Astro Pneumatic Tool Company
K-Dog
Millersville Maryland
Well, to save time the tool is 0.5HP - which should be getting the job done on a 3" cut-off tool as many competing designs are below that power rating. On an in-line tool the ergonomics allow you to push it more quickly through material then approaching it from a 90 degree - so that's some of it.
If there's a general consensus, opinions about a tool, or issue with it - we try to address amazon reviews directly and help if we can. But single or even a handful of reviews can often be.... well off base some times.
We've had people send in this very unit saying it wasn't very powerful, see nothing wrong and have to inform them of the power adjustment knob on the side.
__________________
yeah I took the review with a pretty decent grain of salt. I have been using AP stuff for years and years. I know their quality and standard quite well. That cut off wheel is on my Amazon wish list. My birthday is in July so it might be a wile....
Makes me think of the guy who destroyed his transmission when he shifted from D for dirt to P for pavement
Might be the funniest thing I have seen all day. :rocker:
A
Astro_Pneumatic_Tools
South El Monte
Below please find information on some BRAND NEW items that we are bringing into our product line. These items feature innovative developments in the evolution of tried-and-tested tools. They are all composed of high quality, durable materials, providing dependability and longevity of use. These items will be available by the end of February/early March, and are sure to move quickly!
(800) 221-9705
[email protected]
www.astrotools.com
A
South El Monte
Good Morning Everyone,
Let's take a closer look at one of our hot new tools!
Item # 7763, the Astro Digital LCD 12-24V Circuit Tester.
This tool has a clear LCD display for accurate voltage readouts. It has a small, ergonomic design for easy use in confined areas, and is great for use on cars, boats, trailers, vans, RV's, motorcycles, airplanes and snowmobiles. It is used to check electrical circuits and accessories on all 12~24 volt systems. The needle-sharp stainless steel probe allows for easy piercing. Cable length : 11ft; Voltage : DC 12-24V.
http://www.astrotools.com/index.php/new-products/digital-lcd-12-24v-circuit-tester.html
800) 221-9705
[email protected]
A
South El Monte
Check out our Item # 9421 - Multi-Angle Internal/External Snap Ring Pliers.
- Engineered for professional use, tips made from heavy-duty C45 Tool Steel
- Quickly change out tips or from internal to external use
- Three interchangeable sizes of 270 degree adjustable and locking tips
- Tool and tips both feature machined teeth to prevent movement once angle is set
- Firm and positive internal to external adjustment
(800) 221-9705
[email protected]
http://www.astrotools.com/index.php/multi-angle-internal-external-snap-ring-pliers.html
https://scontent.**.fbcdn.net/hphotos-xpa1/v/t1.0-9/12876_10153070984697383_6113365931736207185_n.jpg?oh=6c63b995012a0c5bf32cc77f85b9c698&oe=5572AA00
https://scontent.**.fbcdn.net/hphotos-xpf1/t31.0-8/11026073_10153070984802383_5787204762871738562_o.jpg
A
South El Monte
A
South El Monte
Happy Friday everyone!
Hope the day goes by nice and smooth for all!
Check out some information on our newly added Radiator Pressure Tester Caps, Item # 7858541 - No. 41 Radiator Test Cap (for Late Model GM and Ford) AND Item # 7858542 - No. 42 Radiator Test Cap (for Late Model BMW and Land Rover). These test caps work with the Astro Pneumatic 78585 Universal Radiator Pressure Tester and Vacuum Type Cooling System Kit. They are constructed for long lasting use.
(800) 221-9705
[email protected]
http://www.astrotools.com/index.php/catalogsearch/result/?q=78585
Shopteacher
Grosse Pointe, MI
Thanks for getting back to me, I don't have quantity or part numbers, I was only wondering if there was a program in place as I am tooling up a brand new facility....many of the manufacturers have vocational ed programs for students/programs as a way of introducing the tools to the student while they are enrolled in school (which helps significantly with the shrinking budgets we all deal with), in some cases, the manufacturer sets pricing as "vocational Education" pricing and the industrial supplier passes the savings on to the student/institution...
A
South El Monte
Check out some information on our newly redesigned Suction Cups, Item # 9038 - Single Suction Cup AND Item # 9039 - Double Suction Cup. These suction cups are built with a lever lock system to ensure a secure grip. They are ideal for one person auto glass repair, and can also be used for small dent removal. They are constructed of a high impact plastic, allowing for sturdiness and durability.
(800) 221-9705
[email protected]
Have a great day!
https://scontent.**.fbcdn.net/hphotos-xpf1/v/t1.0-9/11071047_10153112078247383_7232527654892184301_n.jpg?oh=aa3834bb84c5255c01f9d5e2abb84361&oe=55B15858
A
South El Monte
Astro's new 21FX 21 LED Waterproof Flex Light With Magnet is ideal for working under the hood, changing a tire, wiring a home theater, or switching on a breaker in your home fuse box. The base magnet and hook ensure ease of mounting and it is great to have in case of emergencies. The potential uses of this light are endless. It can be bent, folded, and wrapped/hooked around objects. The user can place it on a flat surface for use as a freestanding light, or adhere it to most metal surfaces for convenient use. The bright light beams exactly where you need it to, providing maximum visibility. This light is composed with waterproof silicone, and has 3 different settings (7 LED Strip, 21 LED and 21 LED flashing). These settings can be activated by pressing the on/off button. This light is perfect for hands-free use and requires 3 AAA batteries.
(800) 221-9705
[email protected]
A
South El Monte
iajonesy
Iowa
A/P Tools,
Hi Charles. I've read through most of the posts since you've been on here and I have to say that I admire you for your staying power. At first I thought you might just make a quick appearance,hype a few products and then vanish into the night.I was very wrong and would like to thank you for the way you have handled each and every post directed to you
My question for you is this,do you have a complete online catalog or must I go to one of your distributors for product info and pricing? I don't have any particular need right now but might in the near future.
Thanks again for your help to all of us here on GJ.
Mike
A
South El Monte
A/P Tools,
Mike
Hey Mike,
First off, thank you so much for the compliment and the recognition.
In my mind, it is the tool users whose opinions and views mean the most, so it is truly our pleasure and honor to be active in a community as great as the GJ.
To answer your product question, our website has product info for all products (including discontinued, and closeout which are labeled appropriately).
In terms of pricing, a lot of our distributors post our products to Amazon, so you can always find a good price there.
Along with that, we have plenty of distributors who sell online as well.
I hope this answered all your questions, and thank you again for your support.
Have a great day!
K-Dog
I used my AP DS1000 door skin tool today.
I smiled the whole time. I have tried just about every door skin tool there is. This one os the best.
A
South El Monte
Astro's new 1SL Rechargeable Pocket LED Slim Light with Magnet features a 3-hour work time and recharges its 1000mAh lithium-ion battery with the included USB cable. Designed with a COB (Chips-On-Board) style LED, the light source illuminates as a single 90 lumen light strip instead of independent LEDs on a chain. Also incorporated into the compact 6.25" long design is a base magnet and clip attachment. Contact us for a distributor near you!
(800) 221-9705
[email protected]
https://scontent.**.fbcdn.net/hphotos-xtp1/t31.0-8/10630606_10153177509677383_5395247903205109553_o.jpg
gipraw
Cypress, TX
Just picked up a 1432A Riveter and a 78205 Steering Knuckle Spreader from Woot. $12.99 for the spreader is a steal, imo.
K-Dog
Good Morning everyone!
Hope all of us had an amazing weekend, and are ready for an even better week!
We are receiving a ton of new items in the coming months, so make sure to keep an eye on the "New Products" section of our website for all the info you will need!
http://www.astrotools.com/index.php/new-products.html
(800) 221-9705
[email protected]
www.astrotools.com
Finally test drove this thing.
Decent power. The regulator is a nice touch. I actually ran it fairly low for the most part. I was grinding out spot welds on a chevy truck bed for what its worth.
The tool feels real stable and well balanced. It doesnt feel jerky when you squeeze and let off.
Nice job. :thumbup:
If I had one complaint it would be that it is pretty dang loud. And I am saying that with ear plugs in.
A
South El Monte
Decent power. The regulator is a nice touch. I actually rant it fairly low for the most part. I was grinding out spot welds on a chevy truck bed for what its worth.
Nice job. :thumbup:
It definitely is one of our louder air tools. I'm working on a new inline cut-off tool right now (think bigger, more power:rocker:) and even with a few different types of muffler designs, it still fits right in with the 209 haha.
__________________
Chris P.
Product Manager
Phone# (800)-221-9705
image.php
A
South El Monte
Check out Astro's new 9421 Multi-Angle Internal/External Snap Ring Pliers are engineered for professional use. The tips are made from heavy-duty C45 Tool Steel and are constructed so the user can quickly change them out, or change them from internal to external use. This tool includes three interchangeable sizes of 270 degree adjustable and locking tips. The tool and tips both feature machined teeth to prevent movement once angle is set, and the tool is constructed with a firm and positive internal to external adjustment. Combine the utility of an entire 10pc kit without the need to find the right pliers style for the job and reassembling them for internal use. Tip Sizes: 2.3mm, 1.7mm, 0.9mm
(800) 221-9705
[email protected]
A
South El Monte
Is the DA variable speed, or six set speeds? What is the price point for the DA?
Hey gipraw,
Our Sugg. List is about $250.
A few distributors have purchased it already so it should be appearing online any day now.
The speed settings are on a wheel and is adjustable.
Please see the Product Info Sheet (http://www.astrotools.com/pdf_info/3058.pdf)
6MocoA
Fairfax, VA
We hope everyone is having a great week so far!
Stop by our website for New Items, Warranty Information, and the Find A Distributor feature!
(800) 221-9705
[email protected]
https://scontent.**.fbcdn.net/hphotos-xpa1/t31.0-8/11181788_10153213322222383_6416576780433058183_o.jpg
Charles,
Thank you.
Im getting the circuit tester for no other reason than I already have many of your products and have been impressed with the quality vs. value and that the photo you used is that of a Coyote Mustang engine bay! :beer:
aka Larry
Eastern, NC
Hope everyone is having a smooth week so far!
(800) 221-9705
[email protected]
https://scontent.**.fbcdn.net/hphotos-xtf1/v/t1.0-9/11255222_10153239833757383_8472349006718261303_n.jpg?oh=aeaeb66606bb35dda2c95f2e9702092f&oe=55C7B71F
I have the above and I really liked it, but if it had a bleed down valve I'd love it. Might be something you want to add in the future to this tool.
A
South El Monte
That would be our Astro shop car and guinea pig. Many parts and Astro tools are being thrown at it this year. Will be piloted by our Product Manager Chris this year in HPDE events as well as SCCA and NASA events next season.
__________________
Astro
image.php
e-Mail: [email protected]
Facebook: https://www.facebook.com/AstroPneumaticToolCompany
YouTube: http://www.youtube.com/user/AstroTools
LinkedIn: http://www.linkedin.com/company/astr...c-tool-company
Twitter: https://www.twitter.com/AstroPneumatic
Pintrest: http://pinterest.com/astropneumatic/
dudutzu905
It does have a bleed down function, you squeeze the lever only half way and it lets air out of the tire:dunno:
