C_F
I think the garage size in relation to the house is juuust right.
I think the garage size in relation to the house is juuust right.![]()
. So, we re-worked back to the 6' width. It is much superior.
. My initial thought was the 2 rows of glass at the top. High enough so folks can't see directly in, lets in the most light.
There's plenty of examples here but my own preference (appearance wise) is front to back when viewed from the door. However, it's going to be far easier to install if you are perpendicular to the floor joists. I wouldn't do furring strips myself.
I have been working on the lighting layout; I started by studying many of the layouts in this thread (HERE). These 2 threads are super helpful.
What do you think of this?
It may be overkill, so I am looking for some real advice. Can I scale back the quantity of the fixtures?
As shown I have, 26 48" double fixtures for LED bulbs (no ballasts). I plan on putting these 26 on 2 or 3 separate circuits. The fixtures and bulbs I plan on using all come from the Sticky Thread HERE.
I am working on a layout for the upstairs, but I think I will use the same fixtures, but with difusers (since the ceiling is less than 8'). Probably end up with a simple 2 rows down the center of the ceiling and 1 or 2 fixtures in each dormer.
This brings me to a question:
Does 100 amps of service seem too little for a shop this size?
I don't want to be power limited, but I also don't want to blow the budget on something I will never use. I did the maths, and with what I can figure is the worst worst case ( air compressor running, 2 mini-splits, lights, fans, and a welder), I would be drawing 106+ amps.
I had been planning on pulling the garage power off of the house, but there is really only 100 (maybe 150, maybe) available. I am waiting for the power company to get back to me about adding new service to the shop in order to get 200 or more amp service.
I run 100amps out to my 24 x 24 and have yet to pop a breaker, and I have lots of equipment that pull quite a bit of power. the (7)120V receptacles on the right side of the garage are on a dedicated 20AMP breaker, same with the left. I have (12)T8, 4' long 4 bulb fixtures on the ceiling on a dedicated 15AMP breaker, and a single 220V 50AMP plug on its own breaker
unless you are going to be powering some pretty crazy stuff in your loft, I see no reason to go over 100AMP's, maybe 150 MAX
That is quite a bit all on 100A. What is the most you've had running at the same time?I have three 8' four tube T12 fixtures, 12 - 4' LED work lights, 2-1/2 ton mini-split, 60 gallon air compressor, a Bridgeport, a lathe, refrigerator, mig welder, electric on-demand water heater, all kinds of power hungry power tools and have yet to trip a breaker. All of this is on 100 amp service.
YMMV
[emoji481]
Sent using The Garage Journal mobile app
Nothing crazy in the loft, just lights and 110 outlets.
But I am still skeptical.....
Progress has been really slow ever since Thanksgiving. My contractor seems to be preoccupied with other jobs, so I have attempted to express my concerns that finishing my job does not seem like a priority. Little to nothing has been done since the Monday after thanksgiving.
Nearly 2 weeks of stagnation......very frustrating.![]()
