Craftsman 103.9770 Combination Kit (dp#86)
I went and fetched this Craftsman 103.9770 Combination Kit this morning.
It includes:
Oddly, it's missing the 4-1/8" jointer. The way it's set-up in the seller's photo is totally incorrect.
This combo kit was Sears answer to the Shopsmith.
7/13/2020
Included with this kit was a Craftsman 8" table saw, model 103.22161. There were too many missing parts and pieces to make this a refurb project, so I decided to part it out. If you're familiar with the 8" saws, you know that the tilt gears often go bad. This one is in excellent condition.
When I flipped it over, I saw new bolts attaching the frame to the table. That's odd. I continued dismantling the frame and then discovered this custom repair:
The friction ball on the elevator screw was replaced with a 12mm socket!
Here's an oe part next to the repaired part.
I'm torn between wtf and that's ingenious!
8/11/2020
Painting begins on dp#86... Rustoleum 353091 Gunmetal Gray.
8/18/2020
Major progress on dp#86. The base and column are from dp#81.
8/19/2020
For some unknown reason, the original feed handle on the drill press with this Combo Kit was replaced with this too small (3/8"), and too short (10") steel rod.
To remedy that, I fabricated a new feed handle from the 1/2" x 11-1/2" stud (part #66) from an old Craftsman jig saw and two Craftsman stubby screw drivers. This is very close to the original handle size. Perfect!
8/21/2020
DP#86 is complete.
It includes:
- a large 45" x 26" heavy duty power tool bench
- a nice 3/4 hp, 1750 rpm motor, model 115.19790
- a 1/4 hp, 1750 rpm Kenmore motor
This was not original to the combo kit. It runs, but I still need to determine just how good this is yet. - some of an 8" table saw
It's missing one extension, the miter guide, the blade guard(?), the elevator/tilt knob and the oe table insert. - a disk sander assembly, complete
- a Craftsman 80-ish drill press (dp#86)
I have a motor mount and a floor standing base and column to make this a stand-alone drill press.
7/13/2020
8/11/2020
8/18/2020
8/19/2020
8/21/2020
DP#86 is complete.
