camarosrus69
Re: The Lone Beech Garage Build Thread (60x46)
I have a similar situation on my 18 ft wide double door. When I open the door after a rain that has been hitting the door, water drains out about five feet from one end. That puts a water racing stripe down the driver's side of the car as I back out. In my case there appears to be a vent hole in that location, As to how the water is getting into the seal, I have no idea. My door is similar yours in that it is foam filled and double sided. My only thought might be that if there is a lip on outside for the part holding the seal, maybe that needs to be sealed.
Wednesday - July 6, 2016
I examined the gasket at the bottom of the door and quite a bit of water came out of the end of the gasket. I checked all the other garage doors and one of the 10-foot doors also had quite a bit of water in the gasket.
I would not think that water should be accumulating in the gasket and I'm going to check on this with the manufacturer of the doors.
Scott
