let's see your craftsman block grinders
ALLFAST
6Pony,
The red one looks exactly like my 1/3 Horsepower 1949....probably a Doerr from what folks have said here. It's a little tank...My data plate is faded thin except for motor and serial number...no name info.
torqueman2002
SE Michigan
Does the stator body with the windings need to be grounded to the frame? I've replaced bearings and the motor rotates freely, but as soon as I turn it on it hums then trips the breaker. I've tested resistance of all the windings and it looks fine. The windings all have continuity to each other, but not the body.
See post #3 in the following link for wiring diagrams; post #5 for relays and caps. --> http://www.garagejournal.com/forum/showthread.php?t=249539
If the field coils and rotor are not aligned properly on assembly, the rotor can spin freely by hand but 'bind' when power is turned on.
To maintain the proper air-gap, use of four 0.010" shims, between the rotor and stator.
http://www.garagejournal.com/forum/showpost.php?p=5181709&postcount=7017
balthor
NC
Thanks for the info, I'll check it out. I disassembled the relay completely, cleaned it and tested continuity. What should the relay coil resistance be? 0 ohms? This model is 1/2HP and does not have a starting capacitor.
After reassembling it, I added the light to the relay and switch, and the light worked. I then added the windings only, turned it on and it tripped the breaker almost instantly. The resistance of the windings adds up correctly.
Last week, I had it set up and got a small shock from the actual body (it's unpainted currently) and assumed it was ground fault due to lack of paint.
I'll get numbers again shortly. Any ideas?
torqueman2002
SE Michigan
Please see my comments in RED.
That's what I would expect. See the following SlideShows for the 2 different style relays I have dissected.
4CR Style --> http://s786.photobucket.com/user/torqueman2002/slideshow/CM%20011%20Start%20Up%20Relay
2CR Style --> http://s786.photobucket.com/user/to...1/2HP and does not have a starting capacitor.
That sounds like a short of one or more windings to the case. Leave the grinder assembled, but disconnect all the electrical connections.
Connect one leg of your Ohm meter to case (ground), then test each electrical connection -- they should not have continuity to the case (ground). Fix the short, and reassemble and verify the fix.
:thumbup:
torqueman2002
SE Michigan
Where did you get the info Bub? (Correction: Dr. Block!) Here is what I have (so far) but open to correction if off (and some Conflicts...)
257 Allegretti & Co & Paramount; Paramount (now Poulan), who continued the Delco model Block Grinders
306 Belsaw Machinery Co.
397 Delco Products Corp. (Motors and grinders)
And Some conflicting info:
115 Packard Electric 1890 -1932 - from 32 on a division of General Motors (Division of General Motors - Purchased by Delco in 1932) 1890 -1932 - from 32 on a division of General Motors
In 1943, Sunlight Electric's small motor production was consolidated with Packard
115 1917-33 Sunlight - Sunlight Electrical Manufacturing Co. Purchased by Delco in 1932 Sunlight Sm Motor production consolidated w/Packard Electric (Division of General Motors) in 1943 - "In January 1940 the Sunlight Electrical operations were separated from Delco (Conflict) "It is believed that both Sunlight and Packard built motors and grinders for Sears"
Sorry for slow reply.
I thought I'd put links to my source information, but it appears they are 'broken'.
I've corrected the 'broken' links in the thread: "Craftsman Block motor Bench Grinders - What's the Fuss (with resource information)", post #3
I don't know what the real truth or the alternate truth/facts are. Like so much information on the web, it has to be balanced with reasonableness and multiple sources.
balthor
NC
Thanks. So I got it to spin for a few seconds, and I think the issue is my windings are slightly damaged. Uh... well I was going to take a picture and well the starting lead connector fell off.
How can I repair this, recrimp the lead? What spray should I apply to avoid shorting?
torqueman2002
SE Michigan
There is more than 1 way to repair that, but here's what I would try.
The copper colored 'bare' looking wire is actually coated in a varnish type insulation - IIRC. That needs to be scrapped off and the connector w/ Red wire needs to be removed, leaving as much of the Red wire as possible.
Then, I'd splice the Red wire and copper wire with an insulated, water proof connector. ie: Polyolefin Heat Shrink **** Connector, Waterproof Crimping Terminal
You may not need to insulate the thin wire, but if it is necessary -- you can use shrink tubing or ie: Gardner Bender LTB-400 Liquid Electrical Tape, Easy-on, Waterproof.
BradnCali
I jumped on this one minutes after it appeared on Craigslist for $35. It's got everything but one of the tool rests, removed for the tool sharpener.
Brad
balthor
NC
Nice, I just ordered some Liquid Electrical Tape.
Does it matter if the starting wires are shorted to each other? Here is a picture since GJ has issues with embedding imgur.
https://i.imgur.com/yBPJ697.jpg
torqueman2002
SE Michigan
That's too bad, but it may be OK to use.
First - confirm the resistance of the start winding is within 10% of spec.
Then - carefully separate the individual wires just enough to allow a coating of the following --> MG Chemicals Red GLPT Insulating Varnish. Allow to dry and place the wires in the original orientation.
BTW - that is probably where the short to the case (ground) is/was.
Finally - reassemble, verify the rotor is aligned and does not rub, verify there are no shorts to ground, then power up.
notlob
norcal
Here's a really nice 1/2 hp commercial for sale in the San Jose area:
https://sfbay.craigslist.org/sby/tls/6104192871.html
:3gears:
Shiftless
East Bay SFO
Is that set up for motor drive from underneath? I see a switch on the block. Shall we assume the stock motor is dead and the P.O. Figured a way around that problem?
Are those stones on the ends simply worn down grinding wheels?
Are there chucks on the shaft ends?
No Guards?
Scary!
torqueman2002
SE Michigan
That would be my guess, points for not trashing it...but not too safe :eyecrazy:
There was one like this in our area. Older pre-Block converted to run with an external motor.
If I'd been closer, I might have paid the $20, as it still had every thing else intact - metal frame eye shields, wheel guards, and tool rests.
balthor
NC
Well, I went through and coated all the exposed windings with varnish. I tried to power it on multiple times, even spun it then flicked the switch, and as soon as I did the arbor stopped in it's tracks. It looks like I'm going to have to rewind this thing. Any suggestions on where to purchase good windings and the gauges required?
exmaxima1
Midwest
I recall you have a Split Phase 1/2hp model, and not really worth putting that kind of money into it. Time to part it out or look for a donor grinder that needs your parts.
balthor
NC
I hear ya. I would like to learn how to rewind this thing myself, but am also wanting to get a grinder up and running. I'm fine with spending money, if it allows me to learn a new skill.
As far as the windings, are they aluminum windings coated with a varnish? When exposed, they have a light metallic color, not a copper color. Does anyone know the gauge of the starting windings and the main windings? I can get the measurements, but I'd prefer accurate numbers from someone with a working grinder, haha. I'd like to replace the windings with a more modern approach, I believe nylon coated windings with paper insulation and wraps for integrity and strength.
I'm also looking for a suitable replacement starting relay to use for testing. I've completely ripped my current relay apart and tested all the continuity and resistance through it and believe it is working fine. I'd like to purchase a more modern replacement, but am unsure of exactly what specs are required.
If I can get this thing in a working state, I'd definitely post my troubleshooting and experience, in order to help out other people.
cajunfirehawk
Ms Gulf Coast
Stripped block grinder $19.95 see eBay item number:172663419362
torqueman2002
SE Michigan
I don't recall a post where that's been done in this thread al least.
It would be a great thread/post.
You might want to search on OWWM website, link - --> http://owwm.org/.
Good luck, let us know how you make out. :thumbup:
jeeper46
Canton, Mi
Ever since I started coming to GJ, I was interested in these block grinders-I just have a couple of Chinese ones, and I wanted something good. Today, a 1/2hp Craftsman grinder came my way-almost unused, with what I figure is the original tubular stand for it. Both plastic eyeshields, and the water tray,too. The tray looks like it has never had water in it, and I would say this grinder had never been used, except that someone ground something aluminum and slightly loaded both wheels. The wheels are the original Sears ones. This one's too nice to use! I do a lot of wire-wheeling, so the HF ones aren't going to get a break.
trijeff
Northern Cali
I've got a 5538407 left side assy and a tool rest assy, PM me if interested8336562b12957539e68e848d3fce591a.jpg
Smokeshow69
Scored this mail box 1/3 hp mail box grinder off craigslist for $15 [emoji1] it is a 1970 and I wanted it because it has the glass eye protection! I cleaned it up and it works great! Has some random paint splatter on it but it is a good user ! I am selling my 1975 1/3 block grinder that is nice if anyone is interested ?
6pony6
VA
My first ever bench grinder restoration. Obviously it will need the eye shields and a few other things. Let's see how it goes.
6pony6
VA
Well, I've got $30 in it at this moment so I should come out ahead.
As far as the Mustang, it was a very late 66 production car and originally had a 67 color called Beige Mist. That color was hideous, so it's now another 66 color called Tahoe Turquoise.
wrxr7
Tonawanda, NY
Just picked this up last night off Craigslist. I've been looking for one for quite a while now.
Needs to be cleaned up, but is complete with both eye shields, tool rests, light and quench tray. Mounted on a very heavy stand.
torqueman2002
SE Michigan
Nice find! :thumbup:
I'm surprised the Buffalo/Niagara area doesn't seem to have the supply of other NE industrial centers. IIRC - there is/was a lot of manufacturing, leaving me to think there would be a steady supply of Blocks, like in SE Michigan. But, I haven't found that to be the case.
That will serve you well.
torqueman2002
SE Michigan
I received a question about what I think is the 'best' Block grinder.
Setting aside the round top vs. flat top style preference, and the differences in the numbers Sears produced for the different HP/model Blocks - here is how I replied.
"Like many tools, what the application/use will be, is very helpful in choosing the grinder to buy.
Here are my thoughts on the different Block grinder HP models, round top vs. flat top style preferences aside:
1/4-HP, pre-Blocks, under rated power - more like 1/2-HP, may not come with eye shields, spark arresters, light, or power sw
1/3-HP, light grinding sharpening, light rust removal
1/2-HP, light - medium duty home shop use. Sharpening mower blades, light - moderate rust removal
3/4-HP, medium - heavy duty home shop use. Sharpening mower blades, moderate - heavy rust removal, light - moderate polishing
1-HP, heavy duty home & industrial shop use. heavy grinding, heavy rust removal, moderate - heavy polishing".
I realize that there are 1/4-HP round and flat top Blocks, but I don't have any experience with them.
I'd like to hear what other Block users think.
Thanks for reading. :)
