Northwest 60x60 shop
sfeldma
Really coming along nicely. Are you working on this full time or as time is available? Either way it is an ambitious project. The way you are building it someone will be using it 500 years from now. Keep at it.
Thanks!
Full time for me. I work each day until I realize it's time to quit. Not planned when that is, it just comes to you. I think I'm getting too much sun.
drivesitfar
SF: i don't remember you showing any pictures of your ship lap or siding material other than after you put it up on the walls. if you did i'll look back through the thread or can you post up a few and are they notched on each side to slip on top of each other? i know you said they are shrinking, but i don't see any daylight so even though you are siding over them they look awesome from the insides.
also are they 8, 12 or 20 foot long and 2 x 6's?
i bet your arms and back are sore so you might want to buy a Teeter Up inversion table at Costco next time you are there because mine has kept me from taking advil for about 8 years now.
here's a thread about inversion tables in case you don't already own one.
http://www.garagejournal.com/forum/showthread.php?p=5090065#post5090065
cheers and keep up the great work and that back wall is going up quick.
Toolfool
Columbus, Ohio
Everyday I work on this building, I wonder why I just didn't have a pole barn built! I did look into pole barns, as a kit or kit+install. And then I looked into getting a steel building kit or kit+install. I considered conventional stick frame build. But in the end, I choose the most difficult path. I didn't know about the Costco route. Is that a pole barn?
2 Towns Ciderhouse is about 2 miles from my shop/barn.
Costco sells post-frame structures manufactured by Barn Pros. They look great. Waiting for an opportunity to check one out.
sfeldma
It's 2x8x16 tongue&groove. I got it from these guys: http://roseburg.craigslist.org/mad/5162587521.html
drivesitfar
SF: the ad was for 12 footers so guessing he had 16 footers in a pile for you. i bet he was smiling when you called and asked to buy 100's of them or about how many will it take to finish your building?
hope the rains and winds didn't cause any damage to your great build. we could use the rain, but when it comes with 40 mph winds not always a good thing around our area.
have a great day
sfeldma
have a great day
Yes, they could get me 16 footers as well. Actually, I needed #2 or better per plans, so they had to go thru many boards and pick out/grade the #2s. I'm using over 600 boards but they had to sort thru 2400 boards to get the 600 I'm using.
I was worried about the back wall with the wind coming so I stopped putting on the sheathing until the trusses are up. The front and back walls tie into the trusses with some blocking and cross bracing (I'll show pic once we get there). The wind load on a 60' x 20' wall is high. That's why the center sections of the front/back walls are 4x8 studs.
sfeldma
Very nice build, do you know the history on the AEC truck? I wonder if it came from Hanford?
I bought two of them from a guy in Washington and both are marked AEC on the doors and the guy said they were from swan island in portland, but my guess is they're from hanford via auction. Recently I saw another one on craigslist probably from same area, but it was a 56/57 4x4.
drivesitfar
SF: i actually look forward to seeing more of your progress pictures with all that new wood going up on your barn, garage, shop.
looking even better than a few days ago and keep up the great work.
did you stop at Costco on one of your trips into town and pick up an inversion table?
cheers
sfeldma
cheers
Thanks for all the kind words.
Getting rained out today,so working on getting my sheet metal order in. I'm going with 26 gauge galvalume tuff-rib on roof. I might use it on the side and back walls rather than board and batt to save time/money.
My back is doing fine so far. I did crossfit for a year before building the barn so I'd be in shape. So far no injuries. I've put over 10000 3-1/2" nails in this barn already, so if I didn't have the Dewalt nailer I'm sure I'd have arm issues by now.
sfeldma
Ran out of 2x8 sheathing. I need to get some more ordered.
Trusses showed up today and are on roof now. And then the rain came, hard. I'm going to go watch a movie and let the trusses think about their new home. Scissor lift coming tomorrow and we'll start rolling these out.
drivesitfar
SF: easy to post kind words as you are doing an amazing job. keep taking lots of pictures. more of the insides and of the trusses going up would be great because i love all that wood and i'm positive others do and will to when they see the pictures.
have any questions just ask or again thanks for posting your progress for all of us to enjoy.
cheers and have a great weekend
drivesitfar
SF: ALL that raw wood makes for great pictures so feel free to post more of them if you have any.
after you get done with the shop you'll need to buy a Versaclimber, Concept 2 rower and an Octane Elliptical to get as much exercise as you have while building your new shop.
looks great and good luck putting in the final few tresses.
cheers
sfeldma
Are you happy with the T&G lumber you got from the CL ad? I've viewed the same ad and am considering purchasing some for building the loft in my shop.
Yes, I'm happy. I paid a little bit extra to have them pick thru the boards as they're putting the tongue and groove to find/grade the #2 boards. They fit nice if put up green. They will shrink with about a 3/6" gap between each board if you put 'em up green.
sfeldma
SF: I'm guessing you meant to say 3/16 gap after you put up t&g green and drying in place? Any new pics or are you taking a few days break ?
Yes, 3/16 after the boards dry. When they go up green, I'm putting them tight with no gap. So I start with a 7" board (not including the t&g), and end up a 6-13/16" board. I'd love to go back a "restack" the boards to take out the gap, but there's three 16p hot dipped nails at each post, so they're not going anywhere.
All the trusses are up and it's going to take a few days to put in the out riggers for the end rafter and all the bracing required by the engineer. I was hoping to get the roof sheathed by now, before the rain, but looks like rain for a couple of days starting Tuesday, so I'll have to find something else to work on. My metal panel/trim package is arriving tomorrow, but it'll have to wait for the sheathing.
sfeldma
My wife and daughter are priming/painting everything under the eves and gable ends before the roof sheathing goes down. Actually, they're going to paint a 2' strip on the underside of the sheathing also so when it goes down, everything will be painted.
sfeldma
I picked up some more IH trucks today. These are 1953 & 1954 IH 160s. Cabs are pretty dry as truck came from Eastern Oregon.
drivesitfar
SF: Thanks for the details. Looking good and happy to hear your gals are helping too. I love a great family project. Maybe our weatherman will be wrong again and no rain or less so you can get roof on. Cheers
sfeldma
Updated my phone and it stopped uploading photos...fixed that now...so here's the updates.
Got the upper roof sheathing on and quickly put down the underlayment to keep the water out. We're trying to finish a bunch of little things before calling for the framing inspection. Shooting for inspection on Friday...
drivesitfar
SF: looking good. is the lumber yard you are buying all your lumber from still have enough for you to finish?
good luck and crossing fingers and toes that you get it buttoned up before the rains. also hope your inspection goes ok.
sfeldma
Yes, I picked up more and it's still sitting on my trailer. Should be enough to finish.
Photo from tonight with upper windows tacked in place.
drivesitfar
SF: don't be shy posting pictures here on your thread. i'm positive others will enjoy them too. maybe post a few each day that way it can stay at the top of the list in Garage Gallery so you can have a lot of members following which might help you later if you have any questions or need some advice.
of course i'm still loving what you have built and even though a Mueller steel building is on top of my want list yours is coming a lot closer than i thought a wood building could. the quality and design are awesome.
good luck and hope you beat the rain.
