Between 265 & 485 SQ/FT The 12-Gauge Garage
Guster
Auckland, New Zealand
Next time you can save more by using cotton fabric instead of glass if you won't be using epoxy. It will be just as strong and have an even better finish. Your average cotton bedsheet is about the same weight/strenght as 3oz glass and the weave is so fine that it does not form pinholes. It does not sand nicely but great of an out of the mold coloured finish.
gtr cook
Kent, England
Really impressed with what you have produced and the tinkering you have done to get a good part.
Please make sure there's a part 3!
Squankum
Southeast
Jack, great new cover story on the new Road & Track about the Singer 911.
IMHO, lots off frooty silliness involved, and I continue be amazed at other peoples' ideas of "light weight", but 4.0 liters?! That's very hard to ignore!
Have you considered slide throttles or individual throttle bodies? Perhaps you could cobble something together from junkyard throttle bodies, or, perhaps motorcycle junkyard ITB's.
I once knew a fanatical autoxer who had his own custom slide throttle made, all it took (kinda) was a machinist, some aluminum plates, and maybe some funky coating on the throttle plate itself. You may not know any machinists locally, but on GJ, I'm sure there'd be volunteers.
_
Grizz1963
Rochester, KENT. UK
I wish more people could see your work Jack.
As always, I continue to just lift my jaw from the floor.
That wing and the whole process is rather awesome.
J
Jack Olsen
Los Angeles
All true. But it's hard to beat the reliability and lifespan of a stock motor. But right now I'm trying to work out some approximation of the benefit that would give me -- by using my kids' toys. I got a steering wheel to go with his PlayStation, and I'm trying to tune a 911 (as close as I can get) to match my own car. That way, I can test the effects of adding horsepower (or other stuff) virtually, if I can get it to work.
Here's a video showing my fumbling starting point. Maybe it will lead to slide valves. But I'll want to see some cost/benefit data before I jump, even if it's from a kids' game.
Thanks, Grizz! I keep thinking about your teardrop tailer, and thinking of whether I could do something similar along the lines of the one in this video -- but with my 911.
Brompty
Kent, England
Hi Jack
Love the thread, the garage and the car; I picked it up through the Petrolicious video more than a year ago.
Have you also considered your also of more speed from another angle? You have invested so much time and money in the car that maybe you need someone else now to drive it to see if the car can possibly get to the time you wish to achieve. I think endless laps on a video game is a great way to get all the practice you need to achieve perfect lines on the track. But in the same way that the fastest car in the world is a hire car, perhaps you need someone that does not care about the car to be able to get the most out of it?
Nevertheless, inspirational stuff as always
Squankum
Southeast
I have returned, with links with pictures!
Steve's custom slide throttle on his Fiat:
http://www.network54.com/Forum/12159/message/1199972518/History+Lesson
Steve talking about the motor's mighty output (well, considering):
http://www.network54.com/Forum/12159/message/1200060118/Slide+Throttle+and+DFI
He was aiming for torque, and you don't have room for runners that long, but you're also looking for some shorter runners. BTW, handy fellows have built their own horns using a hydraulic press. (If only you had room for a lathe...)
Not Steve but somebody else showing their DIY slide throttle build, looks within your skill set.
http://www.rotaryeng.net/slide-throttle.html
(I think I'd put the injectors downstream of the slide, for safety reasons.)
The holes in the slidey plate needn't be round at just off-idle. Some go for a < shape, I think. See:
At WOT, nothing but round/hole/nothing there, of course.
Squankum
Southeast
Uhhh... I just discovered you probably have VarioRam intake manifold. :tard:
So now I don't know what to think! It is neat...
If this was just a race car, I'd build for the RPM range you're really using on track (recording tach, or in your case, really good video) and that would be horns, and you'd save a bit of rear weight, but...
Yeah, it's also a street car. That's got to be a great thing on the streets, with the extra torque.
http://vwparts.aircooled.net/VDO-Extreme-11000-RPM-Recording-Tachometer-p/v333937.htm
This can record full road race laps, and it's priced to not sell.
J
Jack Olsen
Los Angeles
Teardrop Camper -- Structural Thoughts
I'm thinking about building a small teardrop trailer to pull behind my car for camping trips with my kids. (I know a pop-up camper would offer me more space, but there are a few things about teardrops that work better for my situation.)
The basic design of the teardrop goes back to the 1930s, and usually involves a converted utility trailer with a wood-frame structure built on top of it. Like this:
Then it gets skinned with aluminum sheet, and sometimes even the homebuilt ones come out looking pretty cool. The back usually opens as a hatch for a basic galley setup.
So that's all well and good -- and tried and tested. But these things often end up weighing close to 1500 pounds. And they also sometimes have weather-related problems, over time. I think part of the problem is that they tend not to be garaged. And they're made with wood.
I would like to make one that's much lighter. And I'd like to make it with no wood at all, and as little steel as possible.
To that end, I've been looking at material samples and testing adhesives with them. Right now, I'm thinking about using Aluminum Composite Panels (which is basically polyethylene Foam Core sandwiched with aluminum) for the walls and ceiling, and corrugated (polypropylene) plastic for the floor. I'd like to use aluminum to connect the floor, walls and ceiling, but I'd like to avoid (as much as I can) a traditional frame for it. And I think I can do away with a lot of the reinforcement typical in an open utility trailer's bed, since the box structure of the camper would provide strength for the floor.
I'm also considering using foam EPS or XPS insulation sheets, adhered to the aluminum composite panels -- both for insulation from cold and heat and also to further strengthen the panels. I will probably use 4mm corrugated plastic for inside the sleeping cabin, since I can cover it with self-adhesive vinyl and make it look like anything I'd like (and hide the wiring and such).
My concern is making a structure that is strong enough -- which is to say it won't pull itself apart under high-speed pothole impacts and the constant vibration and other stresses of being towed.
On the one hand, it seems like the monocoque aspect of the design should be pretty strong without much reinforcement. Using structural adhesives to create uniform adhesion along all the juncture points will distribute stress pretty broadly. And the way the leading edge of the structure curves as one piece from wall to ceiling seems like it would be creating a fairly strong unit, along with walls both fore and aft that will provide more lateral strength.
So in doing my materials/adhesive tests, I put together a toaster-size box that shows my current thinking. The square tubing frame piece along the top edge is one of the things I'm wondering about. I know that it's a stronger shape than L-shaped angle stock. But I wonder if using 1-1/2" angle stock might be better than 1" square tubing, considering the big picture of the whole structure.
Right now, I'm supporting the corrugated plastic floor with angle stock running along the walls. My thinking is that the trailer supports the walls, which in turn support the floor and ceiling. But the floor itself doesn't need a huge amount of support.
Here's the walls and roof:
And the floor being glued in:
And the whole thing, albeit without the front or rear sections.
I don't have much business making structural engineering decisions. But that doesn't stop me from trying to figure this out -- hopefully with the help of some guys who actually know the stuff.
The forces the thing will be subjected to seem primarily to be a lot of vibration, and then some pretty hard lurches in being towed. I'm going to have the tongue and axle be steel, because aluminum will crack if it's flexed too much. But everything else I'd like to be plastic and aluminum.
Any thoughts?
stsmike
Orem Ut.
Re: Teardrop Camper -- Structural Thoughts
Jack,
I think you are on to something here. Can you post some information (specs or brochure) about the materials you are using? This would help a lot in calculating weather or not it will work.
Thanks,
Mike
Krash Kadillak
Springfield, Oregon
You're way beyond my expertise in construction materials (I have none), but having owned both a 5th wheel (27') and a regular (23') travel trailer, I can comment on your requirements..... IMO, a teardrop like you are planning is only fit for 2 people. I don't see how you are going to accommodate sleeping arrangements for all 4 of you. A teardrop is also fairly inefficient as far use of space is concerned. Sure, it's more streamlined, and gets you excellent fuel mileage with your tow vehicle, but square off the shape and you get A LOT more usable space. You need something more like this:
2003-Jayco-Kiwi-17A-Hybrid-Travel-Trailer-Lightweight-Clean-Unit-Concord-NC-17-NC-16662.jpg
kerrynzl
Tauranga, New Zealand
Any thoughts?
Jack, I built an enclosed trailer using the above method and draped it over an Angle steel frame [flange up to get the floor lower]
I used furniture tubing and glued alloy composite signboard to it [ the pre-finished type ]
The biggest issue mine had was it was too lightweight for a large trailer [ the wind made it unstable when towing empty ]
What you are building is a true "monocoque" structure which is very strong.
You won't need any bracing in the sides only around the rear hatch
Go and buy a "Harbor freight" gear driven ring roller for about $75-00 and get a machinist to lathe the rollers for 1/2" furniture tube.
http://www.harborfreight.com/catalogsearch/result/index/?q=ring+roller
This will help you get the corner frames rolled evenly
Glue the sides and the top to the frames using "Simson ISR 70-03" Urethane adhesive and use either Clecos or countersunk pop rivets to hold it until the glue cures.
Cap it with thin aluminium angle and glue this as well.
You can never have enough clamps.
I did a thread here building a car hauler where I used the same glue to bond diamond plate to the frame [I've never had a failure with it ]
Carves
Central West NSW .. Australia
A traditional teardrop, with an airfoil, would compliment the 911 nicely, during lap times .. :D
Not discounting your desire for a teardrop style, or the build challenge, but .....
... Looking at the model you're building, I would suggest forgetting the curves and stay with squares and angles.
This is a little, light weight jobby, I drag all over the place.
Its on a steel chassis no stronger than one of your HarborFreight, kit trailers, with a timber frame cabin, 8' x 6' x 4', plus the 2' high poptop.
Factory designed/built, for onroad use behind a small 4cyl vehicle ... max weight 750kg.
It normally has a lower stance, but I remounted the axle under the springs for some offroad clearance.
Way more versatile than a teardrop can ever be.
A build material worth looking at - is stuff called MonoPan, A euro product I think ... Becoming common in the caravan and truck body industry down here.
Google will bring up some aussie DIY caravan builds detailing using it.
Looking forward to seeing what you eventually roll out of the, 12 gauge garage.
MushCreek
Upstate South Carolina
I'm thinking about building a teardrop using Klegecell (foam) covered in epoxy and fiberglass cloth inside and out. They build boats that way, and think of the beating a boat can take. Never a problem with leaks, either. Not cheap, though.
I designed mine with a seam halfway up, all the way around. I'd put a hinge at the front, and make it so you could raise the back up for standing headroom when parked. Canvas panels would fill the gap when opened. In nasty weather, I'd just leave it in the closed position.
54FordPanel
Fort 54, Littleton, Co
Oh boy, a Jack Olsen built camper trailer….this should be good.
I wouldn't start with a HF trailer though. JMO.
I can't wait for the build thread
:thumbup:
coby65
Monterey Bay area
Jack can't help you with the teardrop......no experience but I can recommend the suspension to put under it!
http://timbren.com/axle-less/
I just install in my expo trailer and am very impressed with how smooth this rides. Towing behind a stock 15 Jeep Wrangler 4dr from Monterey to Truckee I never knew it was back there. I have been pulling some type of bumper pull or gooseneck my whole life and never not been beaten up by a trailer in on rough roads. This pulls like a dream.
G McKay
In the garage in Bremerton
Those are really neat, Jack. I have thought about building one myself from time to time. If you get on FACEBOOK they have a club you can join and get lots of tips. I like them so much I bought a book with hundreds of pictures of them from over the years. And you can GOOGLE them and get a lot of images of them.
Go for it. You'll probably enjoy building it.
:thumbup:
Voi
Western South Dakota
In the past year or so I watched a TV show where an architect and her farmer fiance built their dream house for their combined family out of foam. Not SIPs and not ICFs but what appeared to be expanded polystyrene wall and roof panels with steel caps on ends that would connect to each other or to the slab. Presumably then coated with some sort of mesh and polymerized cement based coating.
Since then all of these Tiny House shows have taken off and I often wondered why somebody hasn't used this method to build these tiny houses on trailers, which is basically what you and Jack and considering with the Tear Drop.
It took place in California and I just did a quick Google search and couldn't find anything.
Anyone remember that show or the builder name?
driver
As the current owner of a trailer using a foam fiberglass sandwich particular attention has to be made on sealing all the panel joints to avoid water infiltration de-laminating the panel. Mine has leaked causing structural failure of the roof and side walls. I am considering re-panneling the framework using this method:
stomperxj
Jack a lot of the strength comes from the front and rear bulkhead making it a box essentially. The galley bulkhead adds side to side stiffness. If I were to build another teardrop I'd do composite panels and use aluminum angle and/or sealed wood 1x2s for structure where needed hidden inside away from the weather. Making it all out of wood is not a problem if you spend the time and money to put a layer of fiberglass cloth on the outside. Makes it waterproof.
There's a guy on the tnttt.com forum that made a teardrop from 1" corrugated cardboard with fiberglass on the inside and outside. Very strong and super light.
Steel frame and all wood body on mine. I should have fiberglassed it but could not afford it at the time:
Z48LT1
Space Coast
I've long thought scaling down a Shasta "canned ham" camping trailer from back in the day would be a cool look, and give a lot more cubic feet inside, if only by enclosing the wheel wells.
Zeke
I don't consider myself to be an engineer but I do have some experience with small trailers, mainly for go karts. IMHO, some weight and COG are important for a nice pulling rig. So I would not be so fearful of a steel frame. I think the benefits outweigh. The other thing is the tiny rims and tires put on the little trailers do them disservice. What you want is a 14 or 15" rim with a tall tire that you can run with low pressure. Helps the suspension a lot. Also, many trailers are sprung with the maximum load in mind. The camp trailer will not come near max load so calculate that and take out a leaf or so.
I would even consider some kind of air ride since there is so much of that kind of stuff around. Think of it, a Citroen type of suspension where you drop the trailer down low on smooth highways for less drag. Having a beam axle going under the trailer frame is the last way I'd consider doing this.
Might be the simplest, but not the best by any stretch. There are some nice IS pics here:
http://www.expeditionportal.com/for...s-and-small-hard-sided-campers-no-home-builds
And this: https://encrypted-tbn1.gstatic.com/...r39niUJOyv_u_ePAKJ6RiQXd_A5p_ARiSwRkhwK0X5wQp
Dutch01
Kempton Park, South Africa
I also have the idea to build a teardrop in the back of my head as kids are all grown up now. I already have a registered utility trailer in crappy condition that will be the donor, dut I saw another design called a BRT that I like as well.
Andre
bczygan
DETROIT! Arsenal of Scrappers
Jack,
This is exactly the little mind exercise I did a while back, for personal entertainment.
Like you, I was thinking, "What if the ceiling, wall and floor panels were a sandwich that provided insulation, exterior waterproofing, interior finish and also structure.?
My first thought was panels that had a foam core with either a plastic or aluminum face on the outside and a plastic face on the inside, all bonded together.
Then I wondered if there was a foam panel that had a skin that served all three purposes. Never did the research.
I thought of other difficulties. How do you connect the wall and ceiling panels? And the wall and floor? Do you have mechanical connections? Are they continuous? Or do you bond them together chemically or with a glue or heat?
And the floor panel. It needs to have different characteristics, as the loads are different.
I planned for the floor panel to be load bearing and structural, such that it did NOT require a frame under it. But you would still need a way to transfer the loads from the trailer and it's contents, down into the axle and wheels/tires. Perhaps a plate or plates that go over the mounting points to the suspension and are bonded to the floor panel.
I also wondered about the comparatively heavy steel springs, axles and wheels and wondered if lighter aluminum components were available. I looked into the configuration where a trailer is connected to the tow vehicle with two hitch points and then only one wheel is mounted under the trailer. This would reduce running gear weight.
I also thought about larger wheels and tires. Something like motorcycle type ones with just a few hard spokes.
Then I got to thinking some more and wondered if you could use carbon fiber in a mold, to create the shell in one complete piece and then spray coat the inside of it with a foam insulation whose skin would be the finished inside surface. The shape would be completely curved and streamlined for strength and wind resistance.
You could even embed solar cells in the skin.
Then I was thinking that this would be an enclosed tomb, just as the teardrops are, and I hate being that enclosed, especially at a campsite with a view. So some consideration needs to be given, in the design, for expanding the envelope of the trailer, once it is set up, with fabric and screened extensions and windows. Slide out and fold out and push out parts of the shell that would expand the usable space and open it up in good weather and take advantage of cool breezes but still shade it from the sun.
And then I got so lost in thought, that I completely lost my way....
Just a thinkn'!
Bill
aussiek2000
not Australia
My grandpa built a teardrop 2 years ago. Built the trailer himself out of 2x4 steel, I think, and then the body out of wood. Pulled it behind a v6 tacoma and 3.0 ranger. they pulled it just fine.
his big problem was (besides registering a homebuilt trailer) no where to do anything in it. If they were out camping and a rain storm came in, they had no where to go. all you can do is crawl in and stare at the ceiling.
J
Jack Olsen
Los Angeles
Thanks for the response, guys. Lots of collective knowledge here.
Here's the shape I'm currently considering:
Since it's a material used in construction, there's a lot of data on it:
http://www.lairdplastics.com/product/materials/composites/496-dibondr-product-information
I'm planning on using 4mm panels, adhered to 1/2" or 1" of foam, adhered to 4mm of corrugated plastic. I suspect this will be massive overkill when it comes to panel strength, but making the doors and windows is easier with more wall thickness.
That looks cool.
I definitely won't be starting with a Harbor Freight trailer. Partly because flat trailers need a huge amount of reinforcement for strength, where box-type trailers get that strength from the box. At least, that's what I see in truck construction. From my perspective, the floor of this trailer is not very important. The walls and ceiling are the real 'structure' of the thing.
(But then I'm a screenwriter and not an engineer. So take my opinions with the same grain of salt that I do. :) )
My plan would be to do not much more than this for the trailer, buying the axle and wheels and welding the rest. The floor would get some kind of frame around its perimeter, but the strength will come from the wall panels themselves.
Grizz built one a few years ago. I think k it might even feature in his thread on here?
That's what planted the seed in my head. :)
I don't know the show. But there is a whole community of 'foamie' camper builders who make very lightweight trailers out of XPS foam (usually the Foamular panels sold at big box stores). Once you get up to 2" thickness for XPS, it's a very strong panel. They usually coat them with ordinary canvas fabric, adhered with a wood glue mix. It works very well, although the final look is a little 'softer' than I'd want for this.
But it's a proven construction technique, and nothing beats it in terms of low price and low weight.
I would be happy if I could come out of this with a 600-800 pound trailer. I've heard some concerns about the thing becoming a sail in crosswinds, making it hard to control the tow vehicle. But I think I can compensate for some of this with the design of the trailer itself, its suspension, and with the way I distribute weight to the tongue.
In one respect, trailer gets the same amount of pressure from the wind whether it's light or heavy. Its resistance to changing direction is more when it's heavy, but that applies to getting the thing back in line as well.
But again: I'm brand new to this and am qualified to learn, not teach.
wyo george
Wyoming, USA
I like your shape a lot and if you haven't already you might browse on over to http://tnttt.com/ I spend a bit of time there. I haven't started my build yet, I gotta finish a couple other projects first. I do have my design worked out in 3D, just waiting to start building the frame.
Hobbit
Bama
Give the trekker trailers website a visit. They have a simple teardrop design that they claim is 750lbs 4' model & 850lbs 5' model. One photo under the ABOUT tab shows the skeleton of one being built that might give you some construction ideas.
