I'll see what I can do from my dp for you.Thanks for the information. I'll check your post out.. as far as the cover. I am going to fabricate a replica of the original. Was going to see if someone could or would be willing to get me some measurements of theirs or I was just going to wing it off pictures.
Sounds cool. Could always use a little bondo too if needed.
BTY, It does look nice!
Yeah, + 1 on the +/- on the belt length.
Because keep in mind, @ 2" difference, of course, the belt is on both sides of the pulley, so we are talking only a 1" difference.
I would just factor in, how far in or out the motor/motor mount sits from the press. You know, If its real close to the press, might not want to go shorter.
And on the other hand, if it's pretty far away, You may not want the belt longer.
But you probably l'm sure knew that.......LOL
Might be just me, but I don't like the motor slid too too far back.
Just feel it's more solid, somewhat closer, But in "real life".......lol.......it probably don't matter.
pretty Bad A$$ looking pipes on the bike. Can't see the motor too well, Is it
a Sportster?
Sheet metal is the correct material.
Sent from my SM-G900T using Tapatalk
is there a way to lube the chuck? mine spins but takes a little effort. there is no grinding or anything more like dirty or not lubricated.
Mine was kind of like that as well.. I let mine soak in a distilled vinegar bath for a while, then dawn soap wash and then rinsed it off. Let it dry real good then gave it a good spraying of T-9 lubricant. Really hosed it down with the stuff. Just worked chuck opening and closing it. Before you know it it was opening and closing smoothly. I didn't have a way of taking it apart. Don't know if this helps you but just thought I'd share how I fixed mine
So a huge shout out to FrankLee for talking to me about the 150's, I picked up mine today. It is a 113.24511. I am sure I will be asking FrankLee more questions and I will defiantly want a slow speed pulley.
It has a GE motor
So I had some craftsman decals made up. See the attached photo. These are the proofs. I should receive them by the end of the week. I'll have 10 available if anyone would like one. Already have a request for one and that person's is secured so the 10 left are unaccounted for. PM for one and when they come in I'll get your mailing address.
Thanks ndfan, that is a very generous offer! I don't need one, but that would be a great finishing touch for those who reconditioned a machine that had one.
Picked up a 150 today. The chuck has a lot of wobble. I am hoping that it is something that can be fixed by removing the chuck and reseating it. The press has a Jacobs Safe-Lock chuck with a swiveling threaded lock collar. I will re read the thread and see how to remove and hopefully fix this press up. I have an old Taiwanese press I hope to replace with the Craftsman 150. The 150 is missing the electric motor and pulley that would be on the motor. The guy I purchased it from took and put the motor on a squirrel cage for a fan in his garage.
You should ask him if you can go buy him a single pulley, and let you have that one, ?
Of course that's assuming he used the cone pulley on the fan.
Probably did.
He did use the pulley. Going to look at prices and availability of pulleys. I may message him about it, but first I will make sure that I can get the drill press cleaned up and usable. I'm wondering if the guy got a good deal on it just to steal the motor from it, or if he tried to fix it up and found it was more effort or money than it was worth. I got the thing for 25 bucks. So hopefully the parts alone are worth that.
I'm not too optimistic that the problem is the chuck. More likely is that the spindle is bent. If the machine is in good condition otherwise, the sindle can be repaired with a press, find a spindle on ebay, or find a donor machine.
$25 was a great price, even with the spindle and motor issues. You could get many times that parting it out, but I hope it doesn't come to that.
Thanks for the info. I figured for 25 bucks I wasn't getting hurt to bad. Glad to hear that is the case. The press is dirty, but the table is in decent condition. I think there is only one spot where a previous owner got into it with a drill bit. I will have to figure out how to pull the chuck off, and verify the spindle is in fact bent. I have a press, and a cousin that spent years in a machine shop. I may take it over to him if it is bent and see if he can straighten it out. Thanks again for the specific info to me and the great posts you have shared. Knowing this thread existed and you were around and had offered advice and info before made it a no brainer to pick up this 150.
We both posted at the same time yesterday and I didn't see your's until just a little while ago.
It's nice to know a machinist. I have a friend who has helped me out multiple times.
I'm actually rather reluctant to offer advice. I actually prefer to share my experiences, techniques and preferences. I'm glad they're helpful to you and others. Everyone's situation and resources are different.
I brought home #27 today; a 13-1/2" Craftsman 80, model 103.23640.
It's got a few issues. No motor, a worn motor pulley which may be repairable, a bad non-original Supreme chuck, and loose motor mount rods.
Overall, it's in good condition; nice table, engine-turned head frame trim in excellent condition, minimal rust.
That's the same DP I have. Looks pretty good. What is that collar on the post above the table?
I sure you will have it fixed up in no time!!
Wow, that's an ambitious project! will you go with wood or metal? Hmmm, Maybe plastic/Lexan would be fun...
Well fabrication of a replica cover has begun. Mock up complete. This is all been done off just pictures I found on the inter-web. I didn't have measurements to work off so it's a best guess.
