My motor definitely needs a new cord. The whole thing is just cracked to pieces. And there's a broken wire inside. Can I add a ground where the bottom cover plate screw goes.
Also. My motor really needs rebuilt. But I'm not up for that right now. I need to get this thing running.
Yes, that motor definitely needs attention. I used that plate cover screw for ground on one of my refurbs. See the link in my signature. It may not be "code", but I figured that that motor was not originally equipped with a ground wire. So it's better than nothing.
I found a motor that the guy says he don't think it's ever been used. It was his dads. He thinks his dad sent in a bad motor and got this one as a replacement but never used it. There's no cord or switch. He says it looks like it's never had one.
Or it could be a junk motor that his dad robbed the cord off of,,,,lol.
Anyway. Would this little Craftsman work on my model 100 drill press. Is it the right style. I don't know if it will bolt up. Or I might try to use it on my Delta, God forbid having a Craftsman motor on my Delta,,,lol.
Hard to make out the model number. But I think it is 113.18351. I can't find anything on it.
You guys got any ideas. Thanks.
The brown/gold motor has sleeve-bearings and should work well on your DP. I can't read the label from your picture, but there should be a catalog number listed. You may need to investigate whether this sleeve-bearing motor can be mounted vertically. Some sleeve-bearing motors are specified for horizontal mounting only. Craftsman catalogs can be found online. Mounting options are usually specified in the general description of each motor type.
Like outlaw said above, the motor shaft needs to match the bore of your pulley. It's possible you may need a sleeve adapter if the motor shaft is 1/2" and the pulley bore is 5/8". Not a problem. I believe some 1/2" shaft motors came with an adapter when new.
In addition, the motor rotation need to be correct. Many Craftsman motors are reversible. There should be a label attached to the inside of the terminal cover with instructions on which wires to switch to change rotation.
Below are a few pictures of one of my motors very similar to that one.
