let's see your craftsman block grinders
drivesitfar
JZ: do the wheels turn freely when it's not turned on if you give them a spin? if so maybe it's just a coincidence that the switch or another part quit working and needs replacing. good luck and i'll keep watching while the pros guide you through the fix.
softailgarage
Bullhead City, Az.
Check the wiring. Actually, check the wheel area for obstruction first. Does it work with the wheel off? If not then check the wiring. I wouldn't run the motor more than you have to, sounds like it may be burning out. Watch for the magic smoke,
JZiggy
Atlanta
Same issue with wheels on or off. Drives, I will get some pictures later. Nothing of note in the pictures I have taken so far, really.
At one point I mounted the rotor in a vise (to change bearings) equipped with plastic soft jaws. I clamped gently on the rotor itself, before thinking better of it and clamping onto the shaft instead. Is it possible the rotor could have been damaged?? It seems like it is very stoutly built.
Both coils read normal resistances, so they aren't broken. Connector and wires all look good, I have put the DMM across basically everything I can think of.
JZiggy
Atlanta
I took the block down again and am in the process of putting it back together.
Wiring:
Housing (By the way, are you guys used to seeing these metal shims? I tried to reinstall exactly as they were):
Some evidence of rubbing. Im guessing this could be due to a slight misalignment of the housing halves. Then when the armature pulls on the rotor it is able to close the air gap and stick:
I hit these surfaces with some fine grit paper. Also checked the rotor diameter in a few spots with calipers -- that sucker is totally round, no distortion.
harleybuilder
Southern IL
Sonofa&=#÷* anyone have a source for the long bolts that connect the halves together on the round tops. I guess it had a crack in the threads and I didn't notice it. .....
nine4gmc
Dallas
What about a piece of all-thread with nuts on both ends? I may have an original one for a round top.
balane
It dawned on me that I've never done a block with any color so I wanted to experiment a little. The cast parts are metal flake blue and the trim pieces are in satin nickel. This grinder was capital U ugly when I got it.
I know the badge isn't age correct but that's my favorite Cman logo so that's what I used.
McBrownie
Cleveland, OH
It's been a bad day for Blocks. This would be a lot of trouble but, if you have access to a welder, you could cut it in the middle and splice in a piece to lengthen it.
JZiggy
Atlanta
FIXED!!!
In my earlier post I noted the scoring between the rotor and armature. Turns out one new bearing was seated tight and another was sloppy in the housing... 0.006" to be exactly. I trimmed a piece of brass 0.003" shim, stuck it in the housing, and pressed the bearing/shaft assembly in. As I drew the halves together and when tightening the bolts I tapped the housing halves with a plastic hammer and rotated the shaft occasionally to make sure it was still running free.
It now starts up repeatedly (2.5s to get to speed) and runs very smoothly.
Guys, a sincere thank you to you for your troubleshooting ideas. I now understand these blocks and electric motors in general much, much better.
McBrownie
Cleveland, OH
FIXED!!!
Great news! I just noticed that yours is a 257.191500. The one I had the alignment and bearing fitment problem with was a 257.191401 - the 1/2hp model. I bet they are same housings.
JZiggy
Atlanta
Thanks! Those welded aluminum brackets were actually there when I got it. I adapted them for the DeWalt shields and drilled everything to take a 5/16" bolt.
harleybuilder
Southern IL
I don't have a tig, guess I could try to mig it if I can't come up with one.
McMaster has lots of long screws in 8-32 and 10-24/32 size (not sure which one you need). No hex head ones, but standard machine screw heads are available.
I'll take some measurements and look at them and fastenall.
harleybuilder
Southern IL
Looks great. Love the colors. ...
danstead
Western, Pa
Block Grinder Guru's
I don't know much about the Cman 397's but it is now on my "I need List"
Would $40-$50 be a fair price for one that runs well but needs restored?
Anything I should look out for when buying one?
I also saw an old Wilton recently, were they a well made grinder?
Thanks in advance
131558218723
drivesitfar
Dan: i paid quite a bit more for my block grinders, but i like the ones that didn't need to be rebuilt. if your area doesn't have too many blocks ask Doc (Tourqueman) if he might have one he can ship you.
or i like old USA made Dayton grinders, Baldor, and even the old Jet grinders work well. if you happen to find an old USA made grinder they all have more power than that Wilton probably has.
good luck and take a look at the vintage grinder thread too.
JZ: happy to hear you are good now
Harley: if you ask me that question next year hopefully i'll be able to locate that bolt, but sadly i probably own several and have no idea where it might be.
good luck
ALL: if any of your are looking for better health ideas click on my losing weight thread because i have exercise and a lot of good ideas going to be on that thread as i lose my beer/ice cream/food belly.
torqueman2002
SE Michigan
Wiring:
I have not seen those shims before.
Fixed it! Great! :thumbup:
Bobioz1
Northern il. (For now)
I've had 8 of these apart and never seen those shims. Never seen that circlip between the bearing and shaft either. When you put the halves together, take the rubber feet off and find a nice flat place to set the grinder while you tighten up the bolts. Glad you got it going.
torqueman2002
SE Michigan
The 'C' clips between the bearing and rotor are found on 3/4 & 1-HP grinders.
http://tinyurl.com/Go-Blue-Block-Grinder
McBrownie
Cleveland, OH
I had 'C' clips, or circlips, on my 3/4hp 5/8" arbor and it made truing up the wheels darn near impossible. A single split shaft bearing works much better, however, they need to have the I.D. machined to .667-.669" (17mm). This also applies to 1/2" arbor machines (as they both use the same bearings), but the 1/2" shafts already have a machined shoulder in place. I was lucky and GJ'r exmaxima1 offered to open one up for me.
http://www.garagejournal.com/forum/showpost.php?p=4493828&postcount=4
torqueman2002
SE Michigan
Thanks in advance
131558218723
For the 1 you pictured:
$40 is a good price for a 1/3-HP rtop
$40 is a great price for a 1/2-HP rtop
$40 is a fantastic/you **** price for a 3/4-HP rtop
$40 is a you **** x2 price for a 1-HP ftop
The missing quench tray can be found here:
http://www.searspartsdirect.com/cra...780/0009/397/model-39719440/0247/0721000.html
and here:
http://www.ereplacementparts.com/quench-tray-p-972856.html
When I buy, I check the following, listed in importance:
  • missing parts
  • condition
  • noise when starting & stopping
Bobioz1
Not talking about the snap rings outside the case halves. I was talking about the circlip inside the case halves in ziggys picture. Looks like it's the stop for the bearing. He must have a smaller diameter the length of his shaft. Sorry ziggy. Here is a 3/4 and a 1 h.p. No circlips.
exmaxima1
Midwest
I took the relay apart anyway, and sure enough the contacts were quite cruddy. Cleaned them all up with 1000 grit paper and replaced. Dr. Block, thanks for the idea to do this, I would have bought a relay otherwise :)
I hope this isn't too hard to do. I just picked up a 1/2hp block that won't start without a shove. My fault: I didn't bother to check it when I bought it as I was mainly interested in the stand, and the seller said the grinder worked, but now I find I will need to do some troubleshooting....
JZiggy
Atlanta
It's not hard. The little relay is pretty robust and it seemed like it would difficult to mess anything up.
nine4gmc
Dallas
That's what she said. :lol_hitti
torqueman2002
SE Michigan
Bobioz1,
I'm not following, sorry.
What 'snap rings outside the case halves' and 'circlip inside the case halves' are you referring to?
Also, what are the HP and model numbers of the Blocks are the rotors and stator (field) windings?
Pictures would be a great help.
:thumbup:
Dorsey
Valrico, FL
Hi All - Picked up a 1/2 hp today off CL for $50 and hoping I can get inducted into the club. It works good and is complete except for one eye shield (see attached). Also got the blade sharpener with it. Thanks for all the great info on this thread. Two questions:
1) anyone have the instructions for attaching and using the blade sharpener.
2) anyone have a source for a 7 inch diameter, 1 inch wide wire wheel with 1/2 inch arbor.
Thanks again.
