Joe's Shop Build
J
Joe_K
So with doing it the way you have it that makes it structural, Just not load bearing?
Yes, what I consider structural is the posts, which hold up the roof trusses. The bookshelf girts are there to hold the insulation and wall covering. They're not holding the building up, so there's no point in doing traditional framing.
J
Joe_K
Stronger strength horizontally, especially in high winds.
Yes, that's a bonus. They're surprisingly strong, I can stand on them no problem. Once I hang plywood for the wall covering everything should be tied in nicely.
J
Joe_K
Following.
I saw your question on how to insulate a pole building. I highly recommend Rockwool, it's easy to cut with an insulation knife. I can already tell a difference standing in the corner that's completely insulated. I can't wait to get the rest installed, work keeps getting in the way.
gutted72
Jennings, OK
If you don't mind me asking, where did you purchase your rock wool from, and how many did you need of each size?
My pole barn is very close to the same size as yours and it would save me some time in measuring.
Thanks.
jvitez
Big Sky Country, Canada
Great choice on the Rockwool, and excellent build, and trucks! Congrats!
I used Rockwool in 2 buildings and will never go back to fibreglass. It's amazing watching water pour off of it. You do need to wear a dust mask though. It's amazing the amount of black stuff that came out of my nose when I started using it without a mask.
J
Joe_K
Woke up early to install some more insulation. Time to go to work.
J
Joe_K
J
Joe_K
Insulation is done. Time to put up a vapor barrier and install wall covering. Wish I could find sanded 1/2 in plywood for less than $28.50 a sheet.
penth2o
Thanks for tagging me Joe.
I’m following you footsteps to the tee only on a smaller scale. Mine is only 32x32.
Couple quick questions.... bear with my terminology as I restore vintage cars and not a builder.
The top large boards where it meets your ceiling...the two 12 inch boards.
Did you put insulation in them and cap them. And also, what is the purpose of adding another board strip just below it.
Thanks. I’ll try to load a pic
penth2o
This header board.
gutted72
Jennings, OK
I've been meaning to ask, did you have to trim down your 2x6's to match the width of your posts?
And that insulation looks great.
J
Joe_K
Yes, I filled the header boards with insulation. The top of the boards are covered with cardboard to prevent the ceiling insulation from falling down. Regarding the 2x4 strip, do you see the vertical 12" nailing block? I assume it's a support block for the header. If you have the builder finish your building, they nail 2x4's horizontally on the inside of the posts so you lose 1.5" per wall. I didn't want that, so I put bookshelf girts inside the posts. I put that 2x4 strip so I can step down the wall covering. Hope I explained that well.
J
Joe_K
Thanks. I didn't rip the 2x6's. My posts were 5.5", so are the 2x6's.
J
Joe_K
ac9be520721c43d954bcb41a0eb849c4.jpg6f3db042d83007928b172e7134bec737.jpgdbd859afa3637970102827a5d6c75a73.jpg
I cleaned up a bit tonight.
J
Joe_K
Cold and windy outside, 73 in the shop. The insulation is paying off.
J
Joe_K
IMG_3839.jpgIMG_3838.jpg56476980258__37C3EDB4-3120-41DE-A9D7-6E16D452B4D7.jpgIMG_3849.jpg
A little more progress. Vapor barrier and plywood.
J
Joe_K
Andy9743
in for updates. love the color and similar to what i have in mind for spring. looks great.
J
Joe_K
C_F
Utah...SNOW BLOWS!
It's crazy how expensive good plywood is these days! I would have probably gone with MDF board, 'cuz I am a tight *******. :D
Great looking build! When I looked at your first photos of you clearing the ground, it didn't look like the building would be very large. But the shots of the framed building looked a whole lot larger! :thumbup:
With all that insulation, I imagine your building is pretty much draft free, and nice-n-cozy this winter.
Looking forward to your continued progress updates. :)
J
Joe_K
Thanks, it's a nice tight building now. Two small kerosene heaters bring it right up in the 60's.
