recountryman
- Joined
- Apr 20, 2013
- Messages
- 115
I'm still gathering info for my metal building build either a 30x50 or a 40x60. Now looking into insulation I'm in Georgia so hot humid summers with mild winters with a rare cold spell or two. If I go with CCF I would want some type of a radiant barrier installed first on the ceiling prior to spraying or just directly spayed onto to metal? I've read that due to condensation that would be the best option with a foam thickness for 2-3 ceiling and 1-2 one walls for my area. Will be welding and grinding and walls will be open so want to stay away from OCF. Or would ceiling alone be OK if I go with a light color.
Also I know another option not as good but way more cost effective is the batt insulation are these OK for the temps I will see and how long does these last before the plastic backing starts failing apart as I have been in some building that looked like same stuff where they were falling apart......thanks
