I'll take it down to the studs and start over.There is wedges, for lack of a better word, under the eave over hang around the sides to come out to get the siding off to add to the fun. I can't forget the trim to keep the old barn design so the wife is happy. I'm going to patch up some holes and get through winter and make it a summer project, is the plan right now any way.
The LP siding sounds ideal for several projects I need to do. Using the ridge vent to ventilate the storage shed is a great idea, too.
D
D45
NW INDIANA
Well I cannot find 1/8" tread plate that anyone wants to bend locally, that is not $55
I am going to try 1/16" and see how it does
D
D45
NW INDIANA
The 2"x5"x48" section of aluminum diamond tread plate came in
Was only $27ish shipped
1/16" thick but it is very rigid
I plan to use clear silicon under the plate to help seal out moisture, however it still needs to be secured
There is about a 1/2" gap between the raised treads
I can't counter sink since the plate is thin
Do they sell really thin button cap screws that I can sink 1" into the wood subfloor?
I just don't want the head of the screws sticking up
glider
Flint Michigan
Your shed is looking good. You could use some liquid nail. If it comes up down the road. Put some screws in it then.:thumbup:
D
D45
NW INDIANA
My concern with gluing it down, is what happens if it gets damaged and needs to be replaced?
It would most likely rip up the treated plywood flooring, compared to just unscrewing it
Gorille Glue is some tough, nasty stuff!!
Will Liquid Nails hold it solid?
BEAVO
wash ch ohio
nice build...have you looked at a total cost yet? were needing a shed and i have been wondering if i want to buy a cheap shed kit,get a amish shed or build one myself....
RickP
Annapolis, MD
The liquid nails will definitely hold it, but it will also rip up the plywood if you remove it later (I've been doing a lot of demolition lately and it's really hard to get it off without hurting the plywood). The caulk should be fine for your threshold, along with a couple of screws at the ends. You could also add some screws along the front vertical edge to make it really solid. You might be able to countersink that thin metal by deforming it instead of removing material. I would try a punch and a big hammer somewhere near the edge of the metal to see how it works.
Nice build - lots of good ideas here that I'll use for my shed. Thanks for posting.
D
D45
NW INDIANA
No final cost yet..........
I am still waiting on the roll up door to be delivered, need to install the outside wall corner trim, trim around the door opening, and install the threshold
BEAVO
wash ch ohio
i have a question d45...do you have underground electric running behind the shed? i have a 10 ft variance on my property.....if i put the shed where i want it it will be sitting directly above the wires...... so should i put it there anyways? if i do how easy would this shed be to move?
D
D45
NW INDIANA
I have underground telephone and cable lines.........no electric
I have a 7 foot easement, between the shed and my fence
I did not build on this easement
D
D45
NW INDIANA
With a 10 foot easement, I would build on half that
Would not be that hard to move it or pull it out of the way, if need be
D
D45
NW INDIANA
I will hopefully get around to building the removable ramps also this weekend, along with installing the diamond tread plate for the threshold
I am thinking about building two smaller side lofts, built off of, and attached to the rear loft
This way, I wont lose any natural lighting that a front loft might block
BEAVO
wash ch ohio
i went out there and i still had marks where oups came out and marked electric phone etc lines for when we got our fence in..... looks like the power lines are only about 5ft off the property line so i think i will put it there!!
D
D45
NW INDIANA
My vacation ends November 12TH.........it will and has to be completely finished by then
Not much more to do.......maybe 2-3 days of part time work
Beemer533
Syracuse, NY
Looks good!
Here are some truss head screws that would be relatively flush : http://www.mcmaster.com/#93406a255/=uc329c
They are for metal really, but they should work..
You might be able to find something similar locally..
D
D45
NW INDIANA
Brown roll up door is scheduled to be delivered tomorrow at Menards
I bought a small tube of Liquid Nails ad clear silicon caulk for the diamond tread threshold
Exited to get this shed project done, so I can move on to my garage!
D
D45
NW INDIANA
I picked up the Ideal roll up door today, and returned about $70 worth of misc leftovers to Menards
Since it was warm out, I glued down the threshold
Before:
After:
RonRock
Iowa, USA
It's a shed not a high rise apartment. And from what I can see the rafters are in line with the studs. So a double top plate is not needed.
