Show us your welding projects
ndr1968
Oklahoma
I just posted this over at Welding Web and I thought you guys might like to see it too.
I have been fighting those dam "government disigned" gas cans for a long time now and I think this just may be a workable solution.
Problem: Cheap plastic gaskets that came with gas can caps shrink and harden after one season and will not reseal.
I had some .125” wall tubing of just the right size on hand so I sharpened the end and welded a big old washer onto the other. Then I got some cork-rubber Felpro gasket material at the auto parts store. I cut off some strips of it and took it with the new tool over to my new shop press to see what would happen. It worked great! Problem solved.
I really like the fast lift bottle jack I used on the HF press. It makes the press much easier to use. I got the jack at Northern Tool for $60.
ndr1968
Oklahoma
Here's the rest of the photos.
Robert Hall
Utah
How did you do the copper plating?
I grabbed some copper chloride from the darkroom and rubbed it on the heads of the spikes. CuCl is pretty active so I knew from experience it would leave a fair amount of copper on the steel.
zmotorsports
Northern Utah
Last night's welding task. Tail light boxes for my utility trailer project.
Backside.
A few of the welds on the tail light boxes.
Mike.
zmotorsports
Northern Utah
So overkill, I love it!:thumbup:
Those sure look sweet Mike. Better have a good anti theft system on that desirable trailer.
Thanks Claude. Ya, I should probably invest in a good tongue lock.
My wife came out to the shop and asked why it was taking so long to complete. I showed her some of the small details that I was adding and she told me it wasn't a "show trailer" and I wasn't going to want to haul anything on it, or once I did and scratch it I would be heart broken.
I figured it is hopefully going to be the last utility trailer I build/own so it may as well be what I want.
Mike.
sanddan
Oregon
Mike.
Mike,
I built a 6x10 trailer similar to yours 20 years ago and only had to rebuild it last summer. You will be glad you are putting such care into the build as you will enjoy it for many years to come. Mine is also 2x3 tube construction and I also hung the fenders like you did (I did cope the tube to the fender before welding), it's a very sturdy mount and also good looking. I really like the tail light mount box's, a great project to practice the tig welds on. Thanks for sharing.
Dan
mat_GTI-R
My very first welding project was fabricating a seat bracket for my car, from design:
https://www.facebook.com/photo.php?fbid=10153758933970472&l=0a78e71279
to the finish product (I did paint it black before installing):
https://www.facebook.com/photo.php?fbid=10155377756365472&l=251c481f84
Then I did the typical welding cart:
https://www.facebook.com/photo.php?fbid=10155377756375472&l=c5720ecd1e
A few custom brackets for the car:
https://www.facebook.com/photo.php?fbid=10155377756460472&l=ced636538c
Small coffee table project with custom hairpin legs:
https://www.facebook.com/photo.php?fbid=10154784803780472&l=2cbff6f268
Custom bench for the dining room table, I can't take credit for the wood work and the bending of the flat bar, done by others... I just welded the legs together and a whole lot of grinding:
https://www.facebook.com/photo.php?fbid=10154695440335472&l=a40199e8d1
zmotorsports
Northern Utah
Mike,
Dan
Thanks. That is a nice looking trailer, I would love to see some more pics of it.
Mike.
ndr1968
Oklahoma
OK, this isn’t really a “tool” or welding project. It’s just a method I’ve come up with to save peg board space. I keep a set of metric and S.A.E. box end wrenches on two pegs on the board. In the photos I try to show how I use this system. It takes a little practice. I’m right handed so south paws may want to change this accordingly. First I figure out what size I want, then reach with my left hand and grab all the smaller wrenches that are “in front of” it and pull them all off the peg. With the left hand still holding the stack of wrenches use the right hand and remove the wanted wrench and lay it down on a handy surface. Then use both hands if necessary to align and replace the stack of wrenches back on the single peg. Use your selected wrench and when you are ready to replace it just reverse the above steps. The hardest part of this is to remember to replace the unused wrenches RIGHT THEN, don't lay them down! or you will have to put them all back one by one and that's what this method tries to avoid.
ndr1968
Oklahoma
Rest of the "Peg board space saver" photos:
64Trvlr
Northern AZ
I needed a place for a generator and spare tire for my camper.
  • 11-camper bumper pass side 9:13.jpg
  • 10-camper bumper dr side 9:13.jpg
  • 12-camper rear bumper 9:13.jpg
  • 8-camper bumper coming along ok 8:13.jpg
  • 7-camper bumper progress 8:13.jpg
  • 5-camper bumper begining to commence to begin 8:13.jpg
  • 4-start of camper bumper 8:13.jpg
classicJackets
SE Michigan
Did a few small things as Christmas presents and an excuse to use my new (first) welder. None are that impressive or hard to do, but i had all the material for free so why not :)
Tea Light candle holder and rebar letters for my sisters' initials. Ignore the vise..
ndr1968
Oklahoma
Fast and dirty mounting bolts out of all thread.
great white tj
Ocala Fl.
I am trying to fab up a small rake, all I need to do now is put on the tines. The last pict. is what I should end up with the tines.
great white tj
Ocala Fl.
Not bad for the first lift... It did not move at all.
gymbo39
So Calif
Welding cart I built to move new 115v mig around in the yard to weld up fence panels
Broadie
SE Alaska
I built this boat last winter in my garage with a Hobart Ironman 230.
I just got around to turning the cradle into a trailer. Took me about a week of after work hours and weekends. Happy with how both turned out as they were my first big welding projects. The Hobart worked great, although the spool gun has some issues.
RivennHewn
PNW
Great looking boat!
Would love to see more pics of the build.
What's your intended purpose for the boat?
Running rivers, fishing, or just out playing in the rain?
akdiesel
Wasilla, AK
Nice project. A co-worker in Fairbanks is finishing up his 12' with a Skidoo 155 hp jet motor. We plan to take a run up Montana Creek or Little Su this May to try it out.
Hot Chop shop
Las Vegas
Very cool project and design.
ndr1968
Oklahoma
I'm in awe of you guys that just jump in there with both feet and "git er done". No matter what size the project.
Boosted1
Georgetown, KY
Broadside,
Wow! Really! Only 1 week of after hours work to build that?
More details please. Looks very interesting.
It could have its own build thread.
Did you get plans somewhere or make your own?
spent21
Franklin, Tn
I'm diggin the bear trap. that's cool.
bamf
Wake Forest, NC
What issues did you have with that spool gun?
zmotorsports
Northern Utah
Nice. Very impressive work. I am not a boat fan, but I can tell hard work, determination and drive when I see it. :thumbup:
Mike.
sanddan
Oregon
broadie,
Could you share some more details on your boat? Did you get a set of plans somewhere for it? I really like the lines, very nice.
KMinAF
Fairview Utah
I don't see many of these in the parks or schools anymore, so with a bit of scrap angle a
2x6, some paint and a couple of bolts and a couple hours work my grand kids can experience a bit of the "good old days"
RivennHewn
PNW
I don't see any USB ports.
Where do you plug the screen into?
Broadie
SE Alaska
broadie,
Thanks, No plans really, but I copied a few other boats in town that were a similar design built by a local boat builder. I think I'll get a thread going with pics of the build.
