Fixed two spots on my step-dad's yard roller that I had welded after testing it for leaks.
JP, do you put anything on the sheet metal table top? Raw sheet metal would never work here in Missouri!
That is fantastically simple. I'm with VW, what surface finish do you have or will you use?
Thanks zking.
We will powder paint the base and the bench frames, paint the table top and stain the wood to look like barn wood
We plan to paint the top, the table base and the bench frames will be black satin powder coat with the wood being stained to look like barn wood
Removed my old (relative term, it is less than a year old) Klimaire 18,000 BTU heat pump/air con and replaced with a new Mitsubishi 18,000 BTU heat pump/air con. The Klimaire outdoor PCB fried, they wouldn't warranty it, hell I couldn't even buy a new one outright! Searched since February with no luck. At least the Mitsu has a 7 year warranty and local support....
My only advice would be to think about the colour as black is going to get hot enough to fry an egg on in the sun.
Got the wheels ($20 w/ shipping).. Back like new and ready to roll...
Shout out to Volcrew who gave me the lead to OhioTravelBag.com, who expeditiously sent the replacement wheels so I could get the luggage repaired prior to an upcoming trip overseas.. (excellent customer service and they handle a large line of leather working and related tools).![]()
Wow, that's quite the progress these last couple days!!!Today I got the gas tank flange drilled and mounted after cutting the opening for the filler neck. Marked up some openings in the motor mount templates for the brake,fuel and transmission cooler lines to pass through. Layed out the rear cross member for the shocks.
Made two benches for 2 of my SIL's. I like the Ford one.
Thanks. It's fitting since I have 3 currently and have owned another 4Beauty!! I like that SVT banner too!!
I fabricated a hybrid shaft for the P/S control valve I am using in my current garden tractor project.
I had this valve, which comes with a shaft that is meant to accept a u-joint yoke on the spline:
I need to mount a steering wheel on that shaft.
So, I acquired a steering wheel shaft from another tractor, and I cut the shafts of both:
I turned both ends in the lathe to face them off and bevel the outsides of the ends, and center-drilled them:
Pressed them together:
Welded the bevel all around, then turned and polished in the lathe:
Re-assembled, installed in dash tower of tractor to test-fit with the steering wheel:
Then I took it all back apart for painting of the pieces.
