woodturner9
Indiana(ish)
Nice try and nice misquote of the mods there, that post was in a different thread for completely different reasons.
If the mods think the discussion about how to get deals is off-topic, I'm sure they will let us know.
There are differing views on what this thread should be and what is on-topic - please allow others to have their own views and try to not put down others for having a different view.
7avalon7
KY
Found this promo this morning. Only apply for in-store and please read the disclaimer! Decent deal if you need to get something from local store. Hope this helps someone :thumbup:
$19.99 for $30 valid in-store at Sears
$39.99 for $60 valid in-store at Sears
$69.99 for $100 valid in-store at Sears
Promotional value expires Jul 16, 2017. Amount paid never expires. Limit 1 per person. Valid in-store only at Sears stores located in CA, CO, GA, ID, KY, LA, MD, MI, MN, MO, MS, NC, NE, NH, NY, OH, OK, PA, SC, TX, UT, VA, VT, WA, VW. Not valid online. Not combinable with other coupons or vouchers. Not redeemable for cash, unless required by law. Not Valid at Sears Outlet, Sears Appliance Store, Sears Optical, Sears Hometown Stores and Sears Auto centers. Excludes Clearance Items,Grocery, Pharmacy, Cleaning supplies, Home services, Gift cards and Calling cards, Protection agreements and Lands' End products. All Sales Final. No returns, no exchanges (except for defective merchandise). Minimum purchase equal to the full offer value required. Purchase requirement before taxes and other discounts. Merchant is solely responsible to purchasers for the care and quality of the advertised goods and services. Offer is not eligible for Groupon promo codes or other discounts.
https://slickdeals.net/f/10191748-30-33-off-at-sears
EOC_Jason
Bentonville, AR
Sears is so stupid... Some items they will ship for free pickup to my Hometown store, other's they will only ship to the large Sears (that is 30 miles away)...
woodturner9
Indiana(ish)
It depends on which business and location sources the product. Hometown stores are essentially a separate business and they do not have access to the full line of products.
BTW, ship to home is free on nearly everything if you place the order on the terminals in a Sears store. Not sure if that works in Hometown stores or not, but if it does, you could order from the Sears website in the Hometown store and have it shipped to your house free.
potato
"★★ Hot Deals ★★
Looking for great deals, coupon codes, and all kinds of other links to time limited deals found on the internet? This is your place. Got one? Post it here"
Fatboy148
Multi-dept. promo code: 10off25
Sears or Kmart website. Excludes the usual Hot Buys, Great Price, Clearance, etc. Expires: ???
A few tool-related ideas:
Greenlee Cable Cutter with Dipped Grip $25.98
Pro Lift Pro Lift Foldable Mat - 6 Fold $29.98
Kreg Pocket-Hole Screw Kit (675 of 5 most used screws) $24.13
Craftsman Best Carpenter Pencil $0.99
In on the screws with the pencil to get me over $25.00. $16.33 total is almost half of what I pay at Home Depot. Thanks!
EOC_Jason
Bentonville, AR
Yeah I knew the Hometown stores are independents... My store doesn't have a terminal like the regular Sears stores do... And the regular sears is 30mi away.
I'll figure something. I want to use that $10 off $25 plus I have $12 in points...
fr0mastaj
Digital4n6
Glen Allen, VA
5-degree ratcheting. Has 4 sizes per wrench, 2 wrenches in the pack. Standard and Metric avail. $24.99 as a Hot Buy, but can use your points just not coupon codes.
A Ratchet Box End Set That Grips Eight Sizes with Two Tools
If you like traveling light, but want to be ready for whatever mechanical troubles are headed your way, throw this Reversible Gearwrench set in your to-go kit. A serious help when you’re on the road, this pair crams the cranking power of eight different SAE wrenches into a tight package without losing a lick of grip. Whether you’re a side of the road boy scout, or handyman tired of dragging hundreds of tools to the job, this set gives you a firm grip on 5/16 – 3/4 nuts and bolts. Perfect for a back pocket or tool bag, it’s always ready to lend a hand.
Equipped with fast switching reverse levers and a fine toothed ratchet assembly, this Ratchet Box End needs as little as 5 degrees of sweep to turn nuts and bolts, while reversing directions with the flick of a thumb. The perfect companion pair to working in tight spaces, this set was designed to move with speed and agility between jobs and last for decades. Crafted from tough alloyed steel and backed by a commonsense lifetime warranty, add this pair to your pocket, tool bag or chest, and get a serious grip that will travel.
Reversible Gearwrench set includes: 5/16 in. x 3/8 in. and 7/16 in. x 1/2 in. wrench, 9/16 in. x 5/8 in. and 11/16 in. x 3/4 in. wrench
Light and seriously portable, this set is a must have for on-the-go repairs
Four sizes on each reversible ratcheting wrench deliver a solid grip
Two reversing levers swap torque direction with the flick of a thumb
Mirror finish, all metal construction, fully hardened mean they wipe clean and are always ready for more work
Each wrench needs as little as 5 degrees of sweep to move a fastener, perfect for tight spaces
Each box features Surface Drive® machining which directs torque to the toughest part of each nut and bolt head, practically eliminating rounding and slip
Warranty: Limited lifetime
http://www.sears.com/gearwrench-2-pc-metric-reversible-quad-box-set/p-00944021000P
http://www.sears.com/gearwrench-2-pc-standard-reversible-quad-box-set/p-00944020000P
woodturner9
Indiana(ish)
You could try a test to see if ordering from your phone while in the Hometown stores gets you free shipping - that also works if you are in a Sears store.
bagged150
Waldorf, MD
The "10off25" is a promo/coupon code you enter on the shopping cart page. But it won't work for any item that is on sale / great buy / whatever...
Oh okay. I'll have to check to see if there is anything I need that is not on sale. Thanks.
kball
SoCal
Some things on sale work. I just got another padded chair and utility knife (to put it over $25) and it worked. The padded chairs are on sale for $22.99. I ended up paying $6 for both items after the 10off25 coupon and $10 in points.
Tellingthem
Traverse City, Michigan
This might have been covered else ware but you can still order ratchet repair kits at sears. I did it through the manager but I got 2 each of the premium ratchet rebuild kits (for free...err 1 cent but they didn't charge it) Im not sure which are available for which ratchets but he ordered them instore and they came in about 10 days. And these are for the us built premium ratchets. So I would see if your manager will do the same if you need any before sears goes belly up.
dodge610
North Canton Ohio
Sears price now $30.49 just picked one up at K Mart for $18.49. Same company shady way to sell tools. K Mart the new Sears lol [emoji23]
outdoorspace
I was able to use the 10off25 code twice on the same account yesterday for two sets of adjustables free after points. The code still works as of this morning on the same account.
gamp945
I used 10off25 yesterday for a few Lisle items. 40% off of competitively priced items is a very good deal! I then tried using it again but it wouldn't work. I tried again just now and it is allowing me to use it again.
Now...what to buy???
btoonsis
Central NJ
I used the "10off25" coupon three times over the last three days from the same account on the following:
http://www.sears.com/ludell-8-lb-sledge-hammer-with-35-in/p-00943302000P
... and...
http://www.sears.com/hansen-1-2inch-dr-metric-socket-tray/p-00933933000P
http://www.sears.com/hansen-1-2inch-dr-sae-socket-tray/p-00933936000P
... and...
http://www.sears.com/craftsman-5-8-in-x-75-ft-hose/p-07169603000P
All were on sale (but not "Hot Buys" or Clearance)... available for store pickup... and just over the $25 mark. Plus, I had some points expiring...
I did notice one thing... sometimes, I had to try adding the coupon several times before the $10 discount applied. In one case, I gave up... but tried a few hours later and it worked... might be worth a try if your items are eligible but the coupon isn't accepted.
T45
http://www.sears.com/stanley-stst14...sellerId=SEARS&prdNo=3&blockNo=3&blockType=G3
Stanley STST14022 SortMaster Junior Organizer, $6.52
http://www.sears.com/hansen-3-8inch...sellerId=SEARS&prdNo=3&blockNo=3&blockType=G3
Hansen 3/8" dr. SAE Socket Tray, $8
Might be a good filler item/s on $19.99 purch etc.
http://www.sears.com/sunex-extra-la...lerId=SEARS&prdNo=32&blockNo=32&blockType=G32
Sunex Extra Large Locking Screwdriver/Pry Bar Holder, $35
http://www.sears.com/sunex-side-wor...sellerId=SEARS&prdNo=2&blockNo=2&blockType=G2
Sunex Side Work Bench for SUN8013A, $29
(Not a hot buy or any other restrictions, and nice discounts even before 10/off $25)
bubinga
Good Deals above!!
Those Pry bar case locker things for the side 0 your box are nice Had one on my 2nd hand blue point cart I brought used and paid too much for, didn't know about the Red HF ones.
Did get $100.00 for it, but told the guy the locker did not go with it.
He still tried to weasel it out of me, but I told him NO!
Then I gave him the keys so he could haul it home form work, and take a few of my things out, He was putting them in his box, saying they were his.
Meanwhile I had a Big Old T ground in the cotter pin puller.
And a line hacksawed in my Snap on 1/2" down to 3/8 impact reducer,
Had to steal that back later, Then he had my set of snap on line wrenches.
Called and asked a year later if he had them he said NO!
texted me a week later,
"I have your line wrenches...............................Don't ask" I said OK.
I'd like to know what else of mine he has over there.
Then I had a 5 gallon bucket of hammers and stuff, He says,
"well that's stuff we both use"
NO!!!!!!!!!!!!!!!!!!
I want and got it the next day, those hammers and bars would have found a Foster home too.
and my 24" 1/4" MAC extension in the bottom of another box,
said it "was his sons"
Must have felt guilty, texted me later said His son had his, "It must be mine"
80sBMX
Bummed... just tried to use 10off25 a few times on sale and reg priced items and it says, "We're sorry, this coupon is no longer valid."
EOC_Jason
Bentonville, AR
Same... :(
I noticed if you leave a coupon code in your cart, you can still use it typically even a day after it expires... But if you remove it then you are SOL....
YMMV of course...
nahudson
Looks like the 10off25 code is dead. I cannot get it to work either. Thankfully, I used it a few days back for some items
Doohickey
Wild Wins Wednesday.... 5 spins to win some extra points...
https://syw.co/2s3RWVD
Also there is a game showing up as a doorbuster right now, "Time to Win", sorry I can't figure out a direct link to it...
Time to Win
They'll add $1 in points even if you lose.
Enter once for the $1 doorbuster. Here are some codes for extra entries: OUTTATIME , bouqu3ts
Doohickey
Sorry, didn't know the 10off25 code would expire so soon.
With the increase in store closings, and Sears clashing with Ideal (WF) about supply...it's a gloomy week.
