The thread of Dimple!! Finally.
Tinsmith
Fort St John B.C.
Wow! Thank you very much. :bounce: Thanks for issuing the the Challenge and donating the bounty. I have visited your website many times wishing for a set. I have imagined many things in life that can be improved with some dimple flare!
These will be put to good use, I can see a filing cabinet now with a **** load of dimples in it. Did manage to find a little heavier gauge metal, 17 gauge from an old furnace. It definetly was not as easy as the proir piece, but still came out looking well.
Thanks again, Jon
Reddittj
No worries, I just wanted to join in, and just good timing for a contest!
Thanks for the info. I will play with a larger hole this week.
Picked up my motor and frame today, so I will try to do complete body work in next few months
N
NASTYZEN
St-Colomban,Que. Canada
Hey guys, been a while.
The Spouse n I have been together for long enough that flowers and chocolate no longer cut it any more for Valentines day. So I got creative.
She has wanted shelves in the house stairway to the bedrooms for a while.
So here is how I got me some bedroom points using some dimple dies...
I had some pine planks that I could re cut in two's for the shelves and some 5052 .065'' thick Alu. sheet in stock. I used the width of the re cut board as a starter point and then made myself a cardboard template to layout a bunch of brackets. Then off to the shear to cut out some blanks.
With all the brackets cut out. I buffed them BEFORE making holes in them. Buffing things with holes in them is difficult not to mention dangerous.
After punching out the dimple hole with my Harbor freight knockout punch and bending the flanges. I gave the brackets a slight buff to get the small scratches from the break out. NOTE: I am not holding the bracket in the hole so as to not depart with my fingers should the part grab!.:mad:
A little paste.
Ready for dimpling. I love this setup for production.
A bit of a wipe with Acetone and there ready for mounting.
With a bit of a hand from my Son. We put them up before she got home.
A few spots to touch up with stain here and there. otherwise done.
Boy was she happy! Now I have to find some other project to keep my points going.:evil:
mgermca
Small dimple job on my son's V65 Honda bobber.
He needed a new battery box to be able to tuck a new smaller battery up under the new seat support structure and out of sight once the new side covers are in place.
We have a set of Claude's dies but used a slightly different size die set for this project, and a slightly unconventional method for making the holes. See the YouTube video clip linked below.
All fab done in-house in our workshop out back behind the house.
Build thread here:
http://www.customfighters.com/forums/showthread.php?t=121226&page=9
Video clip of the fab here:
Over & out, gotta get back on it, spring's a comin'!
f150skidoo
Ontario, Canada
NASTYZEN the polished brackets and the shelves looks good.
I bought some dimple dies a year ago and never used them so I decided to build a pair of steps for my dump trailer.
polexican23
burbs-Illinois
just found this thread looking for dimple options. I have an offroad buggy based on a VW chasis. What I want to do is put a hole/dimple for strength in the pan at the lowest point (behind the front seats) to make it easier for clean out. somewhere for the water to go.
problem is havent found much in the way of doing this, most die sets arent functional for use in the middle of a pan.
polexican23
burbs-Illinois
disregard the last post. I would delete it, but thought it would serve as a lesson.
Went to the beginning of the post and read NASTYZEN's first couple of posts. Hammer, HF punch. So looks like i need to save a few sheckles to buy a set from Nasty.
now, which set to go with.
overkill19
A buddy gave me this cause he didn't know what it was ! I told him, he said take it! Lol
Anyone know what brand? So i can buy the rest of a set. 0bea073ee02e883e0d52b04f0132fc63.jpg9785473a97fc50573f26d2f7e083d19a.jpga463477fd7e33885953b1187636a2629.jpg
Im guessing TMR but not sure
ilovevocs
Toledo, Ohio
Look like light racing dies to me.
Nastyzen is the in house go-to guy for flared hole dies around GJ.
If I bought a new set I would certainly buy from him.
TruckinT
I've got TMR dies, they're definitely not from them. The finish on the TMR is of much better quality, those almost look cast.
overkill19
They do kinda look that way but it just the finish on them, they are actually very smooth. Believe it or not!
bbcc
Edmonton
Test the surface hardness. TMR heat treats and QPQ (liquid nitride) their dies so they are pretty damn hard. Just by looks I'd say it's not theirs and what you have is a cast die judging by the insignia.
ilovevocs
Toledo, Ohio
Maybe I should have been more confident in my reply. That die is from light racing; the logo tells me so. I have a full set, have dimpled 3/16 a few times but it was just because I could.
For some reason that capacity was important feature to me when I purchased them.
However, the only applications I seem to deploy them in utilize gauge metal.
I despise hole saws and wish I had a set of the pipe sized dies that Nasty makes.
If your really interested in a set shoot me a PM; I would be willing to let these go and trade them out with a set from Nasty.
overkill19
Good man thx for the help!
That was my next question whats the good bad on pipe vs. Standard size?
ilovevocs
Toledo, Ohio
The pipe size dies can be used in conjunction with the HF hydraulic hole punch. You can use the unit to cut and flare. I use the unit for flaring but have to hole saw, then de-bur every hole.
The HF hydraulic punch unit it the best possible means of creating dimples with dies.
FlyingLow
Vancouver Island
Well I might as well post this up finally, I see this thread has been a little quite lately. A simple stand for the belt sander didn't sound stylish enough. Next time will be a welded pedistal. It's made from 16 gauge satin finish steel.40210bf74434e3f0479e1c12a41f2236.jpg71a7f20011437638aba42d879d04dd01.jpg0e836afe3533aa7876fe2e68bc2005f7.jpg
Sent from my Pixel using Tapatalk
Richard D
Texas City, between Houston and Galveston
I'm curious why they make them in pipe sizes. I guess if you were building a structure out of pipe, and wanted gussets that the pipe could slide through? I make a lot of stuff out of pipe, maybe those are the dies I should get...
EDIT:
I didn't realize conduit was measured like pipe, now I see why.
jw3
These are running boards for our Ranger xp900 with 8” of loft and 36” tires. I used 10guage steel. Damn I need to buy a press!!!lola46690a3aa0267a61f19503866e2278b.jpgc876810dfca85c3bf0194299f0e698fe.jpge2a5dcb356ac82640e8e3df0231716f5.jpg
WoodsTruck
Are you going to put some kind of flap behind the front wheels? I'm afraid those running boards will fill up with "stuff" real quick otherwise.
jw3
I may before it’s over with. I haven’t gotten that far into the build. Normally when we take them out, I needs a bath anyway. Lol
N
NASTYZEN
Hey guys, I am sorry to inform you that I am no longer selling dimple dies. Thanks to my insurance company no longer covering me for exported goods. Unless of course I give them an extra 15K a year...:wtf:
If anyone wants to pick some up at my shop for a super good price. I still have around 30 sets of standard sized ones left on the shelf. Ran out of pipe sized ones.
Thank you insurance dudes!
larry4406
Northern Virginia
Well that's pretty sad.
Include a disclaimer in all sales - "No warranty expressed or implied. Use at your own risk." Have purchasers sign at time of purchase?
ToolPolisher
Seeing as how we're all friends here, can we just send you money via Paypal and you send us a "gift" of some sweet dies for Christmas?
bad_idea
Pasquotank, NC
Well dammit. Today was the first time I saw this thread and I have been a member for several years now. I spent the last 45 minutes reading through the thread and saved visiting your site until I read to the end. It's disappointing to see insurance is killing the sale and manufacture of these.
N
NASTYZEN
Oh yeah, now everyone wants DD's....
I sold off all the stock I had to my friends at STG. If you are interested in a set of standard sized DD's. They regularly hold online auctions there. I believe they ship international.
Here is the link.
http://auctions.atelierstcg.com/auction.aspx?as=56062
They currently have two sets up for grabs. Items 138 and 139
I will post up future auctions as they happen.
Please note: I AM NO LONGER MAKING OR SELLING OR SHIPPING DIMPLE DIES. IT'S OVER!
It was fun, those who got some seem to be pleased with them, I broke even. Time to move on.
:beer:
f150skidoo
Ontario, Canada
I made a step for my trailer, the step is 5.25” wide by 22” long and made from 11 gauge steel.
