5-degree ratcheting. Has 4 sizes per wrench, 2 wrenches in the pack. Standard and Metric avail. $24.99 as a Hot Buy, but can use your points just not coupon codes.
A Ratchet Box End Set That Grips Eight Sizes with Two Tools
If you like traveling light, but want to be ready for whatever mechanical troubles are headed your way, throw this Reversible Gearwrench set in your to-go kit. A serious help when you’re on the road, this pair crams the cranking power of eight different SAE wrenches into a tight package without losing a lick of grip. Whether you’re a side of the road boy scout, or handyman tired of dragging hundreds of tools to the job, this set gives you a firm grip on 5/16 – 3/4 nuts and bolts. Perfect for a back pocket or tool bag, it’s always ready to lend a hand.
Equipped with fast switching reverse levers and a fine toothed ratchet assembly, this Ratchet Box End needs as little as 5 degrees of sweep to turn nuts and bolts, while reversing directions with the flick of a thumb. The perfect companion pair to working in tight spaces, this set was designed to move with speed and agility between jobs and last for decades. Crafted from tough alloyed steel and backed by a commonsense lifetime warranty, add this pair to your pocket, tool bag or chest, and get a serious grip that will travel.
Reversible Gearwrench set includes: 5/16 in. x 3/8 in. and 7/16 in. x 1/2 in. wrench, 9/16 in. x 5/8 in. and 11/16 in. x 3/4 in. wrench
Light and seriously portable, this set is a must have for on-the-go repairs
Four sizes on each reversible ratcheting wrench deliver a solid grip
Two reversing levers swap torque direction with the flick of a thumb
Mirror finish, all metal construction, fully hardened mean they wipe clean and are always ready for more work
Each wrench needs as little as 5 degrees of sweep to move a fastener, perfect for tight spaces
Each box features Surface Drive® machining which directs torque to the toughest part of each nut and bolt head, practically eliminating rounding and slip
Warranty: Limited lifetime
http://www.sears.com/gearwrench-2-pc-metric-reversible-quad-box-set/p-00944021000P
http://www.sears.com/gearwrench-2-pc-standard-reversible-quad-box-set/p-00944020000P
