Ton ton
I have not heard some one complain about the dogs slipping before. That is a new complaint for me. I cut cured logs - different set of issues for me.
First chainsaw here...Stihl 250. Not the biggest or the baddest but I got to put in through the paces a bit felling a couple decent sized trees (had some experienced guys guiding me through it) and was very happy with it. I definitely have a lot to learn.
I did notice however that on wet logs with thick bark the fell dogs (bumper spikes) sank in and then didn’t grip much. Without going too nuts are any larger ones interchangeable from other Stihl models? I read some bad remarks about the ones from Piltz.
Through some of my research I came across the forum on ArborSite. Anyone else on there?
Picked this 034 saw up yesterday for $50. The guy said it needed a new coil. He threw in a new bar and freshly sharpened chain.
View media item 100280
First thing I did was pull the plug. This is what I found.
View media item 100281
I replaced the plug and the saw started right up and ran great. I looked in the plug hole, and the cylinder and piston looked perfect. Also pulled the muffler today and not a sign of scoring. And this saw has a ton of compression.
I’ll have to get some pics, but I’ve got an 034 Super that I picked up for $100, put a muffler and air cleaner on it and I’ve used the snot out of that thing. It my favorite saw.
I bought a McCulloch Super 2-10 automatic a little while ago thinking it would be a great resto project. It was for a very silly reason; I really like the right side start saws, being an older made in USA saw meant I there would be no metric fasteners on it so I would only need one set of allen keys and sockets. The guy wanted $35 and said it ran. The problem is it needs no restoration, it all works perfectly and looks to be in great shape too. I've run it only a few times as I typically have 40:1 in everything and knowing this is supposed to be somewhere between 16:1 and 32:1, I just poured more oil right into the gas after filling it a little with my normal mix. It runs fantastic and my only reservation in using it is that it has no brake. I'll have a picture posted in a bit after I clean all the dust off.
As promised, a picture of my McCulloch. Any idea on the specified fuel/oil ratio?
Tried to get the old Husqvarna 50 running. I cleaned the carb, replaced the fuel hose and filter. I could only get it to run for 2 seconds before it dies. I think the floats in the carb are shot. I might replace unless someone has any better ideas. I took out my MS251 stihl bar and chain out of the mineral spirits and hang dry them in the shop.
Here are most of the saws i have had from past and present. Past saws include the Husqvarna 390XP and 2100CD. Also a Stihl MS271. Current saws are my Husqvarna 3120Xp, 562XP and T540XP. I also have some vintage Olympic saws and McCulloch saws.
Although I have no use for one, a 3120 is on my must find list. They just never seem to pop up for sale cheap around me.
Not sure what you are referring to by floats, but chances are the diaphrams in the carb have dried up especially if it has sat with ethanol gas in the carb. They should be rubbery, usually after they sit and dry out the crackle when you flex them.
It is also possible the impulse line is dried out. If you didnt know, it is usually a rubber hose that causes the fuel pump in the carb to pump. If it has cracks or if it is broken off, it will not pump fuel.
Cool old saw. According to Acres, it looks like the manufacturer recommends 20:1. New 2 stroke oils may not require such a high ratio though.
Here is a little info on it for you.
http://acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/e35f4988a0df72d488256b6100194537?OpenDocument
Unfortunately, Arces site isn't the gospel people make it out to be. The Mac -10 series are, and have always been 40:1.
Below is a copy out of the Mac -10, Super Pro and G Series owner's manual (part # 85726).
I have a Stihl MS270 farmboss. Yeah, I know it’s not a pro saw but it does whatever I ask of it. Runs quite well with an 18” bar and the Duro carbide chain. Also have a yellow full chisel chain for it.
Just got this Stihl MS-250 and tore it down for a checkup. Just as good as a new one !
Its funny cuz I watched as two of my neighbors had 5 oak trees professionally removed last week, and as I watched them drop the saws on the ground from 12-18" while hustling to set up, I understood why some of us need pro saws, and some of use can live our entire lives with a MS270. Pro saws are meant to be used 10-12 hours a day, 5-6 days of the week during the prime season.
As I mentioned above, my neighbors had 5 decent sized oaks removed last week, the oldest having 80 rings. The second set of neighbors didn't want the wood from their 4 trees, so my neighbor and I agreed to cut and split the wood, and divide it between the two of us (1.5 cord maybe?).
Three of the trees were over 18" diameter, so I had to do back cuts to ensure I could get through the entire tree with my 18" bar. My MS250 wasn't a hot knife through butter, and it didn't take much muscle to bog it, but if I used some decent technique it worked out just fine!
And while the very first rule I think should be followed is to respect the saw and what it could do to you if something went wrong, knowing it isn't a massive powerhouse makes it more comfortable (easier on my nerves) to use.
My latest project - Jonsereds XF. My personal favorite saw -- beautiful lines, built from 1962-1969 IIRC, 110cc.
Went completely through it, new Caber rings, new fuel line, cleaned up points, etc. Runs pretty darn good on a plug that's probably 50 years old, too.
<iframe width="560" height="315" src="https://www.youtube.com/embed/LAgL1FekH4c" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
