Above 1200 Sq/FT The Lone Beech Garage (60x46x16)
camarosrus69
South central Kansas
Re: The Lone Beech Garage Build Thread (60x46)
Wednesday - July 6, 2016
I examined the gasket at the bottom of the door and quite a bit of water came out of the end of the gasket. I checked all the other garage doors and one of the 10-foot doors also had quite a bit of water in the gasket.
I would not think that water should be accumulating in the gasket and I'm going to check on this with the manufacturer of the doors.
Scott
I have a similar situation on my 18 ft wide double door. When I open the door after a rain that has been hitting the door, water drains out about five feet from one end. That puts a water racing stripe down the driver's side of the car as I back out. In my case there appears to be a vent hole in that location, As to how the water is getting into the seal, I have no idea. My door is similar yours in that it is foam filled and double sided. My only thought might be that if there is a lip on outside for the part holding the seal, maybe that needs to be sealed.
camarosrus69
You mentioned that it was a gusty storm. I went back and took a closer look at your photos. The wind would only have to push the water uphill for about an inch until it reaches the top of your incline. after that, it would flow naturally to that slightly lower area. If you have someone shine a flashlight along the bottom, you'll probably find that seal isn't fitting quite as snugly along the entire length.
sbosecker
Peachtree City, GA
SB: hope you solve the mystery of the water. BTW when you did mess up a little did the blue (is it painter's tape) tape keep the flaws from showing?
best of luck with the weather and the hyrdo-seeding.
DrivesItFar,
Water:
Thanks... It's sorta like crop circles, so far I've only seen the results - not the formation. Seeing it happen would be useful to determine what's going on.
Blue Tape:
Yes, 3M Painter's tape of some variety from Home Depot. The tape worked well. If I got too much into the control joint and the sealant would crown up the tape kept the sealant from getting on the concrete beyond the control joint.
My technique was to put the tape down; install the Backer Rod; then apply the sealant. Pretty shortly after I'd applied the sealant I would removed the blue tape - one side at a time. I tried to stand on the opposite side of the control joint and pull the tape towards me at an angle. This would put any residual sealant on top the tape back into the sealant in the control joint.
This seemed to work. The SikaFlex, being self-leveling, is forgiving in this regard. Even though in some places it would appear that I had gotten too much sealant in the control joint, the next day it would look pretty good.
Thanks for the weather wishes!
Best regards,
Scott
sbosecker
Peachtree City, GA
camarosrus69,
The Gasket on the bottom of my doors is made to slip over the bottom of the door. This means there is a seam running along the bottom of the door facing up. I'll have to try to get a picture. It looks like a very close fit but I think this is how the water is getting in. A bead of clear sealant is probably the cure for that.
Your theory as to how the water defies gravity is pretty much at the top of my short list as well. I did look at the bottom of the gasket shortly after discovering the water. It wasn't intuitively obvious that this is what was going on. As noted in my note to DrivesItFar, it would be helpful to see it happen. I'm sure I'll get a chance at some point.
Best regards,
Scott
sbosecker
Peachtree City, GA
Friday - July 8, 2016
No sign of landscaping activity today.
A week ago a couple of guys came by to start up the Rinnai Tankless Water Heater. It was about 6 pm on the Friday before the holiday weekend. They couldn't get the Water Heater to light. After about 15 minutes, they gave up and said someone would be out the following week.
Today, at around 2:00 pm, a couple of guys showed up and checked out the water heater.
It pretty much started right up. A discussion followed and the working theory was that the first guys didn't give the gas line enough time to purge itself of whatever had been used to pressure test the system and they must have been close when they gave up.
As readers of this thread may recall, the total gas line is probably pretty close to 100 yards from the far end of my house to the water heater. At that time, there was a discussion that this length might have issues trying to provide the gas requirements of the water heater. I am concerned that this is part of the issue but...
We shall see how this operates over time. Today, it seemed to work fine with the minimal load put on the water heater.
Today I also took the opportunity to discuss the water heater's location with these workers. I am not happy with how this installation turned out visually.
This is my fault as I made some assumptions that turned out not to be correct - The water heater is 14-inches wide so it must be able to be located between studs, right?
...not. (At least not wooden studs)
Initially I thought I could hide the heater in a wall cabinet but as plumbing and the gas line were added the situation only got worse. I had intended to have base cabinets running along the wall where the plumbing comes out of the wall and that's not going to work.
Anyway, I asked if it was possible to move the water heater completely into the attic at some point and the short answer was "yes" and that they didn't think it would be a difficult thing to do.
I will wait to explore this further until this winter when the attic isn't stinking hot.
Scott
sbosecker
Peachtree City, GA
Saturday - July 9, 2016
Yesterday I spent a little time at an estate sale located about 20 miles away from my home. This sale was in a rural location and had more "man stuff" than what I normally see advertised.
Despite the encouraging location and advertising, when I got there I really didn't see much of anything that would be of use to me. There were a couple of rough outbuildings full of stuff and that's where - despite the sauna-like heat - I spent most of my time poking around. I had about given up on this event and then I saw it under a dirty sheet of 3/4 inch plywood piled high with used-up tools and coffee cans full of nails - hiding in plane sight (albeit in very dim light).
A 66-inch Youngstown Kitchen Sink Cabinet - minus the sink - painted a color of brown that made it blend into the background of this rough shed. My first reaction was that the handle hardware was in good condition and there were 8 handles. I really wasn't that interested in the cabinet because I expected it to be in terrible condition but the hardware was of interest as it matched the other Youngstown cabinets I've recently acquired. The cabinet had no price on it.
Since in my experience most estate tag sale organizers aren't interested in negotiating on day 1 of a 3 day sale I did not discuss the cabinet with the folks running the sale. I returned today a bit over an hour before day 2 would end. The cabinet was still there - apparently pretty much unnoticed - and now I discussed the cabinet with the organizers. A deal was struck and my son and I extracted it from the rude structure that had been its home for many, many years.
I was surprised at how good of condition this cabinet was in despite its location. Most of the 50's era sink cabinets I've come across have suffered mightily from leaking plumbing and spilled caustic cleaning agents. That was not the case here.
It's in good enough shape that I may have to rethink the concept of it being a supplier of hardware and parts for the other cabinets that I've acquired and it may get to live another day. If not in the Lone Beech Garage then somewhere else on my property.
I suppose it could also become barter for trade. I'm generally more interested in wall cabinets than base cabinets but we'll see.
Scott
Bob Heine
Boca Raton, Florida
Scott
Scott, I don't know why but some (if not all) water heater installers seem to have the ability to fugly up the installation. I've only had one installed by "professionals" and they used a half dozen unnecessary fittings and bent a section of rigid pipe to line it up. When I mentioned it to my wife she gave me that "it works so who cares" look. I lived with it until the tank sprung a leak (6 years) and I installed a new one. I responded to the "What's taking so long" comment with an "I don't do this for a living so it takes longer" reply.
In South Florida skilled workers are fully employed by wealthy clients and are too busy to do the small jobs. I know they are here but I also know they didn't install my water heater.
sbosecker
Peachtree City, GA
Scott,
Still love following your progress.
Found this. Thought you might find it interesting.
https://www.etsy.com/listing/249290...8f9d570b8e24&gclid=CPus7JWi680CFcJahgodFYUHWQ
Than,
Thanks for the kind words and the link!
I've done some searching on eBay for the cabinets on the off chance a nice set would show up either close to me or my folks.
While doing that search I come across ads/brochures like the one you linked to. I copied the pictures of these items from various years (40's & 50's) and by studying these images one can sometimes pin down how old a particular piece is.
One of the biggest giveaways is the handle hardware. From the advertising it appears that Youngstown changed them from "Art Deco" to "Atomic Age Boomerang" in 1953.
Best regards,
Scott
sbosecker
Peachtree City, GA
Bob,
Mostly I kick myself as installing the water heater in the attic space was discussed prior to me giving the "Go" to the interior wall installation.
I was concerned that the attic might get cold enough to freeze the water lines so my practical side trumped my esthetic side. I stated this to the workmen and then my visual assumptions were torn asunder. First due to the Water Heater having to be completely inside the Mezzanine and then by the plumbers complying with "keeping the water lines out of the attic to avoid freezing".
Now that it's all said and done, I'm pretty sure that I can, in the future, move this mess into the attic and make an insulated "box" around it to keep it warm enough in the winter to avoid pipes exploding.
Best regards,
Scott
sbosecker
Peachtree City, GA
Tuesday - July 12, 2016
We are in limbo here as far as the hydro-seeding. We had a couple of days last week with some much needed rain and that kept the hydro-seeders from doing their prep work.
It was dry and hot all weekend and yesterday dawned clear and a bit cooler. I think it would have been a perfect day to get the prep work done. About noon I got an email from the builder indicating that the prep would start today.
By late afternoon yesterday the sky was darkening and we had another spasm of very gusty winds and 6-tenths of an inch of rain in a very short time.
As I expected, no hydro-seed prep was accomplished today. It is drizzling outside as I write this.
We had hoped to get the hydro-seeding done and then a final inspection on Friday. That is looking doubtful at this time.
I did acquire something for the Mezzanine yesterday.
A drafting table complete with drafting machine.
Well... actually two drafting tables complete with drafting machines.
Last week I saw a Craigslist ad for a drafting table & drafting machine not too far away from me. I sent an email asking for more information and heard nothing ...until yesterday morning.
An email arrived indicating I could come look at the table. A phone call was made and off I went, dragging my son along to act as a Sherpa should that be necessary.
The situation was a industrial operation that was selling a building. They needed this room cleared of a few things and one of these things was the drafting table & drafting machine. We walked over to the building and climbed up the stairs to the second floor. It was quite warm up there.
I looked over the table and struck a deal with the owner. Then he pointed out another table that was disassembled. "Wouldn't I like to have that one also?", he asked.
"No", I answered.
As my son and I studied the narrow exterior stairs that we were going to have to bring this monster down, the owner kept extolling the virtues of having two Drafting Tables.
He finally made an offer to sell at such a low price it was practically free. I took the bait and that's how I wound up with two of these dinosaurs.
He threw in 4 old computers as well so my son was delighted with that.
As I needed to go the doctor's office mid-afternoon - Pilot medical exam that I have to do twice a year - we came home and parked the truck in the Lone Beech Garage with all the stuff still loaded.
Today we unloaded these treasures and parked them in the woodshop. I'll play with them for a bit and then pick one to go upstairs. I'll try to sell the remaining piece. It isn't that unusual to find a drafting table but it's quite a bit harder to find one complete with a drafting machine.
Since these things are pretty heavy and bulky, I may have to offer some sort of delivery to sweeten the deal enough to make a sale.
Scott
shortykorte
Tallahassee, Fl
Nice score on the tables. Now to fine an artist that hasn't gone digital. Here's the type drafting machine I started with. Not as sturdy but you had free range of the entire board.
sbosecker
Peachtree City, GA
Scott, those drafting tables are sweet. Great score.:thumbup:
Thanks guys!
I probably won't use it that much but I know I will use it.
Shorty... That elbow type is what I used many years ago as well. We'll see if I can adapt to this big rig.
Best regards,
Scott
sbosecker
Peachtree City, GA
Wednesday - July 13, 2016
I was a bit surprised to hear activity on the building site at about 9:00 am this morning.
It was the prep crew for the hydro-seeding operation.
They raked the area with an attachment on a skid steer while working tighter areas by hand. All the roots and other trash were collected in the skid steer bucket and then carried off in into the woods and dumped.
The Hydro-Seeding Truck arrived early afternoon and the process of putting down the seed slurry began.
They finished their work around 4 o'clock. I spent the next several hours dragging hoses and sprinklers around making sure the seeds were kept moist.
This is what I'm going to be doing for the foreseeable future. I am told if I do my job properly, the seed should start germinating in a week or so.
Oh yeah...
With this "landscaping" in the rear view mirror, the final inspection of the building should take place on Friday.
Scott
shortykorte
Tallahassee, Fl
Congrats on finally getting seed down. Rainy season is here so that should help.
Well things are looking greener on the other side.....
Of the driveway. :rocker:
LutzTD
Lutz, Florida
"No", I answered.
Scott
My first engineering job was on a table exactly like those, same base and woodgrainish arms.....
sbosecker
Peachtree City, GA
Thursday - July 14, 2016
Today has been a constant battle against the relentless Georgia summer sun and my ability to manipulate sprinklers and garden hoses in an attempt to keep my new grass seed in a moist environment.
I think I managed to succeed today but the mid-90's and cloudless sky combined to be a ruthless task-master.
The chances of rain increase into the weekend. If I can keep the soil moist this weather will make the seed pop but I'm going to a (tired) one-trick pony for the foreseeable future.
Scott
sbosecker
Peachtree City, GA
shortykorte,
Thanks!
Today was a day that reminded me why I left the farm as a young man. Ha!
Chances of rain increase starting tomorrow. A toad-strangler would be a problem as the naked earth would give way to a cloud burst. Unfortunately, if we do get rain it will probably be the result of convective activity and that tends to come hard and fast.
We shall see. If nothing else some clouds would help. Mid-90's with clear skies makes it tough to keep in front of the evaporation rate with my inadequate equipment.
Best regards,
Scott
sbosecker
Peachtree City, GA
Sunday - July 17, 2016
Friday we were supposed to have our Final Inspection... at 6:30 pm we gave up waiting and we hope to get this accomplished tomorrow (Monday). This is a first - the Inspectors have been quite conscientious up to the point.
It is often said on this web site, "If there are no pictures it never happened."
I must say that trying to take (interesting) pictures of me using my Rube Goldberg irrigation set up to water the freshly seeded areas around the Lone Beech Garage seemed like an exercise in futility. Watching someone watering a yard may actually be less interesting than watching paint dry.
Mostly I drag about 400 feet of garden hose around and set up the oscillating sprinklers to provide as efficient a watering pattern as possible with my odd shaped situation.
Still, it would seem my efforts are starting to pay off.
Last evening I noticed the first green shoots of Bermuda Grass. I continue to spend a ridiculous amount of time keeping the seeded areas as moist as possible under the present conditions.
Yesterday we were supposed to get some rain. We did but it didn't amount to anything. No measurable rain in the rain gauge. We'll see if we get any this afternoon. It was clear this morning but the afternoon sky has the starts of some towering cumulus as the sun moves towards the west.
One thing about trying to grow plants is that as you work the earth you see things you probably wouldn't even notice normally. Take the above picture. What was really a bit startling was the insect that was making that burrow.
A Cicada Killer Wasp! This a big son-of-a-gun! After trying to get a few pictures of this rascal - without getting too close - I gave up and resorted to Google to find the above picture. I was looking for something to give a sense of the size of this wasp so the business card for an exterminator seemed to work.
I flooded the burrow after I took the picture. I'm hoping any survivors will try to find another area to live.
Scott
Drewstang
Bedford, KY
We have those cicada wasps around here as well. They hunt the other more annoying paper wasps. We've never had a run in with one as they usually avoid people. And to update my Trane Mini Split situation, a second company came out and after many calls and emails came to the conclusion the first company installed both units completely incorrect. Trane was nice enough to pay for the uninstall and reinstall, and even upgraded us to a brand new larger system. I can't say enough about Trane, I'm impressed.
sbosecker
Peachtree City, GA
...to update my Trane Mini Split situation, a second company came out and after many calls and emails came to the conclusion the first company installed both units completely incorrect. Trane was nice enough to pay for the uninstall and reinstall, and even upgraded us to a brand new larger system. I can't say enough about Trane, I'm impressed.
Drewstang,
Outstanding! Great to hear that!
Best regards,
Scott
Dadofour
Middletown, NJ
Scott
Scott,
We have had an increasing number of these every year. Although they seem to be completely disinterested in people they are very intimidating.
Watch one dig out its nest. It is amazing. If you want to kill them, flag their borrows during the day and flood them with a 50/50 mixture of ammonia and water at night.
Than
sbosecker
Peachtree City, GA
Than,
The excavating that creature was doing was quite impressive. I felt a small bit of remorse as I hit the entrance to its tunnel with the "Stream Mode" of my water sprinkler. With the grass only just starting to sprout, the bare earth collapsed completely into the tunnel. So far I haven't seen an escape hole.
The entrance was next to the edge of my "half-circle ramp" driveway. The vindictive witch is probably borrowing straight to the middle of the driveway with a pound of C-4. I just hope she sets it off at night when I'm not out there.
Ha!
Scott
sbosecker
Peachtree City, GA
Monday - July 18, 2016
At 3 o'clock today, the Lone Beech Garage passed the "Final Inspection" from Peachtree City, GA.
Still plenty to do but, for the most part, things from here forward just need to please me.
Scott
sbosecker
Peachtree City, GA
the know all and see all.....google
it is in the lower corner of the picture
Yes google maps
Gentlemen:
Yes, I could see Google in the corner of the picture but when I used Google on my computer I did not get this image. I just used my smart phone and I get the updated image of my property that included the Lone Beech Garage.
Odd.
Why would it be different (older Satellite image) on a PC vs. my smart phone?
Best regards,
Scott
shortykorte
Tallahassee, Fl
Depends on browser and phone app.
Internet Explorer will probably default to Bing Maps. Others who knows? I believe Apple uses a different base map than Google. Google app will of course use Google. There are several providers of base maps (maps and aerial) and they are updated at random.
sbosecker
Peachtree City, GA
shrotykorte,
No, I used Google search via Internet Explorer on my PC and the "Maps" app on my Android Smart Phone...
I just figured that Google would use the same satellite image database for all its applications: Apparently not.
Best regards,
Scott
drivesitfar
SB: it's looking like a golf course around your new shop. congrats and hope you get plenty of rain, but i bet it will be a lot of hand watering. that was some BUG and almost looked like a cartoon in the picture. we get plenty of hornets up here and they make their nests in the ground like the ones you found or just start attaching plaster of paris type nests to decks, homes and trees. nasty sting and i usually swell up pretty good if one happens to get me.
CONGRATS ON FINAL INSPECTION TOO.
looking great around your place and i need to step it up at mine now and get off the computer.
cheers
Dadofour
Middletown, NJ
Congratulations! We follow all the rules we know about and always have a small worry in the back of our minds about the unknown roles.
Let the games begin!
Than
sbosecker
Peachtree City, GA
cheers
DrivesItFar,
Thanks for the kind words... Augusta it is not but it is starting to look like some grass is taking hold.
Mother Nature hasn't been much help so far (rain) so I've been very busy trying to give these seeds a chance to make it.
Hopefully that need will taper off soon and I'll be able to spend some time moving things into the building.
Best regards,
Scott
