I didn't think of the torch. I even have one for burning weeds.
I don't trust good adhesion to old slab with the drips that hardened to it. I tried grinding them off with the diamond grinder and they are really on there. I don't have the time or patience to get the drips off to use sheet material effectively without the risk of water seeping up from the bottom anyways.
I ground off all the high spots and goobers on top and corners of wall then removed all the plastic tubes from the rods.
3 were pinched and had to be cut off. The rest came off easily.
I lifted the garage on all 4 jacks just barely off the cribbing then removed another 2x and cracked all of the jacks just barely going around making sure they lowered as evenly as possible.
The garage is now resting on cribbing 3/4" above the wall. Just enough room to get sill seal in place and lower the rest of the way when I'm ready.
I put the foam in place around 3 walls and decided front forms will stay on until spring. I dont have the patience or feel like digging out the clear stone multiple times when I could just do it once in spring and shovel it right into the garage.
Next step is get sill seal in place, lower and get the wood bracing and accross garage door off, track back on and garage door closed.
I'll leave the main beams in place for time being and keep just a touch of weight on the jacks.
I'm an organization freak and it bugs the **** out of me how messy everything is.
I brought a load of wood stakes and everything small to my uncle for firewood.
Friday I'll load the truck with as much as possible to return to menards. Concrete blocks and all the treated 4x6 that I didn't even use. The less **** laying around the better.
Sure looks different with white foam on it.
