Show us your welding projects
Bob Heine
Boca Raton, Florida
Not sure this qualifies as a welding project but it is welding-related. I started welding at 64 with a Harbor Freight $89 flux core wire feed unit. Upgraded to an Eastwood 175 MIG with a spool gun for aluminum and a tank of 98/2% Ar/CO2 so I could weld stainless steel. Before I conquered those units I bought an Eastwood 200DC TIG machine and a tank of Argon. The MIG is doable one-handed but I couldn't coordinate my artificial arm with either the TIG torch or the filler rod so I mentioned wanting some kind of a filler-rod feeder that attached to the torch. I found a wire feed unit for about $3,000 but that's about three times what I've spent on the three welders. I mentioned my dilemma and Zeke pointed me to some really cool pencils, including one he developed. Knowing too little, with mostly hand tools, I made a filler rod feeder that seems to work.
Started with a foot-long piece of thick-walled 1/4-inch stainless steel tubing. It needed to hold the stainless wire or the filler rod so I put a slight bend in it, using an Eastwood brake line bender. The un-bent tube is the same outside diameter but thinner walled.
Using files, a Dremel tool with some diamond burrs, a Scotch-Brite EXL de-burring wheel and a buffer, I cut away a section of the tube. A little shaping and polishing and a 1/16-inch filler rod slides through quite easily but with some friction so it doesn't fall out..
Unfortunately I can't get the rod to slide with just finger pressure if I'm wearing a TIG glove but it moves fine with bare skin. I can take a certain amount of heat but a molten pool of steel at the end of the rod is going to be more than a little uncomfortable. I am drawing pictures in my mind how to solve the advancing mechanism and I think it's going to be simple -- Famous Last Words!! :headscrat
I wanted to move on to the torch mount for the TIG rod feeder. I went to my wood lathe and... oops, I don't have one of those, or a milling machine or precision tool of any kind. Drill a 1/4-inch hole in a block of wood at an angle, round off the block on a sanding wheel and hog a channel to match the torch with a rotary rasp. A hose clamp and I think I've got it.
I obviously can't use a block of wood but I can weld an angled bracket to the tube. First I have to make a sleeve that slides over the open channel. with a threaded hole for a screw. The screw tip presses on the filler rod and the sleeve slides back to grab a bit more rod, press down on the screw head and feed more into the puddle. Turns out I have the right size stainless tube in my pile.
It didn't work because the screw tip just slides along the filler rod. I filed a curve in the screw tip and that didn't help either. It occurred to me it needed a longer and rougher surface to grab the rod. The file on the vise tested the theory and it worked surprisingly well. If I can attach a section of jeweler's file inside the tube I might have a winner.
More than 20 years ago I broke a jeweler's file. I knew exactly where it was so I put the thing in the garage vise so I could grind a dent in it. I have a set of diamond bits and surprise, surprise it worked. I also know I snapped that file so it should be easy to break off another piece. Another surprise -- it took one hammer tap once it was in the vise.
I had to re-file the end of that 6-32 screw so it better matched the dent. This is by no means an elegant piece of work but the file piece sorta fits and the rod slides forward with minimum pressure and the sleeve slides back without grabbing the rod.
At this point I felt like I had proof of concept so I tried it out with the camera recording the action. I didn't do a very good job setting up the contraption in the vise so I had to use two fingers to operate it.
"Alright, Mr. DeMille, I'm ready for my close-up... "
As you can see in the video, the slide is very loose. I found another piece of stainless tubing that's thicker walled so I made another sleeve.
I added a finger stage to the slide and mounted it with a second countersunk screw.
Guster helped out with some examples of mounting brackets so I'll be working on that next.
I splurged on a #9 torch, hoping the smaller size might make a better platform. I also bought an $8 #26 straight torch (like the one in the middle of the top row in the above photo) just in case. I'm also going to look for a slightly wider file to chop up.
jinjaninja
Awesome work.
Just a thought though, and I dont know the extent of the "artificial" arms usefulness, but it might be worth adapting the torch or the arm to be used by the artificial arm and learn to feed with the good hand ? I had a old mate I worked with who lost his favoured arm midway to the elbow. It was his feeding hand. We tried a bunch of different setups (my boss wasn't willing to let him go or give up on helping him make it work) in the end, he found the best solution was learning to feed with his other hand and having a hook glove as he called it controlling the torch.
After that our boss made it a shop policy that everyone had to practice lefty welding at least once a day lol :D
All the best with the adventures though mate :D
Sent from my HTC_0P6B using Tapatalk
Bob Heine
Boca Raton, Florida
Thanks, Jinjaninja. I'm not really without a left arm, just the elbow and the fancy bits below. I tried holding the torch with the hook but kept dipping the tungsten into the puddle or pulling too far back and losing the arc. Your boss had the right idea not giving up just because it didn't work perfectly on day 1. I'll continue down this feeder path but I'll also practice holding the torch with my hook. Maybe a movable rest would help.
jimgood
Marshall, VA
Bob, that's really amazing.
I wonder if it would be fairly simple to make a block with thumb wheels that could feed the rod. If the thumb wheels had a rubber tread the rod could run between them. By spinning one wheel, it would feed the rod.
A block of aluminum with a hole for the rod to pass through. Then a slot cut for the thumb wheels to be mounted so that there's just enough space to grip the rod. Hell, you could even shape the aluminum to make it more ergonomic.
Sorry...I'm an idea guy. I can't help it. Forgive that and my rudimentary drawing.
EDIT: Patent pending!!! LOL!
EDIT: Sheeeit! http://www.ebay.com/itm/like/322305783771?lpid=82&chn=ps&ul_noapp=true
MP&C
Leonardtown, MD
Bob, if you remember back to some of my initial attempts at TIG fusion welding, I modified the nozzle to act as a guide similar to that of a plasma cutter, and still be able to see the arc. Perhaps something like this would work for you to keep a "feed hand" open... Used roloc sanding discs to modify, but don't get the nozzle hot, take your time. If it overheats, it's done and in multiple pieces.
Bob Heine
Boca Raton, Florida
Jim, that's one of the items Zeke pointed me to. I'm probably going to buy one, just to try it out and to see if I can mount it to the torch in a way that turns it into a one-hand operation.
Because I drank a lot of Scotch Whisky in my youth, I became very frugal. Everything in the Fickle Finger Of TIG device (thanks to Andy [oldironfarmer] for the name) was in my metal tube and plate collection (needed pieces for spacers on several projects) so it was a total of $0 invested.
You weren't the only one to suggest the thumb wheels. I haven't implemented it yet but I have some lighters from my smoking days (frugality made me quit) and one was missing the shroud. Another freebee.
It turns out the knurled wheels with striker attached to them is a pretty close fit:
zmotorsports
Northern Utah
Bob, you are truly amazing. Things that many of us simply take for granted and you have found yet another way to kick its *** and make it your *****. You are truly inspiring.
Thank you.
Mike.
Bob Heine
Boca Raton, Florida
Robert, thanks so much for reminding me. Now that I see the photo, I do remember (Scotch is not good for brain cells). I just so happen to have a collection of nozzles so I can definitely do that. I did overheat one so I know what you mean about shattering it.
Thanks guys, I appreciate the feedback.
Bob Heine
Boca Raton, Florida
Thank you.
Mike.
Mike, I'm having trouble reading the screen. Thank you for those very kind words. Life is good, whatever the circumstances. The side effect of mine is to force me to have patience.
Mike, you and so many other people on the Garage Journal Forum show us the way and it has become a very important part of my life. Thanks to all of you.
helterskelter
Bob,
Goodluck with your wire feeder. What type of thumb control is on your #9 torch? I have a miller thumb wheel style but that level type looks much nicer.
Bob Heine
Boca Raton, Florida
Bob,
Helterskelter, my Eastwood's 200DC TIG comes with a foot pedal variable control and that plain ON/OFF switch on the #9 and #17 torches. The switch is only zip-tied on so I can rotate it to any position that's comfortable. I plan on using the foot control with the wire feeder -- I'm pretty good one handed but I think feeding wire with one finger and turning the torch on and off with another might exceed my dexterity and certainly my mental capacity. The switch on the TIG torch was good when I was first using it because it is so similar to using a MIG torch.
jimgood
Marshall, VA
I've had this carport truss across the back of my sawdust bin for several years now. It was just loose and when I pulled the tarp over the bin, I would raise the truss so it was vertical and this keeps the tarp from collapsing into the hollow between the sawdust pile and the back of the bin and collecting water. The only thing holding it vertical was the tension of the tarp hanging on it.
The only problem is that it falls over when the bin starts to get empty. So, I added a brace to it from some scrap. Nothing earth shattering but this will make my life slightly easier. Took about 45 minutes to cobble this together. Would have been quicker but I went to the trouble to cut a bird's mouth in the brace to provide more surface area to weld.
View media item 65528
View media item 65529
View media item 65530
skipnay
PA
Picked the frame up dirt cheap at the scrap yard. Though it was poorly slapped together. If I remember correctly $3 in the frame from the yard. I have less then $0.50 in the expanded metal (bought 25 pieces for 4.5'x5' for $20 and had probably 10 half pieces). Then I bought the wheels from harbor freight. Going to be using this outside. I always use saw horses and they **** for heavy stuff it seems. I need to get some ideas on what to add. Probably be a vise for one.
Bob Heine
Boca Raton, Florida
A big thank you to Robert (MP&C) for the modified TIG torch nozzle idea. I used a diamond-impregnated wheel on the Dremel to relieve the sides of the nozzle. I'll let you know how it works. I'm going to have to practice with the new torch on fusion welds before I make the rod feeder mount and try my hand at filler rod.
First test will be fusion welding those two pieces of scrap stainless exhaust pipe in the background...
Griff93
Huntsville, AL
Did a little welding to put a bung on a piece of aluminum tubing for a 5vz engine swap in an 86 4runner. It would be really hard to do this without being able to weld.
Cue
Zebulon, NC
Add on for a basic tire machine so I am able to install low profile tires easier. Just a trailer hitch receiver with a piece of 2" square tube a a piece of 1/4" plate welded to the bottom and a wheel mounted to that. It can slide up and down and a bolt locks it in place. the wheel holds the tire down and keeps it from popping off the rim while it rotates, works very well.
MarkG
Elgin, IL
Anyone here able to help. I use a hobart 140. Just hobby stuff. But I notice while I'm welding it sounds like it's hopping. And the wire isn't coming out smooth. I tried turning up the wire speed. But doesn't matter. Any help is greatly appreciated. Chris
Sent from my SM-G928V using Tapatalk
Wirefeed probably too slow and burning back. I used to get positioned so I could weld a test bead with one hand and adjust the speed with the other while welding a test bead till it smooths out into a nice sizzle.
Mr_fixit
Rustylvania
I couldn't find a press brake that fit my press. So I made a narrower version of one a friend had.
kmkalf
Buffalo, NY
Welder cart and table, gotta make tank brackets and secure the top. If and when I do weld on the top I have a welding blanket as a barrier
Sent from my SM-N910V using Tapatalk
NUTTSGT
Northern Central Ohio
I made this last night. It's for the inflatable Avon boat at the fire station. The hitch has been sitting on a block of wood since I started (first the Zodiac, then the Avon) and has a habit of sliding off when somebody leans on it too much.
I'm hoping this will cure that.
Partsguy57
Building stainless exhaust today for my 68 Camaro project car. Entirely home built in my shop.24efa6f4ed29db5c01c28a6f8e5a7b8c.jpg
/ca9eb405519ba3218121800b5116535b.jpg[/IMG]f94ef69901d96f74c02a919757ca521c.jpg work in progress, probably two months from start up.
Sent from my SM-G920R4 using Tapatalk
Keyblazer
Irvine, CA
OMG Partsguy.. that is sick quality work!:D
I posted this in a thread in tools, but nobody seems interested...
Here maybe is a good place...
Got an Alfa Romeo, to restore, and whilst I have a good MIG and TIG, there is something about replicating OEM Spot welds that tickled my interest.
Been trolling CL for a while, and this popped up..
LENCO Panelspotter... from the 70's maybe, but a modded and updated version is still sold today for about $1500.
He assured me it worked, and deal was done at $60, and the super nice guy even met me half way to help out!
Those unfamiliar with these...
It has TWO guns... it spot welds from one side, but pressing the two tips to one side of the panel and pulling a trigger on one of the guns, it does 2 at a time. It is good for 20g steel.
The REALLY cool part, I think, is that not only can it Spot weld, but with some extra parts, it can weld studs like a stud gun and also spot shrink!
Today was test day..
I powered her up, and even tho, I think the tips are past it, here was the results...
First try was a little tentative, with me set on #1 power.
In a destruction test, it failed.
So I upper the power to #2.0, which ups the amps and duration of the timer.
Much better penetration and 2 of 4 pulled slugs before breaking.
Final test was at #2.5.
Very happy with my buy!
PCO6
Newmarket, Ontario
Keyblazer - I have a similar Porta-Spot welder. I picked it up for $50 at an estate sale back in the '80s. I believe they were going for about $1,200 new at the time. I don't use it often but it's a great machine when you need it. Have fun with yours! :thumbup:
View media item 36196
Keyblazer
Irvine, CA
I agree with you John!
Pco6, I read your post in the Lenco thread I mentioned.
I am actually surprised it worked at all judging by the tips in comparison to the tapers on yours!
Can't wait to see how it works as a stud gun and shrinker!
PCO6
Newmarket, Ontario
^^^ I think you're right about the tapers. My guess is that you can probably reshape them with a grinder. Chances are that they're also replaceable.
Also, I wouldn't be afraid to try thicker metal with yours. You mention 20g. I have welded 18g with mine and as an experiment I welded 19g to 1/8" wall tubing on my Jeep Cherokee rockers. I backed it up with some mig welds but so far the spot welds have held up just fine.
View media item 43613
Keyblazer
Irvine, CA
Way cool!
The tips are replaceable, and I have a kit of them coming.
The set includes several spot welding tips for different jobs, the hollow stud welding tip and a bunch of other accessories. Look up Lenco 104.
The tips are not screwed in... They are a taper fit,
Tim K
Good score with the spot welder. Somebody mentioned stud puller attachments:
When I worked in a body shop one summer while in school, they were using the same type of machine but they cut a slot in one of the ends for holding washers. They just welded the edge of the washer to the panel needing to be 'pulled' and had a cheap slide hammer with a hook on the end to do the pulling. When you're done, give the washer a twist and they come off. They were just reused again and again.
Tim K
Keyblazer
Irvine, CA
You are correct Tim. This unit can do studs, washers, stars, and wiggle wire. It can also attach fittings like threaded studs and screws.
PCO6
Newmarket, Ontario
Way cool!
Keyblazer - That's good to know. I don't know about the availability of Porta-Spot parts but I wouldn't be surprised if Lenco parts would work in my machine.
Another source is copper ground rods from places like Home Depot. I met a guy who modified them to work in his spot welder like mine pictured below. He cut them to size, turned down the ends in a lathe and bent them to the shape he wanted. Seemed like a smart idea to me.
1/2" copper ground rods ...
http://www.homedepot.com/p/ERITECH-1-2-in-x-8-ft-Copper-Ground-Rod-611380UPC/202195737
My other spot welder ...
View media item 43752
Tim K
Tim K - That's something I hadn't thought of but am now itching to try. Thanks! :thumbup:
Keyblazer
Irvine, CA
Good info.
The tapers on the Lenco are apparently "No. 1 Morris Taper(No. 4 RW)".
To remove the tips from the gun, they advise to "bump" with a hammer untill they come loose, and specifically advise against twisting them.
I will try that today.
Partsguy57
For $60 there is no way you could go wrong with that machine.
jhn9840
John
Thank you sir!! Great buy on the spot welder. Welded up now and ready for install.7bdb92ffe6d3618f9d38e679fb6ffe18.jpg
skipnay
PA
I posted this in my other thread, but thought I'd post it here too.
A little cutt'n and fitt'n and a little bit-O-welding.
A little mobile burn table for my plasma cutter.
GP6o
Does this fold up also? This is kinda neat. It can't be lite that is for sure!!!
Has any one else made a plasma table like this? Thick I found myself another little project!
Keyblazer
Irvine, CA
Nice Partsguy!
Wow, I am likin' that plasma table... More info please!!!!
Just to wrap up the spot welder info...
Got the original tips out yesterday... you can see how shallow the taper is on them!
FYI, if anyone is inspired and finds a Lenco Panelspotter..
The Lenco Rep tells me that specific internal parts are long discontinued, but...
They do an upgrade kit, called CK-35($240 msrp), that replaces and updates the NLA parts to a modern version, but...
They are in limited supply, and Lenco is discontinuing them... so if you find a Panelspotter, I advise to grab a CK-35 kit soon...
FYI, I paid $177 for my ck-35 kit yesterday... last one that supplier had.
Also bought:
New trigger wire with switch, for $58.
Tip sharpener, $30.
And a Lenco ET-104.. Tip and consumables kit for $140
This includes:
(2)A-144 Regular Welding Tips 21050
(2) A-145 Welding Tip - Drip Rail 21040
(1) A-200 WeldingTip-Hollow Stud Welding 21080
(1) A201 Welding Tip-Blunt,heat shrinking 21090
(1) SPK-102 Welding Tip -Long Studs 28916
(1) SPK-103 Welding Tip -Mold Rivet 28917
(1) A-202 Welding Tip-Slotted 21100
(1) STSW Electrode Cleaning Brush 21060
(1) A-203 Welding Tip- Swivel Ground 21110
(100) SPK-109 Long Welding Stud- 100 pcs 28923
(100) SPK-110 Mold Rivets - 100 pcs 28924
(10) QPC-451 Star Tips 10 pcs 27451
So, I am pleased with what capabilities just got added to my shop!
1/ A spot welder, with multiple tips and abilities to weld and replicate OEM spot welds, in singles and pairs. It can also act as power supply for a double sided traditional spot welder, that I could buy, or make.
2/ A stud welding setup, that can weld studs, washers, star tips, and "Wiggle wire", but can also weld threaded studs, mold rivets, and trim studs, as well as screws, and mounting nuts.
3/ A spot shrinker to repair stretched metal, or reduce oil canning.
Jazzed!
