Re: The Lone Beech Garage Build Thread (60x46)
Friday - November 17, 2017
My son and I spent the a bit of time this morning moving stuff out of the way to make a clear path for the JET Mill to be moved. As we were moving things I was thinking about the ideas I had read on the internet about the placement of a vertical mill in a room. More than a few people had mentioned being very happy with their mill backed up to a supporting column. I had disregarded that as an option because I didn't have any columns in the Lone Beech Garage.
Then it dawned on my that the posts of the 2-post lift were "columns". I mentioned the above to my son and we pondered the idea of positioning the JET Mill near one of the 2-post lift columns. After some thought that idea was abandoned and we returned to Plan A: Moving the JET Mill to a position between two windows on the southern wall.
The Mill-Drill had been living in the location I had chosen for the JET Mill so it needed to be moved as well as a few other things.
When the path was clear to our destination, we marked the midpoint between the windows on the floor and measured out 50-1/2 inches. This would be the aiming point for the front of the JET Mill's footprint. A piece of masking tape was placed on the JET Mill and a mark was made indicating the center of the mill.
It was time.
Raising the forks on the Pallet Jack just enough for the 4x4's to clear the floor, I started pulling the JET Mill across the floor. I made a turn into the Metal Working Bay and then made a 180 degree turn past the landing point. A bit of back and forth followed to get the JET Mill lined up on the mark we had made on the floor.
I think the JET Mill is in the location I want but I do need to confirm that I have placed it far enough from the wall. When I placed the mark on the floor locating the location of the mill I was figuring the Ram would not go any farther to the rear than where the dovetail enters the column. That may have been a mistaken assumption and I need to verify that before I bring the mill off the 4x4's and onto the floor.
If the JET Mill is not at its final location it is within inches of being so.
A really good day in the LBG!
Scott
Key Words: Pallet Jack Vertical Mill Milling Machine Knee Mill Bridgeport Moving
It was time.
Scott
