Christmas 2020
R
royce
fairbanks ak
Got all the slats for the backrest bent and started to bolt the seat boards to the frame.
Royce
R
royce
fairbanks ak
Fitting up seat slats and each one is a little different to the others.
Royce
R
royce
fairbanks ak
Are you pinning or biscuits or ? on the outer ends of your slats to keep them in line. I do like it.
Sent from my SM-A102U using The Garage Journal mobile app
Harley,
I'm thinking I'll fit flat bars to the under side of the seat, on the outer edges and through bolt them, with the same screws as the center.
With the seat back having less strain on it, I'm thinking some dowel pins cut from tig wire would be a viable option.
Royce
R
royce
fairbanks ak
Seat and backrest all rough fit.
Started beveling the edges.
Still need to figure out how to shape the back rest.
Royce
WoodsTruck
Can you cut a slit down the end of the back boards on each side and insert a metal stabilizer?
R
royce
fairbanks ak
While it is certainly possible, it would be tricky fitting the metal spline, in that it would need bent 2 degrees +/- at each slat intersection.
I'm thinking that it may be easier to fit the the bar to the back side and less prone to splitting.
Royce
R
royce
fairbanks ak
Got all the edges beveled and crowned the top slat.
Thought about cutting some shape in the backrest, but decided to leave it as a simple rectangle with the top and bottom radiused.
Royce
R
royce
fairbanks ak
Also got a flat bars attached on the underside of the seat.
It straightened the outer edges out nicely.
Royce
R
royce
fairbanks ak
The bars on the seat worked well enough, to use the same method, on the backrest.
Royce
R
royce
fairbanks ak
Really looking good Royce. I always enjoy seeing the work of others, especially when it's better than mine.
Thanks Ronin,
Pulled all the seat slats, trimmed them to length and beveled the ends.
They are about ready for a coat of oil.
Royce
R
royce
fairbanks ak
Also got the armrests tacked off.
I tried to use the ones I had previously made, but they just did not look right to my eye.
So I cut them up and came up with this.
Royce
R
royce
fairbanks ak
Armrests welded out and worked on inlaying a stone in the cap of the spine.
Never tried it before, I'll be surprised if I can do it without busting the stone.
Fingers crossed.
Royce
ezriderga
NW GA
Got Santa's shop opened up, for the season.
One of my daughters sent me a pic of a tensegrity table, which is a table that appears to be floating in air.
My thought is to use the same principal for a chair.
So, after some research, a foot of pencil lead and a yard of eraser, got the base cut up and welded.
Royce
So you’re one of my brothers in red? I think that chair is a good idea.
quadrcr87
Travelers Rest, SC
A stone inlay? Now you’re just showing off! How did you cut the profile? I am thinking plasma cutter.
R
royce
fairbanks ak
Drilled a couple starter holes, then rough cut with jig saw and finish shaped with a carbide burr.
Royce
R
royce
fairbanks ak
Got the steel oiled and cut some plastic softeners for the feet, to keep from chewing up the flooring.
Royce
R
royce
fairbanks ak
Finished up the spine cap, with the stone inlay.
Forgot to take a pic, but the stone is held in place with a couple straps tacked on the backside.
I was afraid of heat shocking the stone and busting it, so I went slow on the welding, with a bunch of stops to spray everything with water, to keep things cool.
Royce
R
royce
fairbanks ak
Thanks Harley,
I was really tickled not to bust it!
Cut and tacked the permanent chain tension pins.
On the home stretch now, with milling the armrest oak and final assembly being the last of it.
Royce
loganb
Omaha, NE
Very cool, thank you for sharing. Hadn't seen any of the chair iterations, only the tables!
R
royce
fairbanks ak
Got her done!
Pleased with the function and comfort of it.
As to the aesthetics, it is a bit of a hodgepodge, but that's alright.
From some angles it makes me think of some sort of medieval torture device!
Royce
quadrcr87
Travelers Rest, SC
How much movement in the chains is there with it fully assembled? I picture it with some movement like a floating rocking chair.
R
royce
fairbanks ak
Not as much as I would have thought and the movement is more rotational than to and fro or gee and haw
It also depends on how much preload on the center chain, I have it just snugged and get a few degrees of movement.
Royce
