Craftsman Drill Press
F
FrankLee
seMI, 48317
So here's an observation - compared with picture #10 from your link, looks like someone changed the bearing (?) and put two spacers to keep the pulley up, however the spacers are not keeping the pulley high enough. I assume now I need to figure out where to get more spacers.
I agree. Here are my observations.
Your sleeve bearing is either worn down, pressed down too far, a previous owner replaced it with a shorter version, and/or the splined sleeve was not pressed up enough to be fully seated into the pulley. That's why there's vertical play when you lift the pulley. The sleeve bearing should stick up from the head frame casting. The inside ring surface in the pulley should ride on the end surface of the sleeve bearing. Is that a steel washer pressed into the pulley?
Maybe the previous owner pressed the sleeve bearing too far into the head frame casting. Check from inside.
http://vintagemachinery.org/pubs/222/4727.pdf
You may want to verify whether the steel washer (26714) and snap ring ((26811)are present at the bottom of the splined sleeve (26617).
RHJO51
Red Hook, NY 12571
Thanks guys! This one doesn't pivot front to back, but up and down on an angle very easily. JB Weld and drill it is! Plus new belts, which thanks for the part numbers too!
I did that JB Weld and drill/ream on two of these Vari-slow rigs and it worked great. I've had no issues with the JB Weld. Good luck!
Plombob
Tennessee
I thought you guys would be interested in the restoration of a DP I bought a couple of years ago. Our member Zeet did the work and it came out great. I posted a review in the Vendor section because Zeet does machinery restorations for a living. Here's the link and a tease.
https://www.garagejournal.com/forum/showthread.php?t=391200
View media item 83137
It's so purty I might not be able to use it! :(
paulm12
NW Chicago 'burbs
I am ordering the spindle bearings today for my recent 103.23640. I have it apart down to sub-assemblies so far. I forgot to take a picture of the inner bearing. I assume is the same as the outer bearing? And any ideas why the original schematic shows the inner bearing as part of the spindle assembly? and it doesn't therefore list a part number for that bearing? Just wondering.
Thanks all, and thanks a bunch Frank for this thread. Disassembly was easy following the steps and comments. Especially that hidden screw on the spindle pulley.
F
FrankLee
seMI, 48317
You're very welcome!
Yes, both the upper and lower spindle pulley bearings are the same part number.
I would verify that the old bearing inner race did not spin and damage the spindle pulley shaft. If it did, you may consider an extended inner race bearing.
Check this post by Cjmac and several posts following:
https://www.garagejournal.com/forum/showthread.php?p=7096809#post7096809
F
FrankLee
seMI, 48317
That is beautiful work!
Many times original paint cannot be saved, but I like original paint so much that I'm kinda going somewhat in the opposite direction. I believe I'm going to be swapping the base, column, and table from dp#41, rust, paint drips and all, into the head frame, etc., from my dp#15 (background).
paulm12
NW Chicago 'burbs
Frank: yep. read through that thread too. So much useful info here. Thanks again.
lafester
Northern CO
Many times original paint cannot be saved, but I like original paint so much that I'm kinda going somewhat in the opposite direction. I believe I'm going to be swapping the base, column, and table from dp#42, rust, paint drips and all, into the head frame, etc., from my dp#15 (background).
Original is the way to go unless it's bronze.
Currently stripping my bronze/gold pedestal and I'm really liking the naked look as well.
Only way I would keep bronze is if it was in very good condition.
Sent from my moto x4 using Tapatalk
lafester
Northern CO
Wouldn't let me add a pic.
These picture issues are driving me nuts.
Rushton
Richmond, VA
FrankLee, what are the dimensions of the rectangular plywood base you have under the Model 100 Drill Press in your picture below? It looks to be just about right for the base I should build under my Model 150 to deal with a non-level floor and give the DP a more stable platform.
F
FrankLee
seMI, 48317
Those are 22" x 29.75". More info on those here.
paulm12
NW Chicago 'burbs
Frank: here is the spindle shaft. Seems ok, picture looks worse than it feels. The first bearing I used a puller with a nut over the end of the shaft, it didn't take much force at all to slide it. Then I was able to pull off the bottom bearing by hand, not real easy, but it came off. I will clean up the shaft with some steel wool or very fine paper, just enough to slide on the new bearings easily.
New bearings are on order from Accurate Bearings.
Thanks
F
FrankLee
seMI, 48317
Thanks
Yep, that looks pretty good.
Smokeshow69
Started working on a bench top model I got from Oregonrockcrusher! It was pretty ratty looking but so far is cleaning up well! It was pretty rusty and had not received any love for years but only because all the machines he has are of the highest caliber and all are fully restored vintage examples! He graciously let me get my paws on this one[emoji5] I already have a nice original crowntop 150 model so I am giving this one to my brother. So far, all the rust has been removed to reveal nice parts that just needed some elbow grease. I am not repainting it as I don’t have the time right now and since all the other chrome and metal is not perfect, if I painted it, they would look even worse. I removed the light and switch and degreaser it! The original paint actually came out very presentable given what it did look like.
After degreaser and hot water with dish soap
Smokeshow69
Re: The Classic Craftsman 100/150 Drill Press
Picture of the column before the craftsman block grinder
Clamped in the smooth jaw vice for work
After
What do you use to remove the column foot plug bolt ? Why a rhft craftsman ratchet and a craftsman long c 8 point socket!
Feed stop is clean but the nut was not cleaned yet. You can see how much surface rust was on this thing
lafester
Northern CO
After
Looking better already! I thought it was bronze at first lol.
If you feel like selling that collar I've been looking for one. Couldn't tell if you have both lock nuts but I have a spare that needs a home.
Smokeshow69
Thanks but I want to keep the collar with the machine [emoji51]
Smokeshow69
I was able to get both table tops and the column waxed and set into place tonight. Hard to believe it is the same machine!
Picture of the wax I used and the lube I am using on all the nut inserts on this machine
Also pictured is my drill with a wire wheel chucked up in it. That thing has been a lifesaver especially with the small places a larger wheel can’t get to
Rileysan
Milwaukie, Oregon
I'd like to thank Smokeshow for pointing me in the direction of this Craftsman model 103.23130 bench top drill press. I happily gave the man $100 for it. It has been very well cared for and so far the only thing wrong I have found is a worn bushing on the middle pulley. It has been really well cared for!
Are the stamped numbers on the date of manufacture? It says "J3 48".
My Craftsman X-Y vise looks really good on it. I got that as a resuof Smokeshow playing a prank on me a few months ago 😀
Brian
sheltonfilms
My Craftsman X-Y vise looks really good on it. I got that as a resuof Smokeshow playing a prank on me a few months ago [emoji3]
Brian
Are you talking about the sleeve that you pulled out with the bearing puller/slide hammer? That shouldn’t be worn at all. Slack is taken up by the set screw that comes out at an angle from the main plug of the pulley assembly. If the main plug is spinning in the sleeve, then it isn’t tightened down enough.
F
FrankLee
seMI, 48317
My Craftsman X-Y vise looks really good on it. I got that as a resuof Smokeshow playing a prank on me a few months ago ��
Brian
That is a beauty!
Yes, that is a date code. I'm not sure how to decipher the first two digits, but the second group is the year. Perhaps "J" is the month (October), and 3 is the week of the month. I dunno.
I'm very curious about the bushing wear also. Please elaborate. You shouldn't really need a puller on that sleeve unless the column is upside-down and the sleeve was jammed into the too-small end. That was the case on my dp#1.
Smokeshow69
Brian
When I pointed this out to you I had no clue it had the 3rd pulley. You ****! I can’t think of a better home for it to go to!
Rileysan
Milwaukie, Oregon
That is a beauty!
I wasn't sure how tightly that bushing was in place, so a little gentle persuasion with a Plomb slide hammer made short work of it.
When I first started the dp, I heard dry bearings. When I looked towards the center pully, it was rocking back and forth. After pulling the assembly, I could clearly see wear on both the bushing and the shaft. There's easily.030" play in the assembly. However, you gave me an idea. The bushing can be turned over by removing the snap ring and placing it on the other side.
Brian
sheltonfilms
Brian
If you only have one snap ring then that is your problem. Should be one on both ends. Frank was able to recreate them using 14 gauge bike spokes.
https://www.garagejournal.com/forum/showthread.php?p=4870269&post4870269
Rileysan
Milwaukie, Oregon
I worked on it this morning and honestly can't see how two snap rings would work. The housing is too narrow to allow the bushing to slip into the housing with one on the bottom and top. In fact, the one snap ring at the top acts as a stop to keep it in place.
To each his own, they say. I flipped over the bushing and moved the snap ring to the opposite end then added shims to the outside of the bushing as I slid it into place. I also replaced the bearings and reassembled it. The wobble is gone and it runs smoothly.
Brian
sheltonfilms
Brian
Measure the ID of the column. If you have a 2 3/8” ID then get rid of the snap ring altogether. The snap rings are there for 2 1/2” ID columns on later models.
Again make sure you are using the right end of the column. The right side will have a machined inner bore and will have almost a shelf so the plug won’t fall in.
Rileysan
Milwaukie, Oregon
Thanks for the new information! The thread is too big for me to have gleaned all that .
The tube is in the correct orientation and it's the smaller diameter tube. I'll remove the snap ring.
Brian
Smokeshow69
Brian
You just need to spend time to read the thread [emoji16] franklee has done a fantastic job with it. If you go to the first page he has posted links in an index fashion which are a great for quick reference!
Rileysan
Milwaukie, Oregon
One of these days I'll fix my PC and get back into GJ full force. Until that time, I'm stuck with my phone's browser
rshub
T.O.
Hey guys - thrilled I found this thread. Got this Craftsman 150 with the Vari Slo attachment from my grandfather who passed away several years ago. He kept it in great shape and it still works really well. Going to clean it up and check all moving parts and all your past advice is extremely helpful! Funny thing - I always thought the Vari Slo was seized because I could never get it to move until I read your posts and discovered the DP needs to be running to adjust it. Tried it last night and it works perfectly!
F
FrankLee
seMI, 48317
Welcome to The Garage Journal and welcome to the Craftsman Drill Press thread! I'm always pleased to see new members' first posts here.
That is a very nice looking machine and I always like the family history.
I hope you stick around here and elsewhere on the forum. I'm looking forward to your updates and progress on the drill press.
Smokeshow69
Congrats on the family heirloom! Thank goodness you did not break the varislow assembly by trying to move it while it was not running. They are too easy to break that way. Keep us posted with pictures[emoji16]
