1066 bc
jbmatth
Northern Ok.
You have to be honest, even if there were directions would you really read them? LOL Looks great and I'm sure you are stoked to get it all together and working after a long build.
JB
G
gwellwood
Beautiful BC
For the armchair estimators out there, it might be worthwhile mentioning I am $65,000 CDN into this shop. I did almost all the work myself.
That also includes:
Hoist ($4000)
Air compressor ($2200)
Ground and polished concrete floor ($3000)
Upgraded the service to the house ($2000)
Excavation ($5500)
I had initially planted a fictitious cost figure of around $50,000. I'm close.
Stuff adds up, man!
Dr Stan
Owensboro, KY
That also includes:
Hoist ($4000)
Excavation ($5500)
Stuff adds up, man!
How big is it? Don't worry I'm bi-mathematical, Imperial & Metric.
G
gwellwood
Beautiful BC
Keep in mind, my dollars are Canadian, and everything is more expensive here - it's not just the difference in exchange rate.
G
gwellwood
Beautiful BC
Started working on compressed air lines.
Copper is scuffed with a green scrubbie, and clear-coated.
The intent here is the compressor feeds the rail which is sloped to a drain leg, and all the drops come off the top so moisture is less likely to go down each leg, and each leg has a drain at the bottom.
I may not really know what I'm doing here - all I know is the air lines at work ****, and this makes sense to me.
I seem to have run out of elbows, so this is as far as I got today.
dhubbard422
Texas Hill Country
Toys on a shelf are not junk, at least not per my definition. That's reserved for project detritus that you trip over day after day...
Air line month! Which Is often followed by air dryer or air after cooler month! Haha...
Shop is looking good! Your pace is so much faster than mine... keep up the good work!
Don
G
gwellwood
Beautiful BC
I seem to be taking really crappy pictures lately. Or it's the camera.
Got wheels put on my ratty old Horizontal Bandsaw. Much easier to tuck out of the way now.
G
gwellwood
Beautiful BC
Added another leg to the compressed air lines.
Still not totally sold on the brushed and clear-coated copper, but I started and might as well finish. I can always paint it wall-colour later.
I really didn't plan the placement of this and the make-up air vent very well. Ugh.
Two more legs to run tomorrow.
And with clickable-biggie-size pictures:
G
gwellwood
Beautiful BC
And it doesn't leak - Yay! 100psi through the lines, and we're still in one piece. And there was much rejoicing!
Did a bit of tidying up. Gotta move my bags of concrete for the spring-time driveway curbing.
jbmatth
Northern Ok.
It is always nice to have that happen, I'm still fighting a couple of old leaks, and one new leak in my shop air system. Well by fighting I mean they still leak and it is on "the list" to get to.
JB
Styx
Fraser Valley, BC. Canada
I was thinking of copper at the beginning but ended up going with the rapid air system and putting it in the wall all out of sight... Sure hop it doesn’t leak in the future...
My vote is stay with the clear coated copper...
Cheers Randy...
G
gwellwood
Beautiful BC
Well, essentially the shop is done.
I will be doing the driveway out front and a compressor building out back in the spring.
This left me feeling a bit of loss. I've poured so much of my attention into building it, and now it's done, and I didn't know what to do with myself.
So I built/modified a cart to hold all my milling cutters.
I started to convert my daily ('77 C10) to fuel injection, but ran into Christmas things like "family responsibilities" and "business holiday hours" and it didn't get done. I'm close, but decided to back off and enjoy the break a bit more relaxed.
So instead, I dragged the boxes of Firebird wiring out to the shop and started picking out the EFI wiring to put into my Firefly.
jbmatth
Northern Ok.
Nice cart, I really like that. Have fun with the wiring, I actually usually enjoy wiring vehicles, but I know others dread the task.
JB
G
gwellwood
Beautiful BC
My truck ('77 C10) will be going Megasquirt with a Holley big-bore TBI unit, adapted to fit the GM Rochester injector pod. When that all works, I will run an older Edelbrock Tunnel Ram, bungs welded for port injectors, with twin Dodge 2-barrel throttle bodies, also with Megasquirt. Probably run either Alpha-N or blended tables because my truck idles at 8inHg (potato-potato-potato).
The V8 Firefly currently has a stock 305 TBI V8. I will start with factory EFI to sort out the chassis, then my plan is twin T3/T4's and Megasquirt.
My Super 7 runs Megasquirt (Alpha-N) on a Toyota 4AGE, but I'm running Ford EDIS, Suzuki GSX/R ITB's, and Honda injectors.
I am very familiar with Megasquirt, and I'm cheap, so that's my "go-to".
Briggs
Charlotte, NC
I need this in my back yard. A lathe is my next big tool purchase after a new air compressor.
I like the cabinet arrangement as well.
G
gwellwood
Beautiful BC
My 11 year-old brought his metalwork project home, showing off that he used a sand blaster to create the texture. I said "you know, we have a sand blaster out in the shop." He got all excited. I said that it needed some love, and that if helped fix it, he could use it almost any time he wanted.
So.... He and I added two 100W (equiv) LED bulbs inside, and added a hookah pot for the shop vac. It worked pretty slick, but then stopped blasting sand, so I'm looking into that....
Styx
Most common reason for them to stop working is a plugged pick up screen or something stuck in the line to the gun.
Looking good tho love the vac set up...
Cheers Randy...
G
gwellwood
Beautiful BC
Yeah - I put my finger over the nozzle, and can blast air down into the hopper, but I just don't get sand coming back up. Took all the sand out and sifted it, but no improvement.
Bought a new section of the feed hose anyway, since the old one isn't very pliable any more. I bought that sand blaster back in 2003 for $189.
G
gwellwood
Beautiful BC
May need to add a rheostat or something to the hookah pot - the shop vac ***** all the water out.
Instead, for the time being, I ran the hookah with no water in it, and was pleased to see very little sand in the shop vac. I might just keep it at that.
Also planning some tool/holder stuff on the walls. Pics to follow soon.
G
gwellwood
Beautiful BC
Wiring the Pontiac Firebird V8 into the Pontiac Firefly chassis.
Slow going. Suzuki and Pontiac don't exactly share philosophies.
G
gwellwood
Beautiful BC
Well, while it's ~made~ by Suzuki, this one is officially a "Pontiac Firefly" here in Canada (Suzuki Forsa where you are, I'm sure). I'm just putting a better Pontiac drivetrain in it, so it's still "in the family" (sort of).
jbmatth
Northern Ok.
Your firefly will be one fun little car, I assume you are going RWD, do you have a build thread on it, I have a lot of questions that would probably be best answered that way.
JB
jbmatth
Northern Ok.
Thank you for the link, that is a pretty amazing thread, you've done a lot of quality work on the Firefly, and redone a fair bit as well. lol I think the most impressive part is the budget you've been able to work within. I'm glad I was able to squeeze out a few minutes to have a gander at it.
JB
G
gwellwood
Beautiful BC
Thanks for the kind words!
Grassroots Motorsports has their $2000 challenge - build a car that can win a drag race, autocross, and show, for about $2000. This year, the limit is $2017.
I am currently into it for $1800CDN, which is around $1300 US. I ~might~ stay within budget. If I had built a bolt-in cage, the cost of the cage wouldn't have been included - grrrrr..
jbmatth
Northern Ok.
Some of the other cheap car racing series I've seen don't include the cost of safety items like brake components, tires, cage, harness, helmet, etc. What is the reasoning behind including the cost of a weld in cage but not a bolt in cage? I want to do something like this eventually and have a friend who wants me to help him build a figure 8 car this summer. We will see if that works out or not though.
JB
G
gwellwood
Beautiful BC
It's just the way the rules were written. I'm hoping that by the time I can compete, they will change the rules and I can delete it from the cost.
But the GRM Challenge is not roundy-round racing, so you don't ~need~ a cage. I just know these cars are pretty minimal, and if I ball it up, I want to be able to walk away.
I intend first and foremost that it's a street car. I also want to do local autocross, drag racing, and hill climb, all of which require a cage because I have cut the firewall.
G
gwellwood
Beautiful BC
Now that spring is here and the snow is gone, I'm digging to form concrete curbing to flank a paver driveway.
And teaching my 11-year-old how to MIG weld.
